stalling
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
alex-evo
Iketani
PostPosted: Fri May 02, 2008 3:17 am    Post subject: stalling Reply with quote
Hey guys
Iam having touble where when u let of the throttle the car should idle but the revs drops and stalls could it be the ignition timing ?
thx
Back to top
Ivan141
Moderator
PostPosted: Fri May 02, 2008 9:57 am    Post subject: Reply with quote
Not likely to be ignition timing, it's more likely to have starting problems in that case (at least if it has too much advance).
I once had this problem on an engine that had broken pistonrings on 2 cilinders, not saying that's your problem in this case though.
You can rule this out by pulling the crankcase ventilation tube off the valve cover, and give it some throttle. If it blows smoke out with some force, then your in trouble.
_________________
'81 poor guy with a money-pit
Back to top
DJexor
Moderator
PostPosted: Fri May 02, 2008 12:34 pm    Post subject: Reply with quote
have you also checked your water level in your radiator?
_________________
AE86 Levin 2drs
Back to top
alex-evo
Iketani
PostPosted: Fri May 02, 2008 2:17 pm    Post subject: Reply with quote
kk well first im gonna change the timng back to stock (waiting for the timing light to arrive Sad ) and see as i may have moved the distributor when i was fiddling around when the car didnt start. yeah the water level is fine
Back to top
alex-evo
Iketani
PostPosted: Sat May 03, 2008 12:56 am    Post subject: Reply with quote
well sort of done it. its better but still the revs drop below 500 rpm and then pumps back up
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
