Underbucket shims
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
totta Crolla
Takumi
PostPosted: Sat Aug 16, 2008 8:48 pm    Post subject: Underbucket shims Reply with quote
Anyone have a clue what to use ?
I have seen a 'top hat' type used that sits on the valve stem and I know TRD do a spring retainer that uses a flat 9.5mm shim that fits in the top. I think the TRD ones use non standard collets (keepers) also. Any other issues with the TRD type ? thanks tc
_________________
"accidents are rare but you're a long time dead"
Back to top
robokill
Bunta
PostPosted: Sat Aug 16, 2008 9:10 pm    Post subject: Reply with quote
Yaris ones. Yaris (vitz?) has the same size. Its well known in japan and also found on club4ag. I am building an engine which also has it. Just buy the cams. Measure with the original buckets than buy one yaris. Measure what you need and order form toyota.
_________________
"08 Honda Civic Hybrid
KIS it
Keep It Sideways
Back to top
totta Crolla
Takumi
PostPosted: Sat Aug 16, 2008 10:09 pm    Post subject: Reply with quote
Thanks for the reply. I should have made it clear that I already have the underbucket cam followers, just need to sort the shims now
_________________
Back to top
F0Bman
Takumi
PostPosted: Wed Aug 27, 2008 5:37 am    Post subject: Reply with quote
Consider using the Yaris under bucket shims, these are one piece and are much lighter.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
eight-six
Ryousuke
PostPosted: Wed Aug 27, 2008 10:32 am    Post subject: Reply with quote
Totta - The set up you have described sounds identical to the shim/bucket set up found on the late spec 3sgte (and possibly other engines)
Its an under bucket arrangment with a small shim that sits in the spring retainer recess under the bucket - the shim is about 10mm across or there abouts from memory.
The shims can be found on 1994 onwards SW20 turbo or a ST205 GT4.
Sounds like you have confirmed what I stated a whle back that the under bucket arrangement on the late 3SGTE will also fit the 4AGE head.
Your looking at about £40 for a full set of shims for the head - Toyota can supply them in every size but you will need to get 1 first so you can work out the tolerances and what you need for the rest of the 16 valves.
I will see if I have any spares kicking around in the garage from the last gte rebuild i did.
_________________
www.eight-six.co.uk - UK AE86 Forum
http://www.phpbber.com/phpbb/index.php?mforum=wwweightsixcouk
Back to top
View user's profile Send private message Visit poster's website
F0Bman
Takumi
PostPosted: Mon Sep 22, 2008 4:28 am    Post subject: Reply with quote
Try contacting friends on this board to get you the shim sizes you need for your head adjustment.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
