| Author |
Message |
Sanity Clause Wataru
Joined: 14 Mar 2005 Posts: 58 Location: Addlestone, Surrey, UK
Posted: Tue May 13, 2008 10:29 am Post subject: Aircon recharge - which gas, R12 or R134a? |
I've just got a JDM Levin on the road, which appears to need the aircon regassing.
I don't know which gas is in there, but presume it to be the original R12 (Freon based) variety, which is not legal in the UK any more.
However, I have been told about a place near me who'll sort it.
I think it'd be a good idea to replace it with the later R134a type gas, if possible.
From what I've read here http://www.airconditioningforcars.co.uk/ACpage15.htm there's a good chance that the R143a will be OK.
Does anyone know if the AE86 compressor copes OK?
_________________ www.AE86imports.0catch.com
| Back to top |
Gtsi-R Takumi
Joined: 21 Jan 2008 Posts: 371 Location: Nijmegen, Netherlands
Posted: Tue May 13, 2008 12:06 pm Post subject: |
the gasses are NOT exchangeable..
due to different composition of material like rubbers etc.
that is for so far as I know.. so make sure witch type you have!!
| Back to top |
Posted: Tue May 13, 2008 12:21 pm Post subject: |
According to the link above, the original fears of incompatibility appear overdone, and many old aircon systems will work happily with the new R143a gas.
Is that so for the AE86?
| Back to top |
Gtsi-R Takumi
Posted: Tue May 13, 2008 3:16 pm Post subject: |
| Quote: | Some of the rubber hoses used on cars from the eighties or earlier are definitely a little leaky with the smaller molecule of R134a or the drop-in refrigerants so may cut down slightly on the length of time they are able to retain the charge.
Early cars sometimes have hoses which are not completely impervious to R134a, these can sometimes be changed but where it is not really possible the reality is frequently that the loss is fairly inconsequential anyway.
According to this... give it a shot...
| Back to top |
Posted: Tue May 13, 2008 8:42 pm Post subject: |
That's my thinking, too.
It'd be nice to know if anyone has any experiences they'd like to share.
| Back to top |
projectrollas Wataru
Joined: 25 May 2007 Posts: 105 Location: othersideoftheworld
Posted: Wed May 14, 2008 7:39 pm Post subject: |
have no fear my friend. it is ok to use the R134a w/your compressor.
i would recommend that you replace the rubber hoses that are compatible with R134a. and you will also need some adapters to be able to charge the system w/R134a. if you use R134a w/the hoses you have now, it will seep through in the long run.
its a shame R12 is gone, it blows allot colder than R134a.
_________________ te72 wagon
ae86 levin coupe project
| Back to top |
Posted: Wed May 14, 2008 9:48 pm Post subject: |
Thanks, that's good to know.
I read that the molecules of R134a are smaller than that of R12, and that's why they can seep through the hoses slightly quicker. I guess that's why aircon needs regassing every now and then.
Looking at the parts CD, the 2 hoses on this model were originally p/ns
88711-12341 (discharge hose)
88712-12590 (suction hose)
Presumably, these aren't exactly suitable for R134a, though.
I'll have to do some checking around some aircon places to see what can be supplied, if anything.
| Back to top |
Posted: Fri May 16, 2008 1:28 am Post subject: |
no problem. but yeah your right about the molecules. toyota should carry some kind of upgrade kit. gl on your search.
| Back to top |
F0Bman Takumi
Posted: Wed May 21, 2008 6:22 am Post subject: |
R12a
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
Posted: Wed May 21, 2008 5:02 pm Post subject: |
if you read, he need to recharge his system. R12 is not a choice since its not legal where he is at.
| Back to top |
Posted: Wed May 21, 2008 6:28 pm Post subject: |
R12a is the popular name for a hydrocarbon refrigerant blend made up of a mixture of propane and butane. These blends are highly flammible and you assume some risk by using them but they do work very well in most applications. Do your own research and perform a good risk assessment on your car first before using one.
Even if it's available, I think I'll pass on R12a, anyway.
| Back to top |
