  Home    shopshop    Garage  Forum RSS feed of our forumsForum RSS   FAQ   Search  Memberlist   Register    Log in
Max a 16v 4AGE can be tuned to?
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
heshan
Ryousuke
1987 Toyota Corolla AE86 (late JDM Trueno)
PostPosted: Sat Apr 18, 2009 12:24 pm    Post subject: Max a 16v 4AGE can be tuned to? Reply with quote
Hey guys,
I went around the main areas in Colombo to find a 4AGE 20V but ended up just getting sun burnt. So I'm just wondering..
How much can a 16V 4AGE be tuned to give out. As mine is a JDM 16V its supposed to give out around 130hp stock.
So what's the max power this engine can give when mod'ed?
how much?
what parts?
thanks,
Heshan.
_________________
Cheated on my Hachi and now I can't get enough of her..
www.PetrolInMyVeins.com
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
banpei
Site Admin
1982 Toyota Carina
PostPosted: Sat Apr 18, 2009 1:45 pm    Post subject: Reply with quote
Depends on what way you would be going and what cash you're willing to spend on it. Wink
350 - 400 HP is the highest I've heard of... But then you're talking about a heavily modified 4AGE with a large turbo and low compression pistons...
Keeping it NA you should be able to get till 160HP without too much trouble and money and anything above 200HP will cost you a small fortune. Very Happy
Better read the Billzilla guide to get the idea:
http://www.billzilla.org/4agmods.htm
_________________
Back to top
View user's profile Send private message Visit poster's website Follow me at Twitter Yahoo Messenger MSN Messenger Skype Name
Eircamae86
Bunta
PostPosted: Sat Apr 18, 2009 3:24 pm    Post subject: Reply with quote
Easy,
how much money you got?
Anything is possible with $$$
_________________
Back to top
heshan
Ryousuke
PostPosted: Sat Apr 18, 2009 4:33 pm    Post subject: Reply with quote
exact reason why I put up the topic. Need to figure out how much of money is needed to mod it to maybe 180hp from the stock engine. Smile
I read the entire article Banpei posted earlier and its quite unbelievable that a stock 16V can be mod'd to have more HP than a blacktop. But still I'm trying to figure out how much and how. I'm trying to run away from engine issues I'm having with my 16V hence the reason for me to search for a BT as its a newer model and easier to find parts for it than the 16v.
_________________
Back to top
Eircamae86
Bunta
PostPosted: Sat Apr 18, 2009 5:11 pm    Post subject: Reply with quote
20v complete head with 7a bottom end with silvertop rods & a bit of effort,
or 20v with overbored block & dirty datsun ca18 83mm pistons. It all depends on what you can do or you local engine shops & parts avilability.
_________________
Back to top
heshan
Ryousuke
PostPosted: Sat Apr 18, 2009 5:36 pm    Post subject: Reply with quote
well I can tell you now that the mechanics here in SL will not have the experience to do that so I'm going to forget about that. but I think I might get the BT as it'll give me a better start of around 150hp with the 95 octane we have here.
So according to the Banpei's article putting new Cams will make a huge difference in making the power increase from around 150 to even 200. So what's the best of cam's around for a good price?
any recommendations through experience?
_________________
Back to top
Uzelac
Takumi
PostPosted: Sun Apr 19, 2009 11:58 am    Post subject: Reply with quote
Both 20V and 16v head have pretty much the same max hp level.
Older 16v have weaker low end, but if you switch to 4AGZE internals 16v can be as much as powerful.
I think it costs the same to pump BT or 16V to 200HP.
What makes the biggest difference in my opinion is the fact that BT will offer 150+ hp both street and track drivable in stock form.
But, if you plan more, 16v or 20v... looks same to me. Maybe 16v is even better, much more people using it, more expirience, more parts..
Back to top
heshan
Ryousuke
PostPosted: Sun Apr 19, 2009 4:03 pm    Post subject: Reply with quote
hmm.. interesting.. But doesn't the ITB's and the VVT give some sort of additional tuning capability that the 16v TVIS versions don't have?
It seems quite illogical (not doubting what you guys are saying but just arguing with myself) that a engine with a base HP of around 150 can be tuned to 200hp at the same price as a older less technologically advanced engine such as the 16v.
_________________
Back to top
heshan
Ryousuke
PostPosted: Sun Apr 19, 2009 4:05 pm    Post subject: Reply with quote
also guys anyone out there with a spare 20v? for a dirt cheap price???
_________________
Back to top
Uzelac
Takumi
PostPosted: Mon Apr 20, 2009 1:29 am    Post subject: Reply with quote
There are ITB's for 16V also, which you can easily put on bigport for the price difference between BT and 16V.
Also, VVTi is great but it makes better low and mid range response and not the high end power.
