| Author |
Message |
generalachoo Iketani
Posted: Fri Apr 25, 2008 1:38 pm Post subject: Simple Question about Fuel Pump Mount |
I have an SR5 and am doing the GTS swap. So far things are going alright, but our fuel pump needs a GTS bracket.
Is the bracket native to the ae86 or can we use an AE92 GTS or a MR2 fuel pump mount?
If not, how much will the bracket run me (could not find online).
Thanks!
| Back to top |
Posted: Sat Apr 26, 2008 6:01 pm Post subject: |
bump?
| Back to top |
parrot Takumi
Joined: 24 Nov 2006 Posts: 273 Location: Melbourne AUSTRALIA
Posted: Sun Apr 27, 2008 12:07 pm Post subject: |
You need the AE86 bracket.
| Back to top |
AZNWOKZ Wataru
Joined: 11 Mar 2007 Posts: 57 Location: Conneticut USA
| Back to top |
parrot Takumi
Posted: Mon Apr 28, 2008 2:22 am Post subject: |
The only difference between an SR5 and a GTS tank is that the GTS tank has better baffling around the pickup. You can still happily use an SR5 tank, although you may suffer with a bit of fuel surge.
Brackets from other cars may well fit the bolt pattern, however obviously the length is the critical issue.
| Back to top |
Posted: Mon Apr 28, 2008 4:46 am Post subject: |
Thanks all for the replies. It is much appreciated. Turns out I will just be getting an entire GTS tank since someone local had it.
Thanks for your insight!
| Back to top |
parrot Takumi
Posted: Mon Apr 28, 2008 8:43 am Post subject: |
Make sure you have a look inside with a torch to make sure it isn't rusted
| Back to top |
F0Bman Takumi
Posted: Thu May 01, 2008 1:11 am Post subject: |
Tanks are different so good luck or buy a new race tank.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
parrot Takumi
Posted: Thu May 01, 2008 9:35 am Post subject: |
No, tanks are identical except for internal baffling differences.
GTS pump bracket bolts into SR5 tank.
| Back to top |
