| Author |
Message |
Conrad Ryousuke
Posted: Wed Feb 27, 2008 10:53 pm Post subject: |
Well, a little more progress before the car dissapears off to the fabricators.
Front bumper removed, rear bumper removed, aircon removed, sideskirts removed, and the remainder of the interior trim & roof lining removed
Made a start on the dashboard but didnt get very far
Car is going to the Fabricators on Monday on the truck so the guys are down there are going to finish the strip down for me
Looking forward to some progress in the next few weeks...
_________________ I'm currently taking HRT ~ Hachi Roku Therapy
| Back to top |
Miguel - Newera Ryousuke
Joined: 22 Aug 2005 Posts: 189 Location: Tokyo, Japan!
1985 Toyota Corolla AE86 (late JDM Levin)
Posted: Tue Mar 04, 2008 2:29 pm Post subject: |
Looks good, Conrad!
Looking forward to watching this AE86 take shape. It's great to see another one being built with the intentions these cars deserve
_________________ VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
| Back to top |
Conrad Ryousuke
Posted: Tue Mar 04, 2008 2:53 pm Post subject: |
Thanks Miguel, just keep that AE86 parts catalogue away from me, your killing my wallet
| Back to top |
Conrad Ryousuke
Posted: Tue Mar 18, 2008 9:19 pm Post subject: |
Well the project is well & truly under way now;
The car has arrived at the fabricators and fabrication has commenced.
More updates coming soon
| Back to top |
Conrad Ryousuke
Posted: Sat Apr 26, 2008 12:32 am Post subject: |
Finally some progress.....
Front end all stripped out.
Windscreen removed but unfortunately it got broken
Dashboard, steering column, heater box, pedal assembly and all the front end items removed from the cabin....
Time to prepare the front end for strengthening, seam sealer removed & the area is prepped ready for the stitch welding
| Back to top |
Conrad Ryousuke
Posted: Sat Apr 26, 2008 12:40 am Post subject: |
Next up.....
the cross member gets a little modification to create more room for the F20C sump. Cut, plated and strengthened.
Off it goes for powder coating to get that new look again
| Back to top |
style86 Itsuki
Posted: Sun Apr 27, 2008 7:46 am Post subject: |
How much does it cost for the cross member? It looks like a very well built piece.
| Back to top |
Apolan Bunta
Joined: 27 Nov 2004 Posts: 1851 Location: Slovenia, Ljubljana
Posted: Sun Apr 27, 2008 11:49 am Post subject: |
hm, this is a common solution for the f20c swap, but is it strong enough?
_________________ There are no good decisions or bad decisions - only deciding or running away.
-me, 2007
| Back to top |
Conrad Ryousuke
Posted: Sun Apr 27, 2008 6:51 pm Post subject: |
The cross member is better built now than it was from the factory Much stronger
| Back to top |
Conrad Ryousuke
Posted: Sat May 10, 2008 1:01 am Post subject: |
Ok here we go, some pictures of the progress from RS....
Stitch welding of all the front seams for a little bit of added strength.
Next up.. the boot floor recieves a bit of attention..... and gets removed!
Nice & flat now ready for an aluminium bag tank
Next up... tailgate starting to get stripped out prior to removal.
No rust on this one....
Hopefully the cage install will be next
| Back to top |
Posted: Wed May 14, 2008 5:21 am Post subject: |
Looking good & getting more interesting all the time! Keep us posted Conrad!
A Tuner's Paradise
| Back to top |
Square
Posted: Wed May 14, 2008 6:43 am Post subject: |
I am actually in the midst of the same project on a left hand drive version.
I am doing most of the work along with a friend of mine who will do all the welding.
My car will be my daily driver so I am not going as hardcore as you or some of the people who do these swaps are. (I'm pretty young and poor too).
My subframe is already welded and good to go, I am making some 1cm spacers because my cusco mounts are smaller than the stock ones and I am using the JSP mounting kit which was designed for the stock mounts.
I am not lowering the subframe though.
I have cut the tranny tunnel and dropped the engine in for a test fit, everything looks like it will work, but I'll be 100% sure once I have those spacers made and in.
Next thing on my list is to take the motor back out and remove the seam sealer so I can stitch weld the engine bay and paint it black.
How did you removed the seam sealer???
I think I'll make a thread like this once I am done showing my progress.
| Back to top |
Conrad Ryousuke
Posted: Wed May 14, 2008 9:28 am Post subject: |
Square, the seam sealer is removed using a drill and a wire wheel, that gets most of it out then its a case of using a sharp pointed object to get in the nook & cranny's. You'll know if there is still some there as it wont weld
Miguel, thanks
| Back to top |
Conrad Ryousuke
Posted: Tue May 20, 2008 10:28 am Post subject: |
Well, a few goodies have started to arrive
Equal Length 4 link bars.
