| Author |
Message |
PetzK Takumi
Posted: Mon Aug 25, 2008 8:15 pm Post subject: Cams /w 9+mm Lift |
Hi,
Where can I find Hi-lift cams (9mm+) for the 16V engine? Duration about 260-270° (a little more aggressive than the KK101 from Ted Components) -> What about Toda cams? 264/272° @ 9/10mm
Are Toda valve springs ok for >9mm lift? Combined with 1SZ-FE buckets
Thanks,
Patrick
| Back to top |
ghost rider
Posted: Mon Aug 25, 2008 9:25 pm Post subject: |
toda says that their valve springs are o.k. up to 10.5mm lift.
_________________ go-go-go!
| Back to top |
PetzK Takumi
Posted: Tue Aug 26, 2008 12:41 pm Post subject: |
ok, that's already useful info, thanks!
| Back to top |
F0Bman Takumi
Posted: Wed Aug 27, 2008 5:31 am Post subject: |
That is a good amount of lift, you might need under bucket shims.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
PetzK Takumi
Posted: Wed Aug 27, 2008 8:14 am Post subject: |
Well, thats what I wrote....
| Back to top |
totta Crolla Takumi
| Back to top |
tolisspi Takumi
Joined: 24 Jan 2008 Posts: 275 Location: Greece-Korinthos
Posted: Wed Sep 10, 2008 8:52 am Post subject: |
i ll use 272 and 10,3lift. ll i need shims?
_________________ **COROLLA EE80 - 4AGE 124HP**
| Back to top |
F0Bman Takumi
Posted: Wed Sep 10, 2008 7:08 pm Post subject: |
You should consider TODA cams or HKS cams. They are readily available and have sizes you need.
| Back to top |
tolisspi Takumi
Posted: Wed Sep 10, 2008 11:29 pm Post subject: |
i have bought TODA with that duration and lift
| Back to top |
