  Home    shopshop    Garage  Forum RSS feed of our forumsForum RSS   FAQ   Search  Memberlist   Register    Log in
My 20v ITB installation
Goto page 1, 2  Next
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
Ian.G
Bunta
1985 Toyota Corolla AE86 (late JDM Levin)
PostPosted: Fri Dec 31, 2004 5:43 pm    Post subject: My 20v ITB installation Reply with quote
Well,
its been a while coming but a few of you were interested to see how my ITB installation was done.
Today I have ordered my new trumpets from T3 to replace what can only be described as *the mess* that was already bolted to them.
as they are right now
AE86 : Technical > My 20v ITB installation
after removing the K&N filters you see this...
Look at the way those bell mouths have just been held in with high temp silicone seal !!! they are not even the right size for the 47mm inlets on the silvertop ITBS !!! and 2 of them are falling out. I can imagine that some of that silicone shit has been sucked into my engine which is not good !
Anyone want to hazard a guess as to which injectors these are - I am thinking they are std 4AGE blue top - which probably means they would struggle to provide enough fuel for my 'claimed' power output.
the trumpet plate
This is just a pure work of art LOL
Some nice accurate engineering and welding there Shocked
And the ITBs themselves.
Again - some bonding agent was holding the plate onto the bodies - but look at all the agent that is in the airflow !!! again my engine has probably been eating this stuff which is bad.
I'm not impressed by the dirty mess inside the ITBs - maybe its best to take the whole lot off and clean them up ?
These pictures also show you how the throttle linkage has been done.
Even one of my siamese cats laia admits they are are bodge job.
I now have to put all this *crap* back onto the car as the new trumpets wont be here for a week.
So - what do you guys think ? its pretty messy eh ?
_________________
Regards Ian.
Back to top
Squeejy
Wataru
PostPosted: Fri Dec 31, 2004 6:04 pm    Post subject: Reply with quote
Did it come from Japan like that or was it done in the UK before you got it?
To be honest its things like that I've seen which put me off buying a Japanese import at the moment, the Japanese might have a better climate to keep cars from rusting but it doesn't mean they don't have bodge jobs being done occasionally.
Its good to see that your sorting it out though and at least the rest of the car seems nice. Thumbsup
Back to top
Ian.G
Bunta
PostPosted: Fri Dec 31, 2004 6:48 pm    Post subject: Reply with quote
It was like that from Japan - I'm sure Alex wouldn't have done it that way before I bought it.
As a whole it works fine - its just that I guess I am a bit of a perfectionist when it comes to things like this. I'm sure it will all be ok.
I wouldn't be put off by Japanese imports. This is the ONLY aspect of the car which not quite right (or what I've found so far). I think providing you get the right people to find you the car you can get a good one.
Glen from the driftworks forum has brought in some absolutely amazing cars. He has great contacts over there. He quite often has work carried out on the cars in japan by reputable drift workshops - labour rates are cheaper than the UK and the workmanship is top notch. Take a look at the Silvia 180 that Glen has just got for himself.
I guess at the end of the day these cars are 20 years old - its going to be impossible to find a perfect one.
_________________
Regards Ian.
Back to top
ZaX
Moderator
PostPosted: Fri Dec 31, 2004 8:23 pm    Post subject: Reply with quote
beige injectors = standard 215cc/min injectors
btw i see white cat on your engine!!!
_________________
Go-Drift.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website
Squeejy
Wataru
PostPosted: Fri Dec 31, 2004 8:50 pm    Post subject: Reply with quote
I've seen a couple of imported AE86 imports with a cat fitted but I didn't realise it was that type of cat, I don't think a decat pipe will solve the problem. Smile
Back to top
Ian.G
Bunta
PostPosted: Sat Jan 01, 2005 11:55 am    Post subject: Reply with quote
Zax,
do you have any idea what 'potential' power those injectors run to without going over 85/90% duty ? Looks like I'll need to find myself some bigger ones. Car was said to have 20v injectors - but I guess these are regular 16v 4AGE injectors ?
Well, I dread to think what cams and valve gear I find in the top of the engine. I *should* find some non-std think cams in there, and I *should* find uprated valvesprings etc... I wonder if I will ?
The white cat is not so good - T3 pipe fits much better Wink
_________________
Regards Ian.
Back to top
ZaX
Moderator
PostPosted: Sat Jan 01, 2005 1:28 pm    Post subject: Reply with quote
Yo Ian
The basic formula for calculating fuel requirements is (no. of cylinders x injector flow rate) / 6.75, this equals to about a 90% duty cycle. For example a car with 4 cylinders and 215 cc/min injectors, would have enough fuel for (4 x 215) / 6.75 = 127 hp.
