AE86 SR5 Bogging Down?
04-17-2008, 05:12 AM
I have a AE86 SR5 and it just started bogging down during warm up and when I am driving below or around 2500 rpms only thing is that if a slam the gas it hits a huge power band after 2700 rpm and just hauls ass to 6500 rpms. I have brand new spark plugs and a distributor. the vacuum lines all check out clean and idle screw is good and the fuel filter is clean. I just was wondering if anyone had a clue I dont work on carb engines that much anymore and was wondering if anyone has ever had this problem with their AE86
04-21-2008, 07:29 AM
Well I think its because of the Carb is really dirty. Its really annoying but not costly to clean it. Get some Carb cleaner and shoot it in the buttterfly throttle to do a quick clean up.
It sounds like a air problem. Not much. Also you have to abject the Carb to match to the season conditions of your area. There is a car manual that will example more better about adjecting your carb.
Carb engines are dirty engines in general. But simple than todays Fuel injected cars.
East Coast Toyota
http://ectoyotas.com/forum/index.ph
Club4AG
http://www.club4ag.com/
  20v blacktop swap bogging znull 7 13,316 09-29-2015 03:57 PM
Last Post: znull
  where to start on sr5-GTS swap dinkers542 0 4,474 12-20-2014 02:13 AM
Last Post: dinkers542
  Engine revs up/down on its own El_Camino 8 17,668 04-27-2014 05:49 PM
Last Post: Apsogos
  are sr5 rotors the same as gt-s? Rickybobby 3 7,105 07-28-2013 11:54 PM
Last Post: jondee86
  Revs going up and down... Okami 8 11,751 06-28-2012 07:25 PM
Last Post: Okami
