  Home    shopshop    Garage  Forum RSS feed of our forumsForum RSS   FAQ   Search  Memberlist   Register    Log in
LSD question
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
evfan42
Ryousuke
1986 Toyota Corolla AE86 (late US)
PostPosted: Tue Jul 17, 2007 1:28 am    Post subject: LSD question Reply with quote
idk if this question has been asked or whatever...
If I took the pumpkin off a GTS rear end and stuck it into my SR-5 rear end, will it fit?
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
parrot
Takumi
PostPosted: Tue Jul 17, 2007 4:18 am    Post subject: Reply with quote
Maybe, depending on what type of rear ends SR5's had.
The GTS has a T series rear end. Do SR5's have T or S series rears. LSD's are not available for S series diffs.
Have a look on your build plate and see what it says next to transaxle. T50 refers to the gearbox, the rear axle will be a code something like S314 or T282.
If you have a T series, yes you can bolt in the LSD, if you have a S series, no you can't as the ring gear diameter is too big - 6.7 inch vs 6.38 inch.
See here for more info on interpreting diff codes.
http://www.toymods.net/forums/showthread.php?t=350
_________________
AE86 4AGE
KE15 SL Sprinter
KE25 shell (to be 3TG TE27)
Back to top
evfan42
Ryousuke
PostPosted: Tue Jul 17, 2007 6:07 am    Post subject: Reply with quote
alright thanks parrot ill check tommorow or so
Back to top
assassin10000
Ryousuke
PostPosted: Tue Jul 17, 2007 5:22 pm    Post subject: Reply with quote
It's a US model ae86. The sr-5's ONLY came with the smaller 6.38" rear end with drum brakes. They did not come with the 6.7" (t-series) diff's with drum or disc brakes.
So no, he can't swap a gt-s pumpkin into an sr-5.
Andrew
Back to top
parrot
Takumi
PostPosted: Tue Jul 17, 2007 5:55 pm    Post subject: Reply with quote
Same problem we have in Australia. We didn't get a GTS version here at all, and all Australian Sprinters were very basic SR5 type spec, or AE85 spec if you are from New Zealand. So we rely on importers to bring in t series rears from japan. $$$$
_________________
AE86 4AGE
KE15 SL Sprinter
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
