Simple Question about Fuel Pump Mount
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
generalachoo
Iketani
PostPosted: Fri Apr 25, 2008 1:38 pm    Post subject: Simple Question about Fuel Pump Mount Reply with quote
I have an SR5 and am doing the GTS swap. So far things are going alright, but our fuel pump needs a GTS bracket.
Is the bracket native to the ae86 or can we use an AE92 GTS or a MR2 fuel pump mount?
If not, how much will the bracket run me (could not find online).
Thanks!
Back to top
generalachoo
Iketani
PostPosted: Sat Apr 26, 2008 6:01 pm    Post subject: Reply with quote
bump?
Back to top
parrot
Takumi
PostPosted: Sun Apr 27, 2008 12:07 pm    Post subject: Reply with quote
You need the AE86 bracket.
Back to top
AZNWOKZ
Wataru
PostPosted: Sun Apr 27, 2008 3:28 pm    Post subject: Reply with quote
Yes you do need it because the tanks are different as well.
_________________
East Coast Toyota
http://ectoyotas.com/forum/index.php
Tunernetwork
http://www.tunernetwork.com
Club4AG
http://www.club4ag.com/
Back to top
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
parrot
Takumi
PostPosted: Mon Apr 28, 2008 2:22 am    Post subject: Reply with quote
The only difference between an SR5 and a GTS tank is that the GTS tank has better baffling around the pickup. You can still happily use an SR5 tank, although you may suffer with a bit of fuel surge.
Brackets from other cars may well fit the bolt pattern, however obviously the length is the critical issue.
Back to top
generalachoo
Iketani
PostPosted: Mon Apr 28, 2008 4:46 am    Post subject: Reply with quote
Thanks all for the replies. It is much appreciated. Turns out I will just be getting an entire GTS tank since someone local had it.
Thanks for your insight!
Back to top
parrot
Takumi
PostPosted: Mon Apr 28, 2008 8:43 am    Post subject: Reply with quote
Make sure you have a look inside with a torch to make sure it isn't rusted
Back to top
F0Bman
Takumi
PostPosted: Thu May 01, 2008 1:11 am    Post subject: Reply with quote
Tanks are different so good luck or buy a new race tank.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
parrot
Takumi
PostPosted: Thu May 01, 2008 9:35 am    Post subject: Reply with quote
No, tanks are identical except for internal baffling differences.
GTS pump bracket bolts into SR5 tank.
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
