| Author |
Message |
filh Takumi
Joined: 10 Oct 2004 Posts: 246 Location: Liège Belgique
Posted: Thu May 08, 2008 8:51 pm Post subject: broken Crankshaft |
Hello ,
A friend of mine broke his crankshaft on a 4AGE . He has a 3 ribs block , and small journals.
He was told that it was a common failure .....
It's a rally car , he doesn't want to have the same bad adventure .
Here's the question : will a big journals crankshaft fit his 3 ribs block .
He will have to change rods to fit journals , but will these big rods fit the forged pistons he have ? Or does he have to change pistons too?
Are the main crankshaft bearing same on both parts ?
and the last one : does somebody has the Toyota part number for the big crankshaft. He asked his local dealer , but he only have the EPC , are there are no measurment on crankshaft
Do you have any replacement suggestion HKS Toda or else ?
I'v added a pic of his car , he's a spectacular rallye driver as you can see
(162HP weber 45 dcoe powered )
any help welcome
Regards
Filh
_________________ Filh
Save the RWD cars
| Back to top |
Project D Wataru
1987 Toyota Corolla AE86 (late EU)
Posted: Thu May 08, 2008 9:00 pm Post subject: |
In french
Malheureusement pour lui il doit changer tout le bas moteur (bloc/vilbrequin/bielle/piston) pour celui d'un redtop, car rien n'est compatible...
_________________
| Back to top |
Bad_Dog Wataru
Joined: 05 Jan 2005 Posts: 90 Location: Sofia, Bulgaria
Posted: Thu May 08, 2008 9:52 pm Post subject: |
13401-16020
_________________ AE86 GTS '84 Red Top
| Back to top |
filh Takumi
Posted: Thu May 08, 2008 10:17 pm Post subject: |
thanks for the part number .
in french :
<<<<D"après les infos que j'ai les paliers de vilebrequins sont les mêmes , seuls mes diamètres de maneton changent .
J'attends la suite<<<
Still waiting your further informations : will he have to change block and pistons, to have the big journals crankshaft ? (It's what he wants to have)
Filh
Save the RWD cars
| Back to top |
S.K. Takumi
Joined: 23 Apr 2006 Posts: 244 Location: Vähäkyrö, Finland
Posted: Thu May 08, 2008 10:19 pm Post subject: |
Both axles have same main bearing size (48mm) and it fits straight in to 3 rib block.
What size piston pins he have? 18mm? 19mm? 20mm?
Most 42mm conrods have 20mm piston pin. I don´t think that there is a conrods that have 42mm lower hole and 18mm piston pin.
In here are many over 200hp 4A-GE rally engines and almoust all uses original (but balanced) 4A-GE 42mm cranshaft, including me.
_________________ "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://youtube.com/watch?v=Kgb8yp0eywM
| Back to top |
Jan Pedersen Moderator
Joined: 07 Sep 2004 Posts: 1149 Location: Herning, Denmark
Posted: Fri May 09, 2008 7:34 am Post subject: |
The problem isn't uncommon. Did he balance everything properly?
_________________ Sarcasme is just one of the things I offer
| Back to top |
F0Bman Takumi
Posted: Fri May 09, 2008 7:44 pm Post subject: |
Tell him to get a billet Formula Atlantic one and call it a day. I have one if he's interested.
F0b
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
jamiemirror Bunta
Joined: 04 Jan 2005 Posts: 1795 Location: Sofia, Bulgaria
Posted: Sat May 10, 2008 7:17 pm Post subject: |
Big crank will fit, requires big conrods and pistons.
Hi-rev requires precision balancing.
| Back to top |
firehawk Takumi
Joined: 10 Jun 2005 Posts: 250 Location: Turku, Finland
Posted: Mon May 12, 2008 10:24 am Post subject: |
| S.K. wrote: | | I don´t think that there is a conrods that have 42mm lower hole and 18mm piston pin. |
I actually just discussed this with a fellow Toyota-enthsiast who's building a gr.F AE92 and he suspected that it may be possible that late-model 4A-FE engines could have a 42mm rod bearing and a 18mm interference-fit piston pin. I have absolutely no experience with 4A-FE engines so I can't say anything one way or the other. Anyone know more?
