Celica F-diff with Hilux/ Pickup Torsen diff
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
Roye
PostPosted: Tue Apr 22, 2008 1:49 am    Post subject: Celica F-diff with Hilux/ Pickup Torsen diff Reply with quote
Not long ago I bought a Celica GT RA40 and I need a LSD.
So I need help with some issues.
Is it so that every F-axle and diffs fit between each other?
Is there any difference, like the T-diff, that I need to look out for?
Will be most thankful for tips and link to where I can buy a F-diff with LSD that will fit my Celica F-axle.
_________________
1978 Celica GT RA40
1982 Cressida DX RX60
1982 Carina DX TA60
Back to top
assassin10000
Wataru
PostPosted: Tue Apr 22, 2008 5:37 pm    Post subject: Re: Celica F-diff with Hilux/ Pickup Torsen diff Reply with quote
You can buy just the 'Torsen LSD' itself and have it installed into your current F-series diff housing.
The detroit true-trac is a torsen lsd for the 7.5" toyota diff, but unlike the factory torsen it doesn't break at 400 hp (supposedly). It was originally designed for the 4x4 toyota front 7.5 and is meant to take a lot more torque than the OEM one - afaik.
See more info here:
http://forums.celicasupra.com/showthread.php?t=10188
OR kaazusa has found which one will fit the 82-85 F-series independent rear susp, which is a direct swap into the older solid axle F-series diffs
http://www.kaazonline.com/8285.html
Andrew
_________________
1984 AE86 SR-5 (GT-S Converted)
1995.5 Toyota Tacoma 4x4 (Hilux)
Back to top
Roye
PostPosted: Wed Apr 23, 2008 8:32 pm    Post subject: Reply with quote
Thanks.
So all 7,5" F-diffs fits each other, IRS/IFS and solids?
How about such things as ring gear bolt pattern and number of driveshaft splines?
No worries...?
_________________
1978 Celica GT RA40
1982 Carina DX TA60
Back to top
r.hellenbrand
PostPosted: Thu Apr 24, 2008 3:13 pm    Post subject: Reply with quote
Hi,
You want to remove the torson diff, or are you looking for one?
Thanks,
Ron
Back to top
Roye
PostPosted: Thu Apr 24, 2008 8:06 pm    Post subject: Reply with quote
I am looking Wink
_________________
1978 Celica GT RA40
1982 Carina DX TA60
Back to top
assassin10000
Wataru
PostPosted: Fri Apr 25, 2008 5:56 pm    Post subject: Reply with quote
Roye wrote:
Thanks.
No worries...?
Ring gear bolt pattern is the same for all 7.5" toyota gear sets, Driveshaft splines are the same (28mm O.D./27spline axles).
To fit a 'detroit truetrac' torsen lsd in a RWD F-series housing you need to use the carrier bearings from the 95-04 hilux (1st gen toyota tacoma here in the states) part #:
90368-50006 | Carrier Bearing
All this info is covered in the linked post - afaik.
Andrew
_________________
Back to top
Roye
PostPosted: Tue Apr 29, 2008 9:13 pm    Post subject: Reply with quote
Thanks a lot, Andrew!
Thumbsup
_________________
1978 Celica GT RA40
1982 Carina DX TA60
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
