| Author |
Message |
roubi33 Itsuki
Posted: Thu Jul 03, 2008 6:20 am Post subject: NEEED A LOT OF HELP & WORK ! |
OK soo i just got a 1986 corolla single cam ,,, its reeeeal rusty, im talking all around,,, should i keep it or fix it up, then my rims are loose i know ,,wtf,,, the guy i bought it from put some washers on the lugnuts soo im kinda scerd to drive it at higher speeds cause they sound like they r gonna fall off... what kind of rims should i buy ??? then my breaks feel kinda flimzy i have to almost push them to the floor to stop ,,, or do i just need a brake change? and this is the big killer,,, the previous owner conected the batery ...the wrong way switched the - & + so now only things working are my hazard lights, horn headlights and thats it,,, wtf happened? fuses got blown but is that the only thing??? the car is completly dead, only if you push start it it runs but brake lights tale lights RPM speed nothing works !!!! soo i need some help ASAP soo thanks for reading this long ass ,,, thing
| Back to top |
Mad Max Wataru
1987 Toyota Corolla AE86 (late JDM Levin)
Posted: Thu Jul 03, 2008 6:02 pm Post subject: |
Hello,
Could you please use some punctuations and write a little bit more understandable because it's really hard to read your reply.
To answer some questions :
-Put a twin cam in it and weld it up. How much rust does it have?
Maybe open a project here and show us some pics.
-If you are scared that your rims are gonna fall off ,why don't you tighten the lugnuts. Why did he put washers on the lugnuts.
My advice is : don't drive it until this problem is fixed or you're gonna end up losing a wheel(s) and put other people and yourself in danger.
-braking problem: change the brake fluid ,new brake pads and normally the problem is solved.
-With the electrical problem i can't help you. I don't have a lot of knowledge about this.
_________________ My garage:
http://www.aeu86.org/garage/1987-toyota-corolla...w_vehicle/CID=197
| Back to top |
roubi33 Itsuki
Posted: Sat Jul 05, 2008 1:43 am Post subject: |
hey thanks for the tips !
so about the rust , i think i would need to almost rebuild the whole body because theres literaly chunks of rusted metal falling off
The electrical is fine, it was only a fuse....
And the rims , i did tighten them but i still dont feel safe,,,, about the washers i have no idea why he put those on.
The pics i will work on probably next week to give you some idea of what kind of state the car is in
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sat Jul 05, 2008 9:51 am Post subject: |
We've seen rusty hachis getting fixed up comletely, so let's see how bad it is.
Does it have the correct lugnuts then?
| Back to top |
roubi33 Itsuki
Posted: Mon Jul 07, 2008 9:09 pm Post subject: |
hm i dont think it does... i want to go to a mechanic to get it checked out, and another thing just poped up my idle is way too high, when im in neutral the engine runs on 2000 rpms, and when i want to turn the engine of after i turn the key its stalling, jumping chocking not turning off for a while,,, i been told to spray some WD40 on the choke,,,, i dont think thats gonna solve it or is it? and if not how do i set the idle so its normal?????
| Back to top |
Mad Max Wataru
| Back to top |
Mux213 Site Admin
Posted: Mon Jul 07, 2008 11:25 pm Post subject: |
| Mad Max wrote: | | 2000rpms is not a problem. When i start my hachi it has the 2000rpm for about 4 min and when the engine is warmed up it goes to 1100/1300. |
Yeah but you have a twincam with EFI. That one has a high RPM when its still cold to warm up the engine faster. Once warm the idle should drop.
With the 8v it's carbed and doesn't have this nifty feature asfar as I'm aware off. Sounds more like a badly setup carb. There is a good chance that if you have a mechanic look at the carb setup he can adjust it properly. The question then is. Did the previous owner set it up like this cause he didn't know what he was doing, or to 'hide' problems with the car running at a normal idle.
Try putting your wheels on without the washers. He probably put those on to get a nicer offset on the wheels or because he has a completely wrong offset set of wheels and they will hit the body work somewhere. You have a good chance though that the washers are just there for show.
Change the brake fluids and brake pads. Its an easy fix, just use DOT 4 or something, I'm sure you're not out racing your car. Make sure you check if you're rotors still look good. If they are groved you better replace them too, but thats a tad bit expensive.
