Doubt about TRD springs height
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
Rasteirinho
Takumi
PostPosted: Wed Aug 20, 2008 12:46 pm    Post subject: Doubt about TRD springs height Reply with quote
Hi,
I have TRD springs fitted in my car (FR 6 Kg, RR 4 Kg).
However the rear stays some milimeters lower than the front, it seems like i have some weight inside the trunk.
Anyone faced the same situation with TRD or other brand springs?
What's the better way to solve this "problem"?
I want to keep the front height unchanged so i'm thinking to fit some spacers in the back between the spring and the axle or between the spring and the body.
Thank you for your suggestions.
Regards,
Pedro
_________________
Keeping the AE86 alive!
Back to top
DJexor
Moderator
PostPosted: Wed Aug 20, 2008 12:58 pm    Post subject: Reply with quote
Had the same with my Btune springs at the rear compare to the eibach coilovers at the front. I hated the look so i lowered the front even more. After my arches were widened i drive rear tires in size 205/55-15 and 195/50 at the front. This also helped to get the front hangover look Smile
check this thread. Maybe Tofu Ben still got those spacers:
http://www.aeu86.org/viewtopic/ae86_-de-cat_-tr...ght=spring+spacer
_________________
9/2001 Toyota Yaris 1.5 T-Sport
Back to top
Jan Pedersen
Moderator
PostPosted: Wed Aug 20, 2008 1:39 pm    Post subject: Reply with quote
Mine did the same with 6/5.1 kg TRD springs. It handeled very nicely, but then I got a good offer on some front coilovers...
_________________
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
Ivan141
Moderator
PostPosted: Wed Aug 20, 2008 5:34 pm    Post subject: Reply with quote
TRD springs were made with shortened strutcasings in mind.. thats why the rear is lower when installed on a stock car.
_________________
'81 poor guy with a money-pit
Back to top
jondee86
Takumi
PostPosted: Thu Aug 21, 2008 9:34 am    Post subject: Reply with quote
According to some old information I have here, TRD at one time
offered a 20 mm spacer (Part #40815-TA452) for their rear RACE
springs. So I guess this is not a new problem Emoke
Cheers... jondee86
Back to top
View user's profile Send private message Send e-mail
Bubble_Drift
Takumi
1987 Toyota Corolla AE86 (late EU)
PostPosted: Thu Aug 21, 2008 12:48 pm    Post subject: Reply with quote
Wow.....I had to cut 1 coil off my trd rear springs because they were too high..haha.
Back to top
robokill
Bunta
PostPosted: Thu Aug 21, 2008 1:51 pm    Post subject: Reply with quote
its correct. I am running 8kg front and 7kg rear. Don't care about the look but the handeling is important. I agree with Ivan saying the front was probably modifeid. Keep in mind that the standard hachi springs don't make the car straight either.
_________________
"08 Honda Civic Hybrid
KIS it
Keep It Sideways
Back to top
Ivan141
Moderator
PostPosted: Thu Aug 21, 2008 4:34 pm    Post subject: Reply with quote
If they are race springs, they were probably meant to complement the trd racing shock absorbers. Those are also meant to be used in short-stroke applications.. without a short-stroke shock, these springs can come loose quite a few centimeters.
_________________
Back to top
hachirokuGTV
Ryousuke
PostPosted: Thu Aug 21, 2008 7:44 pm    Post subject: Reply with quote
I had to cut half a coil to get the rear to set down level with the front. Running TRD front and rear with short stroke setup. Kinda wish I had just found a spring that sits the car lower than a trd rather than cut it. (they don't sit to good on the spring seat when you start cutting them)
Back to top
Bubble_Drift
Takumi
PostPosted: Thu Aug 21, 2008 8:02 pm    Post subject: Reply with quote
Don't worry, I have mine under the car for almost a year now.
Had a couple of driftdays with them too.
They are still under the car. Wink
_________________
Back to top
DJexor
Moderator
PostPosted: Fri Aug 22, 2008 9:11 am    Post subject: Reply with quote
B-Tune/ Swift springs
_________________
Back to top
hachirokuGTV
Ryousuke
PostPosted: Fri Aug 22, 2008 11:27 pm    Post subject: Reply with quote
Do you know how I can get hold of a pair? Need 5kg or 5.5kg max i think.
Back to top
DJexor
Moderator
PostPosted: Sat Aug 23, 2008 1:46 pm    Post subject: Reply with quote
Ask SYM from Passracing, he provided me with Swift springs before. I thought you can get them in 6.0 or 4.5.
_________________
Back to top
assassin10000
Ryousuke
PostPosted: Wed Sep 03, 2008 5:20 am    Post subject: Reply with quote
Both TRD & Swift (afaik) both won't put the fender/wheel arches even. The reason being the arches AREN'T even on the body/car height wise.
Andrew
_________________
1984 AE86 SR-5 (GT-S Converted)
1995.5 Toyota Tacoma 4x4 (Hilux)
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
