HELP!!!!
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
midnitezenk85
PostPosted: Fri Apr 25, 2008 10:56 pm    Post subject: HELP!!!! Reply with quote
i have a 1985 toyota corolla GT-S (no conversions), 16v bluetop, all completely stock accept for trd headers. i did a motor swap, kept it stock. now my problem is:
a AFM set up, i crank over the car, it fires up super nice, no hestitation.. nothing... it fires up and begins to idle, then just shuts off. ive tried 3 different AFMs and still same problem... now heres what bothers me --> when i start the car if i stick my finger on the door of the AFM and keep it open the car will stay on, my idle kicks up to 2000rpms. this isnt a bother because when i plug the hole on the throttle body it normals out (idle air valve is bad). now with the car idling, when i step on the throttle it completely dies. i have purchased and installed new fuel pump, new fuel regulator, new AFM, tested my injectors (GOOD), getting 12v to my pump, changed out the fuel relay, and also installed a ECU from a running corolla (pin: 10p 18p 14p). im stuck... i dont know where to go from here... odd enough, the connected that connects to the AFM has a other connector (its a T shape connecter thats just there) that was never connected to anything (ive owned the car since 91). i took it to a mechanic, he stuck a wire in the connector jumping it to itself... the car now runs properly... yet i dont want to be mobbing around with a connector jumped to itself, and i dont want something to short out... im stuck, i dont know what to test anymore, i dont know where to go because mechanics out here are stupid and im getting pissed... HELP! plz!! thanks for reading.
-Tony
_________________
"I drift not because it is a quicker way around a corner, but it is the most exciting way" - Keiichi Tsuchiya
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address
F0Bman
Takumi
PostPosted: Thu May 15, 2008 4:43 am    Post subject: Reply with quote
Check the grounds.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
