| Author |
Message |
Roku_trueno Bunta
| Back to top |
cvrle Itsuki
Joined: 23 Feb 2008 Posts: 18 Location: Belgrade, Serbia
Posted: Tue Apr 15, 2008 11:31 pm Post subject: |
Where are you at Tokol on King of Europe? I hope to meet you and see car in real time, but you are not been there...
_________________ www.drift.co.yu
| Back to top |
AE86_Z Wataru
Posted: Thu Apr 17, 2008 9:50 am Post subject: |
| cvrle wrote: | Where are you at Tokol on King of Europe? I hope to meet you and see car in real time, but you are not been there...  |
Hi,
I was there to help my friend Denes Miklos (AE86 20V 178hp). He won the Hungarian PRO drifting series 1st round on sunday with his hachiroku . Unfortunatelly he had transimission problems on saturdays KoE round
This is my first year in drifting and I will race in the 2nd class Official drifting league in Hungary called Amateur series. In the hungarian KoE rounds you can only race if you have the PRO license.
Regards,
Z
_________________ http://ae86.blog.hu
2006 Toyota Corolla Verso 2.2 D4-D
2005 Toyota Corolla Hatchback 1.4VVTi
1985 AE86 Drift racecar
| Back to top |
AE86_Z Wataru
| Back to top |
dAYTONA Takumi
Posted: Sat May 03, 2008 2:55 am Post subject: |
Very nice drifting. Nice Hachi you have there.
_________________
Koukis - Red, Silver/Gray,
| Back to top |
AE86_Z Wataru
| Back to top |
Gtsi-R Takumi
Joined: 21 Jan 2008 Posts: 371 Location: Nijmegen, Netherlands
Posted: Tue May 20, 2008 9:41 am Post subject: |
verry nice movie!! great driftwork over there!! I want to do a driffschool in this summer!!
| Back to top |
AE86_Z Wataru
Posted: Thu Jul 10, 2008 9:30 pm Post subject: |
***VIDEO UPDATE***
After 2 rounds in the Hungarian Drift Association - 2nd class drift league I'm at the 4th overall position now. I finished my 1st race on the 6th position, and on my 2nd race I won the bronze cup for the 3rd position:)
Here you can watch the best moment of my last race (Kakucs ring - Hungary, 2008.06.22.)
Link
| Back to top |
Roku_trueno Bunta
| Back to top |
Dr.Ling Itsuki
Posted: Sun Nov 23, 2008 3:26 am Post subject: |
| AE86_Z wrote: | My engine setup currently (was built 6 month ago):
7rib block with 1st gen crankshaft-pistons-conn.rods
lightened flywheel, adj cam.gears
ported/polished bigport head
increased CR (11:0)
TRD header with 2,5" free flow exhaust
Map sensored factory ECU always running on 100+ octane
Szia! I have to say I'm impressed that you got 132 whp out of this setup, but this was with the HKS 272 8,1 cams installed? But with the big port head, and bigport intake manifold w/TVIS? Normal size throttle-body?
After seeing your drift-videos I think I might follow in your footsteps engine-wise (that is, not getting a redtop/smallport engine). A shame we dont't have drift-tracks up here were I live Actually I lived 6 years in Pécs, but have forgotten almost all my hungarian!
Unfortunately I have the low compression (9,4:1), AFM version 4AGE, but with the 7 rib block without the oil-squirters. I guess I have the lighter version / 1st gen crank + conn.rods, so I think I'll keep those parts, but will need new pistons to increase compression ratio, helped maybe by shaving the block, and a thinner headgasket.
When you switch to ITB's (+ aftermarket EMS) will you switch to a smallport head as well, or keep the big port head?
And your exhaust guy..... could he make another batch of those headers? He could probably make some serious cash making those, if they connect easily with other cat-back systems
_________________
1987 Levin 3d - daily drifter (to be)
1990 SW20 MR2 w/ gen3 3S-GTE - daily poser
| Back to top |
AE86_Z Wataru
Posted: Sun Nov 23, 2008 10:46 am Post subject: |
| Dr.Ling wrote: | | AE86_Z wrote: | My engine setup currently (was built 6 month ago):
increased CR (11:0)
And your exhaust guy..... could he make another batch of those headers? He could probably make some serious cash making those, if they connect easily with other cat-back systems  |
Hello mate!