As for the body work, post up some pics. Rust is a problem with these cars. A full rebuild to bring her back to life is a good idea seeing the worth of these cars these days, but if you have a shop doing that it could really add up to a large bill. If you have friends who can weld and do body work it will be worth fixing her up most likely.
_________________ Greetz,
No more hachi
| Back to top |
Mad Max Wataru
Posted: Mon Jul 07, 2008 11:50 pm Post subject: |
| Mux213 wrote: | | Mad Max wrote: | | 2000rpms is not a problem. When i start my hachi it has the 2000rpm for about 4 min and when the engine is warmed up it goes to 1100/1300. |
Ha,I didn't knew that ,learned something new today.
| Back to top |
roubi33 Itsuki
Posted: Wed Jul 09, 2008 12:20 am Post subject: |
the carb i will get checked out at the mechanic then. The washers are actually on the lugnuts, an when i tried to drive with the washers off,,,, its a suicide... wheels are all over the place steering is almost impossible and its loud, the car has stock rims, should i just have that chcecked out at the mechanic? so he can tighten them up or possibly even put on maybe proper set of lugnuts?
| Back to top |
Mux213 Site Admin
Posted: Wed Jul 09, 2008 1:08 am Post subject: |
Thats just really strange.... Sounds like the lugnuts are the wrong ones.. If they are properly tightened, the wheels should not be unstable. If the wheel can still move inward/outward after the lugnuts are on, something is really wrong.
No more hachi
| Back to top |
Allexz Takumi
Posted: Wed Jul 09, 2008 9:46 am Post subject: |
if the wheel is unstable look for rust in the centrum ring where u put the wheel oon.. im not so good in english mechanical words so look for rust and be sure u put the wheel all in.
_________________ Donīt Think About The Past,
Live In The Present And
Dream About Tomorrow
| Back to top |
roubi33 Itsuki
Posted: Mon Jul 14, 2008 9:53 pm Post subject: |
hey guys thank you soo much for all the help but the corolla is probably going to end up at the junkyard this week last saturday the whole thing droped, gearbox, differential, the mehanic said the car is no good, and i shouldnt even drive it, so im probably going to junk it whyyyyyyyyyyyyy
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Tue Jul 15, 2008 12:45 pm Post subject: |
Auch!
Better save up money and get a solid one...
Perhaps you can pull it apart and sell some of the parts which are still in good condition, the interior or lights for instance.
| Back to top |
cavey Takumi
Joined: 07 Dec 2007 Posts: 317 Location: Arnemuiden, Netherlands
Posted: Tue Jul 15, 2008 1:48 pm Post subject: |
indeed, as banpei says, break it up into its components, and sell of the good bits Make cash before sending it to the junkyard
(hey, maybe the bootlid, hood, interior stuff is all in good shape, tons of people here will be happy with it. Just don't let Alimonos ask for shipping and handling to greece )
| Back to top |
sergiocharged Wataru
Posted: Tue Jul 15, 2008 6:47 pm Post subject: im fixinmine too |
put some photos like i ll do
| Back to top |
roubi33 Itsuki
Posted: Tue Jul 15, 2008 7:22 pm Post subject: |
haha ok ill remeber that about the greek guy but yea thats a good idea abou selling the parts, well what ever is still good. I just cant believe im stuck with my 94 camaro again i hate it, piece of crap automatic ! I reeeally wanted a nissan 240sx at first but the corolla came up for cheap so i got it. So now im probably going to start to chase after the 240 again. Anyway i still have it its sitting in front of the house so yes i know its about tiime i made those pictures !
| Back to top |
F0Bman Takumi
Posted: Thu Jul 17, 2008 1:39 am Post subject: |
I think getting the car mechanically sound should be priority. Then all the other things should follow suit.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
roubi33 Itsuki
Posted: Thu Jul 24, 2008 8:57 pm Post subject: |
ok so tomorrow im going to get some pics, i have been kind of busy altely so im putting my camaro up for sale and i was thinking of using the money from that salefor possibly giving the corolla one more chance to come back to life. Two days ago i came home late around 2am and i pulled right up front to the corolla, and i just tought to myself that damn this car is sooo hot and its a shame it ended up like this so my friends are about to come down here and help me out. i would LOVE to get the twincam for it, fix up all of the mechanical components as well as the body and maybe even get it do live up to its legendary drifting skillz so what do you guys think
| Back to top |
