| Author |
Message |
seb Wataru
Posted: Wed Jul 16, 2008 9:18 pm Post subject: BIG BRAKE Kit 4 Pistons Brembo |
Big Brake Kit for AE86
Caliper Brembo: 390€ niew delivered (or available on ebay)
or 440€ with pads
Support Caliper in aluminium 7475: 150€ delivered
Use disc Mini cooper S 276 X 22 (approximately 90€ for 2. Available in all the stores of spare parts of your area.)
ref 09.8655.10
or ref Max:09.8655.75
It is necessary to pierce the disc in 4 X 87
To use these discs it is necessary to thin the caliper of 6 mm
3 mm by side of the caliper.
With a machining on the end of the caliper, the assembly is compatible with rims of 14 '
Un autre point ou il faut également faire attention.
C'est le choix de la jante ou le déport
Lorsque que l'on passe de 1 à 4 pistons nous utilisons plus de volume dans le logement de la jante
Nous utilisons un disque mi au même emplacement que l'origine,
donc le problème va être le suivant.
Si le montage des supports et des étriers est bolt on l'adaptation de la jante est au cas par cas (c'est valable pour n'importe quel étrier 4 pistons).
_________________
my 86: http://www.aeu86.org/viewtopic/ae-86-from-belgi.../highlight=#46541
| Back to top |
Menti Wataru
Posted: Thu Jul 17, 2008 12:13 am Post subject: |
I am lost ... you are looking for a kit like that or do you actually sell this kit ?
From what car are these calipers and where can i get those adapters ?
_________________ 4AGE yeaaaah, i have adjustable Cam Gears and i`m pushing 76.3 rwhp on the dyno !
| Back to top |
cavey Takumi
Joined: 07 Dec 2007 Posts: 324 Location: Arnemuiden, Netherlands
Posted: Thu Jul 17, 2008 9:59 am Post subject: |
Seb is actually making those adapters, and the Brembo's can be bought of the shelf, or through Seb, or through Ebay... various options. I guess this thread needs to be moved to the "Sell" section
| Back to top |
seb Wataru
| Back to top |
troupier Iketani
Joined: 27 Nov 2006 Posts: 27 Location: Vosges, France
1985 Toyota Corolla AE86 (late EU)
Posted: Thu Jul 17, 2008 11:06 am Post subject: |
It's 406 V6 brembo calipers. You can have it from Ebay but Seb can have new ones for a better price
_________________ French new owner of a 85 black coupe :]
| Back to top |
seb Wataru
| Back to top |
Xaerob Iketani
Joined: 29 Jan 2008 Posts: 37 Location: Portsmouth, UK
Posted: Fri Jul 18, 2008 8:56 am Post subject: |
are you providing a full kit here with calipers (modified to fit 14s), discs and pads, as if so I'd be interested.
Don't want to mess around machining calipers and finding discs etc myself.
| Back to top |
seb Wataru
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2249 Location: Amsterdam // The Netherlands
Posted: Fri Jul 18, 2008 11:44 am Post subject: |
seb ,
lovely kit. What would be the full price of a full kit
calipers + brackets? (i can manage the discs at a local shop myselve (mini cooper S right?))
_________________ "08 Honda Civic Hybrid
KIS it
Keep It Sideways
| Back to top |
seb Wataru
| Back to top |
The Big Yin Takumi
Joined: 04 Nov 2005 Posts: 413 Location: Falkirk, Scotland
1984 Toyota Corolla AE86 (early JDM Trueno)
Posted: Mon Jul 28, 2008 10:51 pm Post subject: |
so these will fit under a 14" alloy?
_________________
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
| Back to top |
seb Wataru
| Back to top |
seb Wataru
| Back to top |
tolisspi Takumi
Joined: 24 Jan 2008 Posts: 384 Location: Greece-Korinthos
Posted: Sat Aug 16, 2008 8:09 am Post subject: |
Can you help me about calipers + brackets for AE82? Are the fronts brakes differents than AE86?
Im interesting about a complete brake kit.
Thanks a lot...
_________________ **COROLLA EE80 - 4AGE 124HP**
| Back to top |
