| Author |
Message |
CoolinAE86 Itsuki
1985 Toyota Corolla AE86 (late JDM Trueno)
Posted: Tue Jul 29, 2008 6:13 pm Post subject: power steering yes or no...? |
Hey guys just wondering if the power steering is good for drifting or if i can take it out right now i'm running with out it so i don't know if it would be easier wto drift with it..?
_________________ '85 Corolla Sprinter Trueno GT-APEX
| Back to top |
speed-inc Takumi
Posted: Tue Jul 29, 2008 6:27 pm Post subject: |
Changing to non power steering will give you more steering lock. The knuckles are longer.
I do have non power and drifting the car can be stressful. But you get used to it and the steering response is always great.
_________________ Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: info@speed-industries.ch
phone: +4155 420 15 69
page under construction
We have all the parts your Hachi needs
| Back to top |
Bubble_Drift Takumi
Joined: 26 Nov 2005 Posts: 345 Location: Venray - Maastricht - The Netherlands
1987 Toyota Corolla AE86 (late EU)
Posted: Tue Jul 29, 2008 6:33 pm Post subject: |
Use a NON powersteering rack with Power steering knuckles.
These are shorter and give you extra lock.
I have it and it works amazing!!!
Drifting has never been this easy!
| Back to top |
speed-inc Takumi
Posted: Tue Jul 29, 2008 6:35 pm Post subject: |
Oh sorry mixed it up then
8808 Pfaeffikon
Switzerland
| Back to top |
CoolinAE86 Itsuki
Posted: Tue Jul 29, 2008 7:13 pm Post subject: |
So it's better with out the power steering..?
| Back to top |
Bubble_Drift Takumi
Posted: Tue Jul 29, 2008 7:28 pm Post subject: |
What do you have now?
If the car came stock WITH powersteering, then I would convert it to NON powersteering. If you just disconnect the power steering system, it will only make steering harder. Will not give you any extra lock or whatever..
There is a difference in steering racks.
If the car came stock withOUT powersteering, then keep it that way, only replace the steeringknuckles with the shorter powersteering ones.
| Back to top |
CoolinAE86 Itsuki
Posted: Tue Jul 29, 2008 7:45 pm Post subject: |
the car came stock with power steering what i've done is just disconnect the power steering so i have to convert it to non power steering
| Back to top |
GTRJazz Iketani
Posted: Tue Jul 29, 2008 9:16 pm Post subject: |
After a hour of flying around brands hatch I was glad I had power steering fitted. Add big semi slicks and lots of castor and it would be a must.
| Back to top |
Miguel - Newera Ryousuke
Joined: 22 Aug 2005 Posts: 189 Location: Tokyo, Japan!
1985 Toyota Corolla AE86 (late JDM Levin)
Posted: Tue Aug 05, 2008 2:19 pm Post subject: |
I run power steering on my GT Apex Levin, my colleague with a Trueno GTV (20V) doesn't. He complains it gets very heavy for drifting and his shoulder can hurt a bit after a day steering one handed on the track (He uses the handbrake a fair bit ). Power steering's definitely a benefit... I've not had any problems drifting with power steering fitted.
If you use shortened knuckles you may (as I did) find the car becomes unstable at high (Motorway) speeds, since the steering becomes too sensitive...especially where roads have groves worn in them by trucks..
I fitted tie rods that allow more steering lock, in addition to shortened knuckles. The result was that the lock would be so much the tyres touch the inner arches, etc. On full lock moving off from standstill the car almost stalls as it needs to turn such a tight radius. So shortened knuckles with uprated tie rod ends connecting to the rack are overkill.
So I switched back to the standard PAS knuckles and kept the high lock tie rod ends. These are an inexpensive modification (About £100) that works well. I can still get good lock and I have the stability at speed I prefer. I don't have problems running out of lock when drifting.
I definitely wouldn't recommend disconnecting the power steering though. That's pointless, unless you're worried about losing a negligible amount of power to run the pump.
_________________ VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
| Back to top |
sergiocharged Wataru
Posted: Wed Aug 06, 2008 6:35 am Post subject: ??? |
when u mean change the steering knuckle u mean change this like the picture and change the tie rod i can understand that but what u mean with good lock when u change the tie rod what kind ?shoter?larger?
really this is new for me
| Back to top |
Ozone Itsuki
Joined: 12 Feb 2007 Posts: 12 Location: Japan currently, soon Northampton UK
1987 Toyota Corolla AE86 (late JDM Levin)
Posted: Sat Aug 09, 2008 4:19 am Post subject: |
Most modern cars the knuckle is like in the picture.
The knuckle connects to the out ball joint and holds the hub and wheel bearings. At the top of the knuckle it is bolted to the strut and at the bottom it is bolted to the lower suspension link.
On some older cars such as AE86s, E30 BMWs and others it is different.
The hub and bear sits on a spindle which is welded to the bottom of the strut casing.
The knuckle that the out tie rod fits to is a separte part that bolts to the lower suspension link and the lower strut casing - sandwiched inbetween.
Therefore it is possible to have different steering arms on different varients.
In the 86s case the PS models have shorter steering arms than the non-PS models.
| Back to top |
jondee86 Takumi
Posted: Sat Aug 09, 2008 6:47 am Post subject: |
Back in the late 70's and early 80's most cars in this country were
RWD and manual steering. Power steering was a luxury only found
on a few of the most expensive cars. Like automatic gearboxes, P/S
was considered to be more suitable for women...
Manual steering worked fine, and still does with OEM spec wheels
and tires. The problem of heavy steering typically only arises
after "improving" the handling by fitting wider wheels and tires. The
wheels usually have a more negative/less positive offset, which
alters the steering geometry. Someone who is more into the technical
stuff can probably explain it better
If you can retain the OEM offset when choosing wider rims, the effect
of the increased footprint of larger/wider tires is much reduced. But
since everyone likes to get those guards filled, with the biggest, widest
wheels possible, keep the power steering
Cheers... jondee86
| Back to top |
Posted: Sat Aug 09, 2008 10:47 pm Post subject: |
keiichi tsuchiya AE86 TRD hot version specially modyfied for him
use non power steering so i though power steering was the best option but ill keep my non steer rack and see if the power steering knuckles are better like i heard
| Back to top |
Jezza_hr Bunta
Posted: Fri Aug 29, 2008 11:09 pm Post subject: |
I'm probably just reviving this thread for no good reason, but when it comes to power steering i'm in a bit of a rough spot.
My AE86 came with power steering and air con and i've just about finished doing a 20V conversion. The problem i'm facing is that i've removed the air con and would like to keep the power steering but i'm having trouble finding a vacuum line to take from the block itself as most of them were blocked off by the previous owner of the engine. Is there any way I could get around this?
Failing that i've toyed with the idea of getting an adjustable power steering pump from a citroen so I can set the sensitivity levels to my preference and since they are battery powered, they wont take any power away from the engine by running a belt.
Any suggestions?
| Back to top |
jondee86 Takumi
Posted: Sat Aug 30, 2008 8:45 am Post subject: |
Two possibilities come to mind. The first is to replace the part of the
inlet manifold that sits against the head, with another unmolested one.
Since most ITB conversions onto 16 valve engines use only the throttle
bodies, there should be plenty of manifolds lying around
The second would be to tap a 5 mm hose fitting into any part of the
ISCV pipework (the stock fitting taps into the manifold section).
Alternatively, providing you are running the standard ISCV system.
you might like to wait and see if the ISCV system can handle idleup
for the P/S. If it can cope with the A/C load, it should (in theory) be
able to handle the P/S as well.
Oh, and all electrical accessories put a load on the engine via the
alternator. There is no free lunch
Cheers... jondee86
| Back to top |
Jezza_hr Bunta
Posted: Sat Aug 30, 2008 10:10 pm Post subject: |
I'll see how I get on without power steering and may get some of the tie rods miguel was talking about.
| Back to top |
topi
Posted: Mon Sep 01, 2008 2:53 pm Post subject: |
I have a non PAS levin, with wide wheels and lots of camber. I'm a small guy with little arms... and don't have a problem haha. People need to consume more energy drinks before they drive.
| Back to top |
Akina Wataru
Joined: 11 Sep 2006 Posts: 97 Location: Odessa-Moscow
1985 Toyota Corolla AE86 (early US)
Posted: Sat Sep 27, 2008 9:52 pm Post subject: |
| Miguel - Newera wrote: | I run power steering on my GT Apex Levin, my colleague with a Trueno GTV (20V) doesn't. He complains it gets very heavy for drifting and his shoulder can hurt a bit after a day steering one handed on the track (He uses the handbrake a fair bit ). Power steering's definitely a benefit... I've not had any problems drifting with power steering fitted.
