4AGE 20V sensor troubles
04-09-2008, 07:25 PM
I've got some question about blacktop!!!
I receive my engine with a broken sensor (I think it's a sensor) and when I remove the sensor I find a hole without thread : ![]() ![]() This is the throttle body' side of the engine. The broken "sensor" : ![]() ![]() ![]() I want know what's this sensor and if it's the good fixing (without thread) Other problem I don't have the knock sensor : there are two holes under the throttle body and I don't know where it is located... Last problem : I've the purge valve : ![]() But I don't know how it's "wired" (the vacuum hoses) I hope someone can help me or show me pics of this side of the engine. I wait for your answer, thanks... |
04-29-2008, 11:32 AM
The part you have removed is not a sensor. It is just a plain plug to plug up a unused hole. This hole is used in the 16v 4A-GE as a extra oil drain from the head. No used with the 20 valve.
The knock sensor is ment to screw into the block. It goes in the block, under No.3 throttle. |
04-29-2008, 11:37 AM
With the purge valve: one side is connected to your charcole canister. The other side is connected to all 4 throttles. There is a vaccum port underneath each throttle. These are all met to be connected up together, and via a valve, connect to once side of the purge valve.
| map sensor cheating? | fdsjakl890 | 8 | 2,963 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 8,496 |
| AE86 Engine Coolant Temp Sensor | izanagi | 8 | 24,035 |
09-06-2014 05:47 PM Last Post: izanagi |
| Hall sensor | totta Crolla | 7 | 10,526 |
02-28-2014 10:07 AM Last Post: Ivan141 |
| Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 13,714 |
10-25-2013 05:13 PM Last Post: Apsogos |
![AEU86 AE86 - 4AGE 20V sensor troubles [Image: AEU86 AE86 - 4AGE 20V sensor troubles]](http://img357.imageshack.us/img357/583/pict0014bp1.jpg)
![AEU86 AE86 - 4AGE 20V sensor troubles [Image: AEU86 AE86 - 4AGE 20V sensor troubles]](http://img138.imageshack.us/img138/8059/pict0009zs8.jpg)
![AEU86 AE86 - 4AGE 20V sensor troubles [Image: AEU86 AE86 - 4AGE 20V sensor troubles]](http://img357.imageshack.us/img357/947/pict0016nk3.jpg)
![AEU86 AE86 - 4AGE 20V sensor troubles [Image: AEU86 AE86 - 4AGE 20V sensor troubles]](http://img155.imageshack.us/img155/7500/pict0017do3.jpg)
![AEU86 AE86 - 4AGE 20V sensor troubles [Image: AEU86 AE86 - 4AGE 20V sensor troubles]](http://img237.imageshack.us/img237/7463/pict0019ga9.jpg)
![AEU86 AE86 - 4AGE 20V sensor troubles [Image: AEU86 AE86 - 4AGE 20V sensor troubles]](http://img237.imageshack.us/img237/5742/pict0012ib5.jpg)
