Goto page Previous  1, 2, 3 ... 16, 17, 18
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Projects
Author Message
apardal
Takumi
PostPosted: Thu Jul 03, 2008 7:09 pm    Post subject: Reply with quote
alimonos, I do not have the installation card. I followed the recommendations that can be read in the club4ag's tech reference. Max lift for both is at 100 degrees.
I was able to put the exhaust camshaft at 100 degrees, no sweat. I installed this camshaft as the Toyota manual recommends and I measured max lift at 110 degrees. Then I rotated the cam gears until I got 100.
The intake was not that easy. For some reason, the measurement didn't work the same way for the intake side. If I install it as the Toyota manual says, I'll read 120 degrees when I think I should read 110.
Miguel, I've already ran the engine with these camshafts and stock intake manifold and although the pinging almost disappeared, the performance is worse. That is, I think, because what I've said earlier that the engine needs more air and the restrictions from the stock manifold are too much. Air gets hotter and the engine needs to spend more energy sucking air.
Thank you for your comments
Best regards
Back to top
robokill
Bunta
PostPosted: Thu Jul 03, 2008 7:37 pm    Post subject: Reply with quote
hey apardal the power readings are they on the crank or on the wheels ?
_________________
"08 Honda Civic Hybrid
KIS it
Keep It Sideways
Back to top
apardal
Takumi
PostPosted: Fri Jul 04, 2008 1:27 am    Post subject: Reply with quote
robokill, it is power at the crank. It would be a little far fetched to have that kind of power to the wheels with my setup!!
Anyways, that dyno usually "gives" power that the engines don't have...
Between 150 and 155 at the crank might be a little more realistic.
Best regards
Back to top
apardal
Takumi
PostPosted: Mon Jul 07, 2008 12:59 am    Post subject: Corolla Levin Repair, Paint and Tune - WITH ITB's Reply with quote
After many hours around the engine, here are this weekend's pics and VIDEO.
First two photos: test fitting
AE86 : Projects > Corolla Levin Repair Paint and Tune  WITH VIDEO
After first run.
VIDEO! Very Happy
YouTube - apardal AE86 - 2
Best regards
Back to top
JonnyAE86
Bunta
PostPosted: Mon Jul 07, 2008 1:58 am    Post subject: Reply with quote
Cant wait for the new dyno Thumbsup
_________________
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
cavey
Takumi
PostPosted: Tue Jul 08, 2008 12:09 am    Post subject: Reply with quote
you still have the plastic fan connected to the engine?
Back to top
apardal
Takumi
PostPosted: Tue Jul 08, 2008 12:11 am    Post subject: Reply with quote
Yes I do... unfortunately...
Back to top
apardal
Takumi
PostPosted: Wed Jul 16, 2008 5:18 pm    Post subject: Reply with quote
Some more work done.
Closed the throttle a little to lower the idle, installed the pipercross air filter and 40mm trumpets.
Best regards
Back to top
cavey
Takumi
PostPosted: Wed Jul 16, 2008 11:37 pm    Post subject: Reply with quote
nice one!
Back to top
robokill
Bunta
PostPosted: Thu Jul 17, 2008 1:10 am    Post subject: Reply with quote
apardal. was you head worked? Or anything done to it?
Are you running an MS now or still standard ECU with a 16V tps sensor?
and where did you get that nice vacuum container
_________________
KIS it
Keep It Sideways
Back to top
apardal
Takumi
PostPosted: Thu Jul 17, 2008 2:24 am    Post subject: Reply with quote
robokill, head is worked indeed, and I'm running MS and silvertop itb's with 16v TPS sensor, check previous posts.
The vacuum tank was bought at ebay.
Best regards
Back to top
gon
Ryousuke
PostPosted: Thu Jul 17, 2008 12:16 pm    Post subject: Reply with quote
the 16v tps had to "worked" to be usable in all the range of the accelerator ...
i don't think he has pictures of it though ...
Back to top
apardal
Takumi
PostPosted: Tue Aug 05, 2008 12:13 pm    Post subject: Corolla Levin Repair, Paint and Tune - Track Day Videos Reply with quote
Hi!
Went to Estoril Racetrack this weekend.
Link
Link
Back to top
rooty
Iketani
PostPosted: Tue Aug 05, 2008 7:27 pm    Post subject: Reply with quote
Hey mate, which pipercross filter is it? PX500 or PX600? Do you know if it will fit on 4AGE 20V ITBs?
cheers
_________________
TOYOTATECH.pl
Back to top
apardal
Takumi
PostPosted: Tue Aug 05, 2008 9:38 pm    Post subject: Reply with quote
It is a PX600 with a blank base plate so I had to drill the holes in it...
Back to top
rooty
Iketani
PostPosted: Tue Aug 05, 2008 11:38 pm    Post subject: Reply with quote
Thanks! Cheerleader
_________________
TOYOTATECH.pl
Back to top
apardal
Takumi
PostPosted: Wed Aug 06, 2008 12:33 am    Post subject: Reply with quote
Another video
Link
Back to top
rooty
Iketani
PostPosted: Wed Aug 06, 2008 2:14 pm    Post subject: Reply with quote
quick question mate, do you have any dyno data after installing open ITB's with that filter?
cheers
_________________
TOYOTATECH.pl
Back to top
apardal
Takumi
PostPosted: Wed Aug 06, 2008 3:06 pm    Post subject: Reply with quote
Nope. Might have something soon...
Back to top
harkes
Iketani
1986 Toyota Corolla AE86 (late JDM Levin)
PostPosted: Sat Sep 06, 2008 10:17 am    Post subject: Reply with quote
OMG that is a lot of transmission noise? Gearbox or diff?
What kind of brake setup are you running? Problems with fading?
Back to top
roco
Wataru
PostPosted: Sat Sep 06, 2008 12:04 pm    Post subject: Reply with quote
just read this whole thread from start to finnish, fair play dude, that is a serious resoration work, alot of work has gone in, beautiful car, well wear.. Thumbsup
_________________
Back to top
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Skype Name
apardal
Takumi
PostPosted: Sun Sep 07, 2008 11:43 pm    Post subject: Reply with quote
harkes, the noise comes from the diff. It is now disassembled and i'm trying to figure out what i'm gonna do with it.
I'm running front brembo rotors with ferodo ds2500 pads, stock rear rotors with pagid fastroad pads, goodridge brake lines and Ferodo Dot 5.1 brake fluid. All calipers and brake master cylinder were rebuilt. No fade at all.
Thanks roco!
Back to top
Emanuelae86
Iketani
PostPosted: Mon Sep 08, 2008 12:20 am    Post subject: Reply with quote
Stupid very good
Back to top
View user's profile Send private message Send e-mail MSN Messenger
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Projects All times are GMT + 2 Hours
Page 18 of 18
Jump to:
You cannot attach files in this forum
