Water temp crisis, please suggestions
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
fkn16v
PostPosted: Mon Apr 21, 2008 11:13 am    Post subject: Water temp crisis, please suggestions Reply with quote
Has this happened to anyone else before.
Possible Reasons?? how to fix??
Had a Autogauge watertemp gauge installed, was working perfect for 12-16mths something like that , then all of a sudden stopped reading correct, would only go up too 50deg c .
Not "read correct" and stop at 50, when water was warm the needle hadnt moved. So its delayed type of thing.
Ok its a 10$ ebay heap of shit, so i thought might aswell shell out on a brand name item.
Enter Speco sport comp , some problem .
I got a new gauge and sendor send to me just incase, i know these things can be sensitive and dont like being dropped . Still same problem with new stuff
HMMM what now, new gauge and new sendor, all new wires (too eliminate faulty wires) excact same thing.
Ive sinse been able to find out that the gauge always reads 30deg less then it should. Water at 80 then gauge says 50, water at 90 then gauge reads 60.
Any ideas people, ive tried all locigal theories but dont let that stop you throwing ideas at me. Ill try just about anything once or twice.
Any help id greatly appreciated as always.
I might post this on a few forums, more responses that way.
_________________
Steve.....this is sparrrrrtan
Back to top
koh
Wataru
PostPosted: Mon Apr 21, 2008 2:25 pm    Post subject: Reply with quote
can only be a gauge problem if you have tested a new gauge wiring and sender against the actual water temp,i think most gauges are supplied with cheap rubbish senders now,even the senders that come with defi gauges go bad quickly
_________________
Back to top
fkn16v
PostPosted: Tue Apr 22, 2008 12:05 am    Post subject: Reply with quote
Seems a little weird that 2 different brands of gauges and sendors read exactly the same thou doesnt it.
I would hate to spend another $100 ona different one just get the same result.
_________________
Back to top
jondee86
Ryousuke
PostPosted: Tue Apr 22, 2008 12:37 am    Post subject: Just checking.... Reply with quote
Have you checked the operation of the gauge by dipping the sensor
into boiling water ?? If it works OK off the car, you could have a problem
with circulation... low fluid level... air locks ?? It would be unlikely for
two gauges to have exactly the same fault.
Cheers... jondee86
Back to top
View user's profile Send private message Send e-mail
fkn16v
PostPosted: Tue Apr 22, 2008 1:24 am    Post subject: Reply with quote
Just about to do that now Jondee86, yes i cant believe it either bit it all points to something none gauge related.
Time will tell.
_________________
Back to top
F0Bman
Ryousuke
PostPosted: Fri May 09, 2008 7:47 pm    Post subject: Reply with quote
Make sure your thermostat, waterpump, radiator cap is working. Also see if there are any leaks on the block.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
fkn16v
PostPosted: Sat May 10, 2008 2:09 am    Post subject: Reply with quote
Water flow isnt the problem, its not running hot or cold, the water temp is fine, its a sensor/gauge problem of some sort
_________________
Back to top
koh
Wataru
PostPosted: Sat May 10, 2008 3:33 am    Post subject: Reply with quote
are you still using the same earthing point far the gauges?
_________________
Back to top
fkn16v
PostPosted: Sat May 10, 2008 6:01 am    Post subject: Reply with quote
Tried 2 different spots.
The gauge now reads to 50 then stops.
I think ill just let the haltech take care of it when i get it in, im over worrying about it now.
Thanks to all with advice, its just a curse in the car. Cant be fixed
_________________
Back to top
F0Bman
Ryousuke
PostPosted: Wed May 21, 2008 6:29 am    Post subject: Reply with quote
Make sure you check for leaks. After that start with the radiator car, and move up to the more expensive things.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
