HELP 7age problem no start!!!
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
krzak
PostPosted: Thu Aug 28, 2008 11:53 pm    Post subject: HELP 7age problem no start!!! Reply with quote
I read post HERO.....
We get block 7age and 4age head....now engine in the car....but we have
problem with adjusting cams.
We have belt from Porsche.
I try few set but engine cranking how dont have spark plugs.
Please tell me how I must set cams when I have TDC on crank.
Thx a lot Sad
Back to top
Ivan141
Moderator
PostPosted: Fri Aug 29, 2008 3:19 pm    Post subject: Reply with quote
I have no idea how the 7age guys adjust their cams, and I havent seen hero round here for a while. What I would do is to set the campulleys to the approximate position they need to be in (you can find this in the manual, which you can download from the aeu86.org homepage). Then grab an old 4age timing belt that still has the indication stripes on the back, and count the number of teeth between the 2 stripes that are nearest to eachother. Then draw 2 lines on the porsche belt with the exact same number of teeth between them and use these to properly adjust the campulleys.
After that it's a matter of setting the crank to TDC, keeping the campulleys in the right place and installing the belt (making sure it's tight on the side without the tensioner). Now when you fasten the tensioner, look if everything is where it's supposed to be, and draw a line on the back of the timing belt at the adjustment mark on the crank pulley.
Finally, make a note of the distances (nr of teeth) between the lines you drew, and post it in a 7AGE thread here so future generations will benefit from your work Puh
Hope that helped, if anyone knows a simpler method that will make me look stupid, please share.
_________________
'81 poor guy with a money-pit
Back to top
jondee86
Takumi
PostPosted: Sat Aug 30, 2008 12:31 am    Post subject: Reply with quote
Setting the cam timing on a 7AGE should be the same as when
the head is installed on a 4AGE. The only difference is that the belt
has a few extra teeth. However, if you have had everything apart,
you should check the following list:
1. Are the cam wheels fitted to the camshafts correctly ?? When the
dimple on the rim of the cam wheel is at the top, the knock pin on the
inlet cam is in the top slot, and the knock pin on the exhaust cam is
in the bottom slot.
2. Install the cams with the dimples on the cam wheels at the top.
The dimples should line up in the centre of the twin raised marks
pressed into the steel plate behind the cam wheels.
3. Set the crankshaft to TDC on number one cylinder. The notch on
the crank pulley should align with the zero degrees mark on the
bottom timing belt cover.
4. Fit and tension the timing belt. Check that all the marks are still in
the correct places.
5. Remove and reinstall the distributor according to the manual.
Check that the rotor arm is pointing at the post for the number one
cylinder spark plug.
You should be good to go Cool
Cheers... jondee86
And this is always worth another read....
http://www.aeu86.org/index/engine-4age-to-7age-conversion/cat/9/topic=4156/post=60902
Back to top
View user's profile Send private message Send e-mail
F0Bman
Takumi
PostPosted: Mon Sep 22, 2008 4:29 am    Post subject: Reply with quote
Have you checked your grounds or your ignitor ground? The 4AGE is very sensitive to grounds that are not good.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
