| Author |
Message |
alex-evo Iketani
Posted: Fri May 02, 2008 3:17 am Post subject: stalling |
Hey guys
Iam having touble where when u let of the throttle the car should idle but the revs drops and stalls could it be the ignition timing ?
thx
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4759 Location: Netherlands Z-H
Posted: Fri May 02, 2008 9:57 am Post subject: |
Not likely to be ignition timing, it's more likely to have starting problems in that case (at least if it has too much advance).
I once had this problem on an engine that had broken pistonrings on 2 cilinders, not saying that's your problem in this case though.
You can rule this out by pulling the crankcase ventilation tube off the valve cover, and give it some throttle. If it blows smoke out with some force, then your in trouble.
'81 poor guy with a money-pit
| Back to top |
DJexor Moderator
Joined: 24 Oct 2004 Posts: 1421 Location: Netherlands, Den Haag
Posted: Fri May 02, 2008 12:34 pm Post subject: |
have you also checked your water level in your radiator?
_________________
9/2001 Toyota Yaris 1.5 T-Sport
| Back to top |
alex-evo Iketani
Posted: Fri May 02, 2008 2:17 pm Post subject: |
kk well first im gonna change the timng back to stock (waiting for the timing light to arrive ) and see as i may have moved the distributor when i was fiddling around when the car didnt start. yeah the water level is fine
| Back to top |
alex-evo Iketani
Posted: Sat May 03, 2008 12:56 am Post subject: |
well sort of done it. its better but still the revs drop below 500 rpm and then pumps back up
| Back to top |
