| Author |
Message |
delazy Itsuki
1983 Toyota Corolla AE86 (early Levin)
Posted: Sun May 18, 2008 8:46 am Post subject: ANOTHER Australian AE86 |
BUILD PLANS
Engine:
AE101 20v (purchased)
TODA valve springs
TODA 288 degree cams 9mm lift
TODA adjustable cam gears
70mm Carbon Trumpets
Greddy Oil Cooler
Koyo Radiator
Samaco Radiator Hoses
Techno Pro Sprit Engine Mounts *lowers engine postition 10mm and pushes slightly further back*
Adaptronic ECU tuned by GTgarage
N2 Style 4-1 Extractors
Dart Izumi Exhaust or Trust DD Exhaust *both 1 hotdog muffler thru to twin tip*
10% overdrive pulley kit (purchased)
estimate power output - 100-110rwkw with 9,000rpm limiter....expensive power, but should be fun
Footwork:
Front Coilover - tokico hts102 & 8kg spring (purchased shocks)
Rear Shock + Spring - tokico hts102 & 6kg spring (purchased shocks)
Power Steering Knuckles (purchased)
AJPS 40mm RCAs (purchased)
Cusco Castor Rods
Cusco Camber Tops
AJPS Twin Adust Inners + RA40 Tie Rod Ends (purchased)
XT130 Lower Control Arms (purchased)
Nagaisa Auto Traction Brackets (purchased)
Adjustable 4 Link (ORDERED)
Rose jointed panhard rod (ORDERED)
Cusco front and rear sway bars
T18 Series II T Series Diff (purchased)
Cusco 1.5way LSD
4.6 C & P (purchased)
JDM T50 Bellhousing (purchased)
JDM Shifter *blinged up rob/seamus glitter style* (purchased)
BRAKES
Front
FC3S front caliper (purchased)
QFM A1RM Brake Pads (purchased)
AJPS Caliper Adapter (purchased - BUT FOR SALE)
rx7/mini cooper Caliper Adaptor (purchased)
Mini Cooper S 276mm Rotors
Braided Lines
mitsibishi triton master cylinder *LOL* (purchased)
Rear
2 x fc3s rear caliper (purchased)
QFM A1RM Brake Pads - footbrake
URAS D1 Spec Pads - handbrake
DELAZY INDUSTRIES caliper adaptor plates
unknown 258mm rotors
braided lines
hydrolic handbrake
Interior
Black JDM Dash
2x Bride Zeta Sports
Nardi Deep Corn Steering Wheel (purchased)
T3 JTC STYLE Gearknob (purchased)
T3 Drift Button (purchased)
2x Black HPI 4 Point FIA Harnesses
Alloy Floor Plates (purchased)
Carbing Footrest (purchased)
Carbon door panels
J-Blood carbon door sills
Surge tank mounted in spare wheel well *to be decided*
Bracing:
Cams Half Cage with side intrusion bars
Cusco Tension Rod brace (purchased)
Nagaisa Auto Shakkaito Plates (purchased)
Cusco OS Strut Brace (purchased)
T3 tri brace *adds onto cusco strut brace and braces against firewall* (purchased)
Ultra Racing Fender Braces (purchased)
Ultra Racing 4 Link Mid Brace (purchased)
Ultra Racing 2 Point Lower Brace (purchased)
Exterior:
Custom Order Black Work Meister 15x8.5-17 & 9" -29 *bring on tax time*(NEARLY THAT TIME)
4 x Bridgestone Potenza Adrenilin RE001 195/50/15
2 x Bridgestone Potenza RE01 195/50/15 *dreams*
Midnight Purple Paint *inside and out*
Runfree type II full kit (purchased)
JDM Zenki whiteline tail-lights (purchased)
JDM Kouki foglights (purchased)
FC3S Aero Mirrors (purchased)
Skid Rims:
2 x 15 x 8.5-7 SSR MK-2's (purchased)
will update list as things are added and as things are purchased......
| Back to top |
Jan Pedersen Moderator
Joined: 07 Sep 2004 Posts: 1149 Location: Herning, Denmark
Posted: Sun May 18, 2008 9:38 am Post subject: |
Welcome! Nice looking car and very nice spec list
_________________ Sarcasme is just one of the things I offer
| Back to top |
delazy Itsuki
Posted: Mon May 19, 2008 5:08 am Post subject: |
possibly a new update...
in talks with the owner of a 5ag bottom end atm....
consisting of ae111 rods (shotpeen'd and balanced), HKS 5ag crank, ca18det pistons and fresh 7 rib block
also included in the deal is a bigport head that was built by rs-yasu featuring 254/262 cams, cam gears and valve springs aswell as a rather heavy port and polish
currently talking to a few engine builders over possible options and will highly likely buy this package within a couple weeks
| Back to top |
F0Bman Takumi
Posted: Thu May 29, 2008 5:54 am Post subject: |
NUTS!
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
delazy Itsuki
Posted: Sat Aug 16, 2008 1:31 pm Post subject: |
| Back to top |
delazy Itsuki
Posted: Sat Aug 16, 2008 2:13 pm Post subject: |
deal on the 5ag gear fell thru
so just buying a 20v and seeing wat pops up in the meantime, been eyeing off a few 5ag crank lately, so might jump on one of those sometime soon
| Back to top |
megahopi Itsuki
Joined: 26 Nov 2007 Posts: 21 Location: Co. Down, Ireland
1987 Toyota Corolla AE86 (late JDM Levin)
Posted: Sat Aug 16, 2008 2:46 pm Post subject: |
nice car mate
did you remove the front bumper lights?
_________________ Do you ever notice that when you're driving, anyone going slower than you is an idiot and everyone driving faster than you is a maniac?
| Back to top |
delazy Itsuki
Posted: Sat Aug 16, 2008 6:05 pm Post subject: |
yea, front bumper was only just fitted 20mins before the pics....cbf'd putting them back in
| Back to top |
Mad Max Wataru
| Back to top |
delazy Itsuki
Posted: Fri Sep 12, 2008 3:42 pm Post subject: |
| Back to top |