I definitely wouldn't recommend disconnecting the power steering though. That's pointless, unless you're worried about losing a negligible amount of power to run the pump. |
yesterday i was change to non powerstereeng rack...and my steering column shorter (cross-piece)does not reach to the rack (( sorry for bad english...can u help?
_________________ Kouki Levinter AE86 - wicked panda projecto
| Back to top |
speedyrolla Wataru
Joined: 18 Jan 2007 Posts: 112 Location: Aruba,The Caribbean
Posted: Sun Sep 28, 2008 12:15 am Post subject: |
Mine has no P/W steering and it sucks only when you are going to park in tight spaces and I have a welded diff as well and it can be sometimes a pain in the @ss man...
| Back to top |
Ozone Itsuki
Posted: Sun Sep 28, 2008 3:20 am Post subject: |
Akina, you need to use a non-PS column with a non-PS rack.
Otherwise you will have to make up some sort of extension for the PS column to fit to the non-PS rack.
| Back to top |
assassin10000 Ryousuke
Joined: 31 Aug 2006 Posts: 131 Location: Sacramento, CA
Posted: Sun Sep 28, 2008 9:31 am Post subject: |
| Ozone wrote: | Akina, you need to use a non-PS column with a non-PS rack.
Otherwise you will have to make up some sort of extension for the PS column to fit to the non-PS rack. |
FYI: the intermediate steering shaft (removable part that comes out of the steering column - has the splines the u-joint slips onto) from an MKIII supra (87-92) will slip right into the corolla P/S column & connect the manual steering rack to the p/s column.
Andrew
_________________ 1984 AE86 SR-5 (GT-S Converted)
1995.5 Toyota Tacoma 4x4 (Hilux)
| Back to top |
jondee86 Takumi
Posted: Sun Sep 28, 2008 9:44 am Post subject: |
| topi wrote: | I have a non PAS levin, with wide wheels and lots of camber. I'm a
need to consume more energy drinks before they drive. |
Yeah... wide tyres are really only a problem when parking, or making
similar walking pace manouvers. Even with standard width tyres on a
non-power steering car, you soon learn to turn the wheel while the car is
moving. Once you have some speed up, the problem disappears
The upside (IMHO) is that you get a better feedback from the front
wheels without P/S getting in the way.
Cheers... jondee86
| Back to top |
Akina Wataru
Posted: Tue Sep 30, 2008 8:56 pm Post subject: |
W\ell done)thanx for All
| Back to top |
Jezza_hr Bunta
Posted: Wed Oct 01, 2008 12:16 am Post subject: |
| jondee86 wrote: | | topi wrote: | I have a non PAS levin, with wide wheels and lots of camber. I'm a
Cheers... jondee86 |
Quoted for truth. After driving around for a few days without power steering, I can easily say that the feedback you get is far more noticeable (this is not the first time i've driven an 86 without ps) without it. The downside to it however is you cant steer as quickly, so flicking out the tail end of the car is a little bit more work and a struggle to some.
I'm toying with the idea of putting it back on, simply because i'm used to the power steering now and I do a lot of parallel parking and street driving. One thing I did ask in another thread is if it's damaging to the PS rack if it has no fluid in it - e.g does the fluid lubricate anything that could get wear and tear if it's not lubricated?
| Back to top |
david Itsuki
Posted: Wed Oct 01, 2008 1:48 am Post subject: |
for maximum comfort use powersteering
for maximum controll don't,
same rules apply for the brake booster
_________________ 3x ke70, 2x te71, 2x ae86, 1x ke20 and 1x hilux
| Back to top |