Yes my engine can do 134 whp with the following setup:
7rib block
1st gen crank, pistons, conrods
increased CR 11:1
ported&polished bigport head
HKS 272 8,1 cams +adj. cam gears
HKS valve springs
HKS oil up
lightened flywheel
TRD 4-1 header
free flow 2,5" underdiff exhaust
W/O TVIS
stock ECU
stock intake with Greddy filter
I think this is the maximum power with the stock ECU and stock throttle body and injectors, because the engine running lean. So not too healthy 160hp on crank . I'm very happy that the engine worked well on the last 3 races with lean AFR without any mechanical problems. I tried a Greddy E-manage, but it wasn't fully compatible with the bigport ECU. Sold that quickly.
I finished on the 2nd overall position in the 2nd class hungarian drifting championship with my hachi
Next year I will competite in the PRO drift league so I need to uprgade the engine.
I bought an MS-I V2.2 standalone DIY ecu like apardal and gon, and I will build my own EMS. I also bought 7MGE 315ccm high impedance injectors. And I will change to AE101 ITBs, with T3 adapter and velocity stack.
I hope this setup will good for 145-150whp 170-180 on crank.
You can see some new vidoes on my youtube channel: ae86zoli
Best Regards,
Zoltan
| Back to top |
Dr.Ling Itsuki
Posted: Sun Nov 23, 2008 5:11 pm Post subject: |
Sorry, I'm getting more and more confused researching the different 4AGE's...
So your starting engine was from the AE92, with a bigport/TVIS head, but 10,0:1 CR / MAP-based engine? With the 7rib block w/o oilsquirters? But you chose the lighter 11,0kg crank, 40/18mm conrods (and pistons with 18mm pins) usually used with the 3rib (pre 1987) block?
Then increased the CR to 11:1 just by shaving, or thinner headgasket?
I'm beginning to think my engine (bigport/TVIS, and AFM, 9,4:1 CR) must have the "heavier" 42/20 conrods and 11,7kg crank since I have the 7rib block......
I understand you ported and polished the bigport head... so you wouldn't consider a smallport head with your future ITB setup??
_________________
| Back to top |
AE86_Z Wataru
Posted: Sun Nov 23, 2008 6:32 pm Post subject: |
Yes, I have a 7rib block w/o oilsquirters with 11kg crank and 40/18 conrods with the 83-87 pistons (MAP version 10:1).
We increased the compression with shaving the head.
I think my config is revving better than if I have choosen the bigger parts. The only thing I know I can beat the 200-300hp BMW monsters in the league.
I really don't want to change smallport head, the head is fully rebuilt and ready for the ITBs.
But keep it in your mind, my car is a driftcar, and I doesn't really matter engines long life. I don't use the car in street just only on racetracks and in a whole season I run about ~1200kms with the car.
I hope billzilla said the truth, and the stock bottom end is good for ~170hp and 8500rpm, because I will change only the bearings for TRD ones.
| Back to top |
filh Takumi
Joined: 10 Oct 2004 Posts: 246 Location: Ličge Belgique
Posted: Tue Nov 25, 2008 10:52 pm Post subject: |
hello, you did a nice and hard job . Where did you get your suspension springs ?I'm looking for similar springs for my rallycar ?
regards
phil(belgium)
_________________ Filh
Save the RWD cars
| Back to top |
AE86_Z Wataru
Posted: Tue Nov 25, 2008 11:30 pm Post subject: |
Hello filh!
Thank You.
Here is a guy in Hungary who can make clones of the TRD springs, but he can also make different length and strength (kg/mm) springs for racing cars. 1 set about 200-250€.
I have his e-mail address just let me know if you need.
Best Regards,
Zoltan
| Back to top |
filh Takumi
Posted: Thu Nov 27, 2008 12:30 am Post subject: |
Thanks for your quick response . I thought they were trd or else .I know a machinist here in Belgium who does them for about same price , but i'm trying to find cheaper ones.
regards
phil
Save the RWD cars
| Back to top |