Another useful formula is for calculating the percentage increase of fuel flow through the injectors if the fuel pressure is raised. The formula for this is the square root of (new pressure / stock pressure). So for example let's say you increase your fuel pressure from 38 psi to 48 psi, you percentage increase of fuel would be (48 / 38 = 1.26315). The square root of 1.26315 = 1.12, so you have now increased fuel flow by 12%. So if your injectors are 215 cc/min, you would now have (215 x 12% = 25.8 ) + 215 = 240.8 cc/min injectors.
Some basic info on toyota injectors can be found here.
http://www.aeu86.org/viewtopic.php?t=500
Look what i used to have...a black cat on red top engine.
Then some stupid driver "de-cated" me, so now i have white sparco cat.
_________________
Go-Drift.com
Back to top
Mux213
Site Admin
PostPosted: Sat Jan 01, 2005 1:52 pm    Post subject: Reply with quote
Hey Zax,
your black decatted cat looks alot like my oldest cat:)
I have 5 cats btw.....
sorry for the offtopic post:)
_________________
*** http://shop.aeu86.org - shop at aeu86 dot org ***
*** Check the commercial sales section for our closing down sale ***
No more hachi Sad
Back to top
View user's profile Send private message Visit poster's website
Ian.G
Bunta
PostPosted: Sat Jan 01, 2005 2:11 pm    Post subject: Reply with quote
hehehe,
staying off topic.
some of my other pets (1 cat missing from photo) and my good wife.
back on topic
One of the things I'm trying to determine right now is if the injectors on my car are actually able to supply enough fuel with the ITBs present. I don't have a fuel pressure gauge so I can't tell if the presure as been raised from standard.
I am now completely paranoid that my engine is nothing like the spec it should be.
It obviously has the 20v fuel rail installed and what I think is the std 20v fuel regulator. I guess the 20v runs more fuel pressure than the 16v ?
_________________
Regards Ian.
Back to top
Ivan141
Moderator
PostPosted: Sat Jan 01, 2005 2:38 pm    Post subject: Reply with quote
As far as I know, most (except redtop) 4age's run the same 2,55kg/m2 fuelpressure. The standard 182cc injectors could support around 140bhp at that pressure running 100% dutycycle. At 80% that figure drops somewhat to the 115 to 120 bhp mark.
You really should try and keep an eye on the fuelmixture when running a standalone. A WBO2 readout should be standard equipment if you want to keep the engine in one piece.
_________________
'81 poor guy with a money-pit
Back to top
Ian.G
Bunta
PostPosted: Sat Jan 01, 2005 3:16 pm    Post subject: Reply with quote
Yes,
I'll have a look at the O2/Lambda sensor and see if it has any special markings on it. If it isn't wide band then I will replace it. Would be useful to have a mixture gauge in the car so I can spot enrichment/lean out on the fueling.
_________________
Regards Ian.
Back to top
gon
Takumi
PostPosted: Fri Jan 07, 2005 10:58 pm    Post subject: Reply with quote
Hi there
Are you trying to use the standard MAP ECU to run ITB's ?
If the answer is yes, I sujest that you read the megasquirt, i think that is a very good solution for ITB's
The ITB's didn't come with the fuel rail and the fuel injectores from the 20v engine ? if yes , is it possible to run them instead ?
Thank you Smile
Back to top
Ian.G
Bunta
PostPosted: Tue Jan 11, 2005 9:37 am    Post subject: Reply with quote
Gon,
my car no longer runs the stock ECU. It has a Freedom computer from Japan controling fuel and ignition. I think Paz from Driftworks will be running ITBS on the stock ECU soon so it will be interesting to see how it runs.
Good news !!! Mr postman delivered me a package this morning. I was expecting gaskets and cam gears but the package was the wrong shape.
T3/Gabe has come through again - my new ITB trumpets are here and the quality is amazing !!! will try and take some photographs later.
I just need to order the filter socks now and get a spare hour to install them (I have to clean all the mess from the mounting surfaces on my ITBS first).
I'm going to the Autosport international show on friday so should be able to pick some filters up there. The HKS S15 Genki drift car driven by Nob is also on display so that should be good to see.
I was going to use the orange gasket goo to mount them up and then clean away the excess when they are bolted up (obviously being careful to make sure none goes into my intakes). Does this seem like a good idea ?
_________________
Regards Ian.
