removing and replacing speedo wormgear?
08-30-2008, 10:03 PM
I'm having a little trouble removing the speedo unit from my old gearbox to move the wormgear over to my new gearbox. After you remove the bolt that supports it, are you required to give the small housing a good tug with some vise grips or am I doing it wrong?
08-31-2008, 06:23 PM
No one? I've looked through the workshop manual and it doesnt explain anything
08-31-2008, 07:01 PM
You have to get some plyers and then just twist it from side to side while pulling backwards, had the same problem on mine and thats the way to get it out...
AE86 Levin now completed and with new wheels! ![]() Levin renovation post! Daily driver: VW Golf VI 1,6 TDI Highline, Wife: VW Polo 1,2 TSI Comforline |
09-01-2008, 01:32 PM
Use multigrips to give it a gentle twist. Shouldn't take much to come out.
09-03-2008, 05:36 AM
Yeah teh worm gears is a sensitive piece, make sure that you buy the right one.
| Pinout of some connectors needed for removing JB2 | Koen | 4 | 1,202 |
04-01-2026 07:27 PM Last Post: Koen |
| Replacing Top Windscreen Moulding | chrisae86 | 2 | 3,803 |
06-18-2022 08:56 PM Last Post: chrisae86 |
| Replacing front lca | zenki | 6 | 8,025 |
05-02-2017 03:23 PM Last Post: pack |
| removing light switch ? (fixed) | MC_JP | 10 | 20,896 |
09-18-2014 05:16 PM Last Post: MC_JP |
| Removing front window trim | zenki | 7 | 15,491 |
09-07-2014 08:36 PM Last Post: Ivan141 |
![AEU86 AE86 - removing and replacing speedo wormgear? [Image: AEU86 AE86 - removing and replacing speedo wormgear?]](http://i895.photobucket.com/albums/ac155/Juhler86/AE86%20Renovation/ae86.jpg)
