| Author |
Message |
andrecorreia Iketani
Posted: Thu Aug 28, 2008 2:44 pm Post subject: Carina rear end questiom |
Hellod!!!
Anyone knows if the toyota carina st (ta40) rear axle is the same as the toyota ae86, or if the lsd of a ae86 will fit the diff??. Has the carins diff disc brakes??
Thanks
_________________ Always on top always on sideways
http://img512.imageshack.us/img512/6080/hoontruckcustomrx5.jpg
| Back to top |
F0Bman Takumi
Posted: Wed Sep 03, 2008 5:38 am Post subject: |
If not, I heard that the AE86, rear end can be used on the Carina.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Thu Sep 04, 2008 4:31 pm Post subject: |
Axle should be the same since ta40 axle is the same as ta60 axle, but it uses drum breaks. However I think the mounting points are different. Perhaps you can ask Brawnie: he just sold his AE86 with Carina axle.
| Back to top |
The Doctor Bunta
Joined: 18 Sep 2004 Posts: 2224 Location: Goirle, The Netherlands
Posted: Thu Sep 04, 2008 4:54 pm Post subject: |
Zenki AE86 diffs wil fit the TA12/TA22/TA40/TA60 solid rear ends, but you need to take off 6mm of the halfshafts to get it to accept an LSD
_________________
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Thu Sep 04, 2008 10:32 pm Post subject: |
| The Doctor wrote: | Zenki AE86 diffs wil fit the TA12/TA22/TA40/TA60 solid rear ends, but you need to take off 6mm of the halfshafts to get it to accept an LSD  |
That's good info!
Anyone got a zenki diff lying around for me somewhere?
| Back to top |
| Back to top |
