broken Crankshaft
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
filh
Takumi
PostPosted: Thu May 08, 2008 8:51 pm    Post subject: broken Crankshaft Reply with quote
Hello ,
A friend of mine broke his crankshaft on a 4AGE . He has a 3 ribs block , and small journals.
He was told that it was a common failure .....
It's a rally car , he doesn't want to have the same bad adventure .
Here's the question : will a big journals crankshaft fit his 3 ribs block .
He will have to change rods to fit journals , but will these big rods fit the forged pistons he have ? Or does he have to change pistons too?
Are the main crankshaft bearing same on both parts ?
and the last one : does somebody has the Toyota part number for the big crankshaft. He asked his local dealer , but he only have the EPC , are there are no measurment on crankshaft
Do you have any replacement suggestion HKS Toda or else ?
I'v added a pic of his car , he's a spectacular rallye driver as you can see
(162HP weber 45 dcoe powered )
any help welcome
Regards
Filh
Viewed 55 Time(s)
_________________
Filh
Save the RWD cars
Back to top
View user's profile Send private message Send e-mail
Project D
Iketani
1987 Toyota Corolla AE86 (late EU)
PostPosted: Thu May 08, 2008 9:00 pm    Post subject: Reply with quote
In french
Malheureusement pour lui il doit changer tout le bas moteur (bloc/vilbrequin/bielle/piston) pour celui d'un redtop, car rien n'est compatible...
_________________
Back to top
Bad_Dog
Wataru
PostPosted: Thu May 08, 2008 9:52 pm    Post subject: Reply with quote
13401-16020
_________________
AE86 GTS '84 Red Top
Back to top
filh
Takumi
PostPosted: Thu May 08, 2008 10:17 pm    Post subject: Reply with quote
thanks for the part number .
in french :
<<<<D"après les infos que j'ai les paliers de vilebrequins sont les mêmes , seuls mes diamètres de maneton changent .
J'attends la suite<<<
Still waiting your further informations : will he have to change block and pistons, to have the big journals crankshaft ? (It's what he wants to have)
Filh
_________________
Filh
Save the RWD cars
Back to top
S.K.
Takumi
PostPosted: Thu May 08, 2008 10:19 pm    Post subject: Reply with quote
Both axles have same main bearing size (48mm) and it fits straight in to 3 rib block.
What size piston pins he have? 18mm? 19mm? 20mm?
Most 42mm conrods have 20mm piston pin. I don´t think that there is a conrods that have 42mm lower hole and 18mm piston pin.
In here are many over 200hp 4A-GE rally engines and almoust all uses original (but balanced) 4A-GE 42mm cranshaft, including me.
_________________
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://youtube.com/watch?v=Kgb8yp0eywM
Back to top
View user's profile Send private message Send e-mail Visit poster's website
Jan Pedersen
Moderator
PostPosted: Fri May 09, 2008 7:34 am    Post subject: Reply with quote
The problem isn't uncommon. Did he balance everything properly?
_________________
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
F0Bman
Takumi
PostPosted: Fri May 09, 2008 7:44 pm    Post subject: Reply with quote
Tell him to get a billet Formula Atlantic one and call it a day. I have one if he's interested.
F0b
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
jamiemirror
Bunta
PostPosted: Sat May 10, 2008 7:17 pm    Post subject: Reply with quote
Big crank will fit, requires big conrods and pistons.
Hi-rev requires precision balancing.
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
firehawk
Takumi
PostPosted: Mon May 12, 2008 10:24 am    Post subject: Reply with quote
I actually just discussed this with a fellow Toyota-enthsiast who's building a gr.F AE92 and he suspected that it may be possible that late-model 4A-FE engines could have a 42mm rod bearing and a 18mm interference-fit piston pin. I have absolutely no experience with 4A-FE engines so I can't say anything one way or the other. Anyone know more?
_________________
Jani Halme / Red 5 Racing || AE86 / EP3 / SW20 / ED9
Back to top
S.K.
Takumi
PostPosted: Mon May 12, 2008 11:23 am    Post subject: Reply with quote
I have changed conrod bearings to one 98-99 Avensis 4A-FE engine, there was 40mm rod bearings... Don't know what size the piston pin was, because I did it under the car.
I take off the sump, change bearings and then put sump back...
_________________
Back to top
filh
Takumi
PostPosted: Mon May 12, 2008 10:43 pm    Post subject: Reply with quote
Thanks all for your answer .
I got a price (don't know the brand ) for a forged crankshaft with conrods :
about 3500€.
He actually have a balanced one with small bearing , and small axles .
He would like to fit the 42mm crankshaft into his newly rebuild 3 ribs block .
BAD DOG gave me the part number for crankshaft :13401-16020 .
He wants to buy new parts , but want also to know if they will fit , before buying
And I just saw the broken part today : it's broken near the 4th cylinder journal . Conrods , bearings and block are well in health.
Filh
_________________
Filh
Save the RWD cars
Back to top
Bad_Dog
Wataru
PostPosted: Tue May 13, 2008 8:41 am    Post subject: Reply with quote
new OEM crank from toyota should be sth like 800euros. (forged)
New pauter rods - sth like 800 USD + shipping. (billet)
That's less than 3500euros IMHO!!!
_________________
Back to top
filh
Takumi
PostPosted: Thu May 15, 2008 2:56 am    Post subject: Reply with quote
my friend has another question : about flywheel : on a 42mm crankshaft, are flywheel fixations same as on the small one.I think the number of bolts aren't the same , and flywheel is larger ?
Filh
_________________
Filh
Save the RWD cars
Back to top
F0Bman
Takumi
PostPosted: Thu May 15, 2008 4:42 am    Post subject: Reply with quote
Good luck man! But get the 20mm crank if you can.
_________________
Back to top
jamiemirror
Bunta
PostPosted: Thu May 15, 2008 10:41 am    Post subject: Reply with quote
Filh
Flywheels between 4AGEs (8 hole pattern) are interchangeable, clutct must match the flywheel (200 or 212mm diameter).
Back to top
oldeskewltoy
Takumi
1987 Toyota Corolla AE86 (late US)
PostPosted: Fri May 16, 2008 6:21 am    Post subject: Reply with quote
I'm currently having Loynings Engine Service(winning formula atlantic engine builder) build me a bottom end. I'm using the smaller crank because it is SUBSTANTIALLY lighhter....
What is common is if it isn't properly balanced the journals marked begin an oscillation because they are not the same as the counter weight on the other side of the journal. This oscillation can be eliminated with balance, and hardening(shotpeen the crank
Using a newer block that is a bit stouter never hurts either
early block on the bottom(upsidedown), later block on top
_________________
Dan -
You can Stupid .... OR you can ask for help!!!
Back to top
View user's profile Send private message Yahoo Messenger
jamiemirror
Bunta
PostPosted: Fri May 16, 2008 10:21 am    Post subject: Reply with quote
Weight difference is ~1 kg.
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