_________________ Jani Halme / Red 5 Racing || AE86 / EP3 / SW20 / ED9
| Back to top |
S.K. Takumi
Posted: Mon May 12, 2008 11:23 am Post subject: |
| firehawk wrote: | | S.K. wrote: | | I don´t think that there is a conrods that have 42mm lower hole and 18mm piston pin. |
I actually just discussed this with a fellow Toyota-enthsiast who's building a gr.F AE92 and he suspected that it may be possible that late-model 4A-FE engines could have a 42mm rod bearing and a 18mm interference-fit piston pin. I have absolutely no experience with 4A-FE engines so I can't say anything one way or the other. Anyone know more? | I have changed conrod bearings to one 98-99 Avensis 4A-FE engine, there was 40mm rod bearings... Don't know what size the piston pin was, because I did it under the car.
I take off the sump, change bearings and then put sump back...
| Back to top |
filh Takumi
Posted: Mon May 12, 2008 10:43 pm Post subject: |
Thanks all for your answer .
I got a price (don't know the brand ) for a forged crankshaft with conrods :
about 3500€.
He actually have a balanced one with small bearing , and small axles .
He would like to fit the 42mm crankshaft into his newly rebuild 3 ribs block .
BAD DOG gave me the part number for crankshaft :13401-16020 .
He wants to buy new parts , but want also to know if they will fit , before buying
And I just saw the broken part today : it's broken near the 4th cylinder journal . Conrods , bearings and block are well in health.
Filh
Save the RWD cars
| Back to top |
Bad_Dog Wataru
Posted: Tue May 13, 2008 8:41 am Post subject: |
new OEM crank from toyota should be sth like 800euros. (forged)
New pauter rods - sth like 800 USD + shipping. (billet)
That's less than 3500euros IMHO!!!
| Back to top |
filh Takumi
Posted: Thu May 15, 2008 2:56 am Post subject: |
my friend has another question : about flywheel : on a 42mm crankshaft, are flywheel fixations same as on the small one.I think the number of bolts aren't the same , and flywheel is larger ?
Filh
Save the RWD cars
| Back to top |
F0Bman Takumi
Posted: Thu May 15, 2008 4:42 am Post subject: |
Good luck man! But get the 20mm crank if you can.
| Back to top |
jamiemirror Bunta
Posted: Thu May 15, 2008 10:41 am Post subject: |
| filh wrote: | my friend has another question : about flywheel : on a 42mm crankshaft, are flywheel fixations same as on the small one.I think the number of bolts aren't the same , and flywheel is larger ?
Filh |
Flywheels between 4AGEs (8 hole pattern) are interchangeable, clutct must match the flywheel (200 or 212mm diameter).
| Back to top |
oldeskewltoy Takumi
Joined: 29 Jan 2007 Posts: 274 Location: PDX, Oregon, USA
1987 Toyota Corolla AE86 (late US)
Posted: Fri May 16, 2008 6:21 am Post subject: |
I'm currently having Loynings Engine Service(winning formula atlantic engine builder) build me a bottom end. I'm using the smaller crank because it is SUBSTANTIALLY lighhter....
What is common is if it isn't properly balanced the journals marked begin an oscillation because they are not the same as the counter weight on the other side of the journal. This oscillation can be eliminated with balance, and hardening(shotpeen the crank
Using a newer block that is a bit stouter never hurts either
early block on the bottom(upsidedown), later block on top
_________________ Dan -
You can .... OR you can ask for help!!!
| Back to top |
jamiemirror Bunta
Posted: Fri May 16, 2008 10:21 am Post subject: |
Weight difference is ~1 kg.
| Back to top |