Back to top
david
Iketani
PostPosted: Mon Apr 20, 2009 2:47 pm    Post subject: Reply with quote
blacktop 20v
toda 304/304
toda valve springs
toda campulleys
toda headgasket
stock bottom end
engine management
approx 180-190hp if everything else is right
please try to use a 16v to obtain the same hp at this price
with an experienced engine builder and a big budget I would say 250-260hp is maximum possible for both 16v and 20v
turbo? I've seen over 500hp on a stock gze bottom end
_________________
3x ke70, 2x te71, 2x ae86, 1x ke20 and 1x hilux
Back to top
Bean Bandit
Takumi
PostPosted: Mon Apr 20, 2009 4:42 pm    Post subject: Reply with quote
david wrote:
blacktop 20v
toda 304/304
toda valve springs
toda campulleys
toda headgasket
stock bottom end
engine management
slap the same setup on a 16V with high comp pistons and some small changes to the intakeplenum (cheap ITBs) and you should achieve the same power - pistons and ITBs should be cheaper than the 20V
and there are others than Toda out there Wink
_________________
Back to top
david
Iketani
PostPosted: Mon Apr 20, 2009 5:44 pm    Post subject: Reply with quote
you say buy high comp pistons and ITB's, that would make the 16v more expensive to build
you would also need headwork done on the 16v, add that too the cost
20v will flow 200hp without any headwork done
and the bottom end will withstand 200hp
sure you will get 180-190hp on a 16v with 304/304 cams but it would cost more than building a 20v
yes I know there is others than toda, but toda is great and that's why I use them
_________________
Back to top
Uzelac
Takumi
PostPosted: Mon Apr 20, 2009 7:55 pm    Post subject: Reply with quote
You are forgeting silly little thing called start cost Wink.
BT is like 1000e more expensive and needs fabrication to get into AE86 chassis. Just for putting in an BT in Hachi you can get pistons, cams or itb's.
Of course, noone sane would swap an BT with 16v, but if you start with 16v, and we all have bluetops at the begining, i think it's better to crank up 16v.
Swapping to BT and then tuning it is most expensive option.
Back to top
Bean Bandit
Takumi
PostPosted: Mon Apr 20, 2009 11:26 pm    Post subject: Reply with quote
couldn't say it any better - learned it the hard way on my S-body
_________________
Back to top
heshan
Ryousuke
PostPosted: Tue Apr 21, 2009 7:01 am    Post subject: Reply with quote
Uzelac do you know where I can obtain these 3 items? I.E. Pistons, cams and ITBs?
Also what's the max Cam size which I could use to gain max HP and still keep the daily driver status Smile ?
_________________
Back to top
Uzelac
Takumi
PostPosted: Tue Apr 21, 2009 9:35 am    Post subject: Reply with quote
HiComp pistons - Wiseco, Arias, Toda, Mahle..
Cams - HKS, Toda, TRD, Catcam, Webcam..
ITB - you can go from "stock" ITB's from newer Corolla or any other ITB/carbs (bikes, other cars, as long as it is from inline 4 engine, it can fit)
There are many topics discussing this issue on this and many other forums. No one can tell for sure which is street drivable and which is not. I don't know from personal expirience, only from other peoples writeups, but it seems to me that anything above 272 becomes problem for every day use. 250-260 is what seems as best setup for daily driven car and 300+ is track only.
Search and read and try if it is possible Smile
Back to top
heshan
Ryousuke
PostPosted: Tue Apr 21, 2009 10:34 am    Post subject: Reply with quote
awesome.. Thanks Uzelac.. I'll do some research on the drivability issue with the increase angle.
_________________
Back to top
panda_tureno86
Wataru
PostPosted: Tue Apr 21, 2009 1:16 pm    Post subject: Reply with quote
love these topics about how to build a 4AG...
The early bigport 4AG can flow the most hp out of all the 4AG heads.
If you are planning to build your blue top.
I would suggest you get yourself a 7 rib block.
Internal of the early model 4AG are not strong.
If you want a cheap way to build a 16V
I would suggest you do following
a silvertop bottome end.
Use it's crank and rod.
Its strong enough to rev up to 9 everyday, providing you look after the motor properly.
if you are tight, then use some small port pistons. They offer a better compression than your big port ones. They are dirt cheap comparing to TODAs or other japanese brands.
You should note that running BIG cams on the 16V meaning you will need some underbuck and shim kit..... which will cost you AN ARM or your kidneys.
I wont even port out the bluetop, just give it a quick polish...
And then run some ITBs off a silver top.
Remember to shave your head and deck your block too to get a better compression, you have at least 7mm of valve clearance.
Doing all that you will be lucky to get 150hp on your crank
(providing your cams are like baby cams)
you will be able to run stock computer that way.
I note that you guys have only 95 octane juice over there......
maybe its worth while running a black top after all.
it would be better off for you for daily use.
and it sounds awsome too Smile
Anyway, good luck.... hope this won't turn into a project with a dead end.
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Tue Apr 21, 2009 8:31 pm    Post subject: Reply with quote
True... I totally forgot about the 4AGZTE conversion:
http://www.aeu86.org/viewtopic/--twincharged-ae-86--/t/7958
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