Tow Hook.
Bottom Arms.
Adjustable Top Mount Camber Plates.
Top Hat Spacers.
[/img]
| Back to top |
projectrollas Wataru
Joined: 25 May 2007 Posts: 105 Location: othersideoftheworld
Posted: Tue May 20, 2008 9:45 pm Post subject: |
looks good man.
i used a turbo torch (acetelyn only) to remove sealer, it got it soft enough to srap w/spatula/scraper.
_________________ te72 wagon
ae86 levin coupe project
| Back to top |
Conrad Ryousuke
Posted: Mon Jun 09, 2008 9:03 pm Post subject: |
A little more progress in that more stuff has arrived for the build. Not much happening at the fabricators until they get Ian G corolla finished & out.
Anyway, heres the latest items....
ECU to keep everything under control
Traction Arms... courtesy of T3
Hopefully, some fabrication will start soooooooooon......
Oh, and I have just had word from the man in Japan (Miguel) that my new wheels, front grille & redlines have just been shipped . ETA 6 weeks
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2211 Location: Amsterdam // The Netherlands
| Back to top |
The Doctor Bunta
Joined: 18 Sep 2004 Posts: 2225 Location: Goirle, The Netherlands
Posted: Tue Jun 10, 2008 12:25 am Post subject: |
| Conrad wrote: |
Oh, and I have just had word from the man in Japan (Miguel) that my new wheels, front grille & redlines have just been shipped . ETA 6 weeks  |
isn't it cool to get a notice that some niiiiiiiiice stuff is on its way?
I know that feeling
Great project!
_________________
| Back to top |
Conrad Ryousuke
Posted: Tue Jun 10, 2008 3:45 pm Post subject: |
Yup..... its like being a kid at Christmas all over again
| Back to top |
Conrad Ryousuke
Posted: Tue Jun 24, 2008 12:09 am Post subject: |
News from the fabricators.......
the seam welding is complete, the original tunnel has been removed and the new one is in place, although not complete. The pads for the roll cage to sit on are now installed so hopefully next week should see the cage install begin
Heres a few progress shots
| Back to top |
Posted: Tue Jun 24, 2008 2:10 am Post subject: |
Looking good, Conrad!
I suppose they have to keep it outside for space reasons ATM, but shame to see the bare metal being allowed to corode like that (I know it's only surface rust). Maybe a car cover could be secured over it to protect against the weather?
They need to also drill out the chassis plate and remove the door trims, but I'm sure they'll be getting around to that anyways. Good stuff anyways - Looking forward to seeing it take shape from here!
A Tuner's Paradise
| Back to top |
eight6rolla
Posted: Tue Jun 24, 2008 5:51 am Post subject: |
_________________ 7)-730E
| Back to top |
Conrad Ryousuke
Posted: Tue Jun 24, 2008 10:14 am Post subject: |
| Miguel - Newera wrote: | Looking good, Conrad!
They need to also drill out the chassis plate and remove the door trims, but I'm sure they'll be getting around to that anyways. Good stuff anyways - Looking forward to seeing it take shape from here!  |
Miguel, care to expand on drilling out the chassis plate? Whats the options on the door trims?
As for leaving it outside I think its a space thing but your right, it should at least be covered up!
| Back to top |
Posted: Mon Jun 30, 2008 6:58 pm Post subject: |
Just drilling out the 2 pop rivets will get the chassis plate off - Make sure you keep it safe, though - as you can't get an original replacement..
To avoid damage from moisture, rain, etc. those door trims should come off. Need a Phillips & flat head screw driver plus a clip removal tool, to prize the plastic clips off - this will avoid damaging the compressed cardboard behind the PVC trim. Keep all the original parts in freezer bags with labels, somewhere safe where they won't get lost, trodden on, etc.
Would recommend re-trimming the door cards in some nice material. We can supply Bride Mesh (Which looks like carbon mesh) inexpensively for example - which looks excellent. Or you can go silly and get carbon door trims, carbon rear quarter trims, full carbon dashboard, carbon sill trims, carbon wind deflectors, etc. but I wouldn't recommend too much of that stuff.... It'll rattle & squeak!
A Tuner's Paradise
| Back to top |
20vPETE Ryousuke
Joined: 20 Dec 2006 Posts: 136 Location: NSW,Australia
Posted: Tue Jul 01, 2008 10:37 am Post subject: |
how much is the bride mesh miguel.got a pic
_________________ if first u dont succeed,ur not trying hard enough
| Back to top |
