BIG BRAKE Kit 4 Pistons Brembo
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Buy / Wanted
Author Message
seb
Wataru
PostPosted: Wed Jul 16, 2008 9:18 pm    Post subject: BIG BRAKE Kit 4 Pistons Brembo Reply with quote
Big Brake Kit for AE86
AE86 : Buy / Wanted > BIG BRAKE Kit 4 Pistons Brembo
Caliper Brembo: 390€ niew delivered (or available on ebay)
or 440€ with pads
Support Caliper in aluminium 7475: 150€ delivered
Use disc Mini cooper S 276 X 22 (approximately 90€ for 2. Available in all the stores of spare parts of your area.)
ref 09.8655.10
or ref Max:09.8655.75
It is necessary to pierce the disc in 4 X 87
To use these discs it is necessary to thin the caliper of 6 mm
3 mm by side of the caliper.
With a machining on the end of the caliper, the assembly is compatible with rims of 14 '
Un autre point ou il faut également faire attention.
C'est le choix de la jante ou le déport
Lorsque que l'on passe de 1 à 4 pistons nous utilisons plus de volume dans le logement de la jante
Nous utilisons un disque mi au même emplacement que l'origine,
donc le problème va être le suivant.
Si le montage des supports et des étriers est bolt on l'adaptation de la jante est au cas par cas (c'est valable pour n'importe quel étrier 4 pistons).
_________________
my 86: http://www.aeu86.org/viewtopic/ae-86-from-belgi.../highlight=#46541
Back to top
View user's profile Send private message Visit poster's website
Menti
Wataru
PostPosted: Thu Jul 17, 2008 12:13 am    Post subject: Reply with quote
I am lost ... you are looking for a kit like that or do you actually sell this kit ?
From what car are these calipers and where can i get those adapters ?
_________________
4AGE yeaaaah, i have adjustable Cam Gears and i`m pushing 76.3 rwhp on the dyno !
Back to top
cavey
Takumi
PostPosted: Thu Jul 17, 2008 9:59 am    Post subject: Reply with quote
Seb is actually making those adapters, and the Brembo's can be bought of the shelf, or through Seb, or through Ebay... various options. I guess this thread needs to be moved to the "Sell" section Very Happy
Back to top
seb
Wataru
PostPosted: Thu Jul 17, 2008 11:02 am    Post subject: Reply with quote
Yes I have to create the kit to adapt caliper Brembo 4 pistons of Peugeot 406 V6
I can provide new caliper or there is average to find them on the Web.
_________________
Back to top
troupier
Itsuki
1985 Toyota Corolla AE86 (late EU)
PostPosted: Thu Jul 17, 2008 11:06 am    Post subject: Reply with quote
It's 406 V6 brembo calipers. You can have it from Ebay but Seb can have new ones for a better price Wink
_________________
French new owner of a 85 black coupe :]
Back to top
seb
Wataru
PostPosted: Thu Jul 17, 2008 7:26 pm    Post subject: Reply with quote
_________________
Back to top
Xaerob
Iketani
PostPosted: Fri Jul 18, 2008 8:56 am    Post subject: Reply with quote
are you providing a full kit here with calipers (modified to fit 14s), discs and pads, as if so I'd be interested.
Don't want to mess around machining calipers and finding discs etc myself. Cheerleader
Back to top
seb
Wataru
PostPosted: Fri Jul 18, 2008 9:34 am    Post subject: Reply with quote
Yes I can provide a machined complete kit.
But it will be necessary to add fry them machining approximately 40€ and the forwarding of totalitée in the U.K.
_________________
Back to top
robokill
Bunta
PostPosted: Fri Jul 18, 2008 11:44 am    Post subject: Reply with quote
seb ,
lovely kit. What would be the full price of a full kit
calipers + brackets? (i can manage the discs at a local shop myselve (mini cooper S right?))
_________________
"08 Honda Civic Hybrid
KIS it
Keep It Sideways
Back to top
seb
Wataru
PostPosted: Fri Jul 18, 2008 11:53 am    Post subject: Reply with quote
Thank's Smile
Calipers + Brackets: 540€ delivered (and 600€ delivered modified)
It takes 2 weeks to order the calipers
There remain to me 1 kit of brackets of stock
Yes the disc is mini cooper S
_________________
Back to top
The Big Yin
Takumi
1984 Toyota Corolla AE86 (early JDM Trueno)
PostPosted: Mon Jul 28, 2008 10:51 pm    Post subject: Reply with quote
so these will fit under a 14" alloy?
_________________
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
Back to top
seb
Wataru
PostPosted: Thu Jul 31, 2008 2:20 pm    Post subject: Reply with quote
Yes with a small modification on the end of the caliper.
_________________
Back to top
seb
Wataru
PostPosted: Sat Aug 16, 2008 7:34 am    Post subject: Reply with quote
up Cheerleader
_________________
Back to top
tolisspi
Takumi
PostPosted: Sat Aug 16, 2008 8:09 am    Post subject: Reply with quote
Can you help me about calipers + brackets for AE82? Are the fronts brakes differents than AE86?
Im interesting about a complete brake kit.
Thanks a lot...
_________________
**COROLLA EE80 - 4AGE 124HP**
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Buy / Wanted All times are GMT + 2 Hours
Page 1 of 1
Jump to:
