Factory Electrical wiring diagrams & engine diagnosis ma
01-12-2007, 02:12 AM
I have scanned up the AE86 factory detailed Electrical Wiring Diagrams Book (1983) as well as the factory 4AGE TCCS Diagnosis Manual. Both have been my bibles for the last few years. Very useful.
Both are on this site in PDF
see below, now on aeu86.org server
The EWD is very detailed and contains each seperate circuit and illustrates each plug and where each wire goes within it. Not just the basic schematic diagrams, though they are there too. Engine diagnosis manual takes you through step by step for ECU and wiring related faults. Includes pinouts. This applies to AA and AE body series with 4AGE
Edit:
AE86 Wiring Diagrams EU/AU (1983) by Parrot (5Mb):
AE86 Wiring Diagrams (EU/AU)
AE86 Wiring Diagrams USDM (1986) by Parrot (5Mb):
AE86 Wiring Diagrams (USDM)
4A-GE Diagnostics Manual by Parrot (8Mb):
01-12-2007, 02:39 AM
it has tons of info. too bad it doesn't have the electric window diagrams because is for 1983...
those i needed Banging head
Pedro Velado
GT-S Owner
[Image: AEU86 AE86 - Factory Electrical wiring d...agnosis ma]
01-12-2007, 02:47 AM
No problem, I have those too, BUT for the USDM model. The US looms are very different from the Euro looms however I expect the power window section would not vary much until it gets to the junction box. Though actually I note you are in Central America which I presume have LHD US spec GTS's.
I do not have this electronically and it was difficult enough getting access to a scanner to do these two files.
If you PM me either a fax number or an address I can send them to you on Sunday morning Australian time
01-12-2007, 06:22 PM
Parrot: Is it okay if we mirror the diagrams? Tongue
01-12-2007, 07:15 PM
Yes parrot, i drive a USDM LHD corolla.
Please mail the diagrams to [email protected] . Thank you so much, I really appreciate it since I'm having problems with my passenger side window, I cannot open it, unless i take off the door panel and do it manually Angry
Pedro Velado
GT-S Owner
01-13-2007, 08:35 AM
Banpei - absolutely. I shall try and put up the USDM EWD and other assorted useful things at some stage. Scanning is not so easy unfortunately but I am working on a way around that.
Pedro - if you want it emailed you may have to wait a while as it isn't scanned. I shall see how I go. I can post or fax though.
01-13-2007, 01:18 PM
I know the problem. I promised I would scan my EWD as well some time ago, but I never found the time to do it. Undecided
But I've put them up here:
http://files.aeu86.org/manuals/ewd-ae86-...parrot.pdf
http://files.aeu86.org/manuals/4age-diag...parrot.pdf
As you can see I've put your name in it. Smile
Thanks again! Thumbs up!
Edit: I've also added them to our Technical FAQ section. Smile http://www.aeu86.org/viewtopic.php?p=35506#35506
01-14-2007, 01:10 AM
I'm famous!! Thanks Banpei.
Have just finished copying the USDM EWD too. It has all sorts of odd things such as the trueno pop up light circuit, cruise control, power mirrors, power windows etc.
I shall try and get this scanned on Tuesday and advise when it is up.
01-14-2007, 02:14 AM
Hopefully it contains the power sunroof circuit as well. It's not that difficult but I want to check myself if I discovered the wires correctly... Smile
1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
01-14-2007, 12:05 PM
The sunroof circuit is in the Euro version already listed above. Not hard, it goes from the junction box in the drivers footwell.
  Tail light wiring... Mylesmck 4 285 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 3,163 05-23-2022 10:00 PM
Last Post: The Doctor
  Where to run the factory antenna cable andyling 2 3,127 09-30-2020 12:31 PM
Last Post: andyling
  4A-GE wiring engine to chassis connectors Lykowsky 4 6,226 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 4,730 05-18-2019 01:50 PM
Last Post: DJexor