Back to top
mo-racing
Takumi
PostPosted: Tue Jan 11, 2005 9:58 am    Post subject: Reply with quote
interesting stuff about injectors!
i also like to go back to theory for double checking (at least i learnd this stuff some years ago so it comes handy sometimes).
i am not really shure if the the flowrate = power calculations are 100% right. normaly i would not bother but i just experienced some stuff on a dyno myself. it was with a hyundai 1500ccm turbo. this car was making 190hp with 192ccm injectors. with stock fuel pressure (2bar over manifold pressure so that was about 3bar).
also the calculation about the stock 4age injectors seems not 100% right. mine makes 128hp in stock form (not just 120hp)
hm...?
i think its best for you ian to check with a lambda meter on a dyno wich can hold constant rpm. then you will know where you are...
cheers
Back to top
mo-racing
Takumi
PostPosted: Tue Jan 11, 2005 10:00 am    Post subject: Reply with quote
btw, is it a high flow cat? Wink
Back to top
Ian.G
Bunta
PostPosted: Tue Jan 11, 2005 10:38 am    Post subject: Reply with quote
Cat is very high flow. I was considering installing them both but It works out a bit expensive Wink
_________________
Regards Ian.
Back to top
mo-racing
Takumi
PostPosted: Wed Jan 12, 2005 8:58 am    Post subject: Reply with quote
would not be a good idea to install the cat infront of the cat. burned hair will jam the metal cat Smile
hey, i found a pic of my old sucker. later that day he pissed into my seat, my nice cat Very Happy
Viewed 134 Time(s)
Back to top
Widar
Bunta
PostPosted: Wed Jan 12, 2005 9:07 am    Post subject: Reply with quote
I'm not surprised, just look at his evil grin Evil or Very Mad while thinking "just you wait!" !
Smile
_________________
Back to top
View user's profile Send private message Send e-mail MSN Messenger
mo-racing
Takumi
PostPosted: Wed Jan 12, 2005 9:40 am    Post subject: Reply with quote
hehe. he alswas does that Evil or Very Mad grin. i think i shoud go to the doctor with him Smile
Back to top
The Doctor
Bunta
PostPosted: Wed Jan 12, 2005 12:52 pm    Post subject: Reply with quote
Please don't, i'm allergic for cats Very Happy
_________________
Back to top
JFR
Itsuki
PostPosted: Wed Jan 12, 2005 10:46 pm    Post subject: Reply with quote
Ian, your running the std AE86 fuel rail. The 20v runs an internal fuel rail as they are side feed injectors that are in the inlet manifold and not situated in the head like on the 16v. It is possible that your fuel pressure has been turned up by squashing the regulator thats on the end of the fuel rail.
Best way to check the pressure is to mount a gauge where the cold start injector feed is on the fuel rail.
My grp A car only has 210cc injectors, but the pressure is more than standard and it makes 197ps
I ran the 20v throttle bodies on my old black car with the std ecu, it can be done.
If you need some help im not far away.
Jamey
Back to top
Ian.G
Bunta
PostPosted: Thu Jan 13, 2005 9:44 am    Post subject: Reply with quote
Cheerrs for the help/advice Jamey.
Since starting the thread and understanding a little more about injector types from 4AGE motors (especially the difference between the 16v and 20v) I figured the rail was the std 16v unit once I'd found out the injectors were not 20v.
I must get a pressure gauge on there at some time. We did have one on our old hayabusa powered westi but I cant find it now.
When all this new stuff gets fitted onto the car I'd like to put it on the rollers and see what its making (I reckon maybe 150bhp ish at the flywheel). At the same time I'd also like to use a wide band 02 monitor so we can see how the fueling is doing. The biggest problem right now is not being able to work with the ECU.
_________________
Regards Ian.
Back to top
Ian.G
Bunta
PostPosted: Sat Jan 15, 2005 8:40 pm    Post subject: The mess is gone... Reply with quote
Well,
today I made a difference to my hachi Smile
if you remember my ITBS looked like this behind those trumpets
So, after approx 1 hour of cleaning gasket sealant and some metal cleaner they looked like this.
I was at the autosport show yesterday and managed to pick up a set of pipercross C1050 trumpet socks direct from their stand at half the retail price. Thumbsup This is what was waiting to be installed onto the car...
And after a bit of spannering...hmmmmmmm.... trumpets Drool
Gasket seal was cleaned up and the socks installed and zip tied into place.
What with getting the timing sorted and fitting these the car is pulling like a trooper - its really smoothed things out and it revs hard as you like again. I was so happy I decided to navigate an entire roundabout - sideways LOL.
_________________
Regards Ian.
Back to top
rikard
Takumi
PostPosted: Sat Jan 15, 2005 8:47 pm    Post subject: Reply with quote
That looks very nice, look forward to seing your car at Silverstone next weekend! Smile
Back to top
Mux213
Site Admin
PostPosted: Sat Jan 15, 2005 8:49 pm    Post subject: Reply with quote
Looking good!
_________________
No more hachi Sad
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
