| Author |
Message |
generalachoo Iketani
Posted: Thu Aug 21, 2008 10:11 pm Post subject: Voltage to the Coil should be? |
Hi guys,
When I have the key in ON position:
Voltage across the coil is 4.2 V
When I press key into START position and engine crank:
Voltage across coil is 3.4 V
However, the Spark Plugs don't seem to be firing. Any idea on what we can do?
| Back to top |
jondee86 Takumi
Posted: Fri Aug 22, 2008 11:36 am Post subject: |
With the key on, there should be battery voltage at the coil positive
terminal. This is measured between the coil terminal and chassis
(ground).
The coil resistance (measured with all wires disconnected) should
be about 0.5 Ohms on the primary side (+ve to -ve terminals) and
between 10-15 kOhms on the secondary side (+ve to high tension
terminals).
Cheers... jondee86
| Back to top |
F0Bman Takumi
Posted: Wed Aug 27, 2008 5:33 am Post subject: |
For the coil, please make sure that the grounds on the ignitor are clean and are connected to a clean ground.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
