4AGE 20V sensor troubles
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
von*
PostPosted: Wed Apr 09, 2008 7:25 pm    Post subject: 4AGE 20V sensor troubles Reply with quote
I've got some question about blacktop!!!
I receive my engine with a broken sensor (I think it's a sensor) and when I remove the sensor I find a hole without thread :
This is the throttle body' side of the engine.
The broken "sensor" :
I want know what's this sensor and if it's the good fixing (without thread)
Other problem Mad :
I don't have the knock sensor : there are two holes under the throttle body and I don't know where it is located...
Last problem :
I've the purge valve :
But I don't know how it's "wired" (the vacuum hoses)
I hope someone can help me or show me pics of this side of the engine.
I wait for your answer, thanks...
Back to top
Jonny Rochester
PostPosted: Tue Apr 29, 2008 11:32 am    Post subject: Reply with quote
The part you have removed is not a sensor. It is just a plain plug to plug up a unused hole. This hole is used in the 16v 4A-GE as a extra oil drain from the head. No used with the 20 valve.
The knock sensor is ment to screw into the block. It goes in the block, under No.3 throttle.
Back to top
View user's profile Send private message Send e-mail
Jonny Rochester
PostPosted: Tue Apr 29, 2008 11:37 am    Post subject: Reply with quote
With the purge valve: one side is connected to your charcole canister. The other side is connected to all 4 throttles. There is a vaccum port underneath each throttle. These are all met to be connected up together, and via a valve, connect to once side of the purge valve.
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
