trans wont shift into 3rd or 4th :(
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
odeaten
Itsuki
PostPosted: Sun Apr 13, 2008 6:48 am    Post subject: trans wont shift into 3rd or 4th :( Reply with quote
hey guys first things first im pretty new, and actualy my car isent a AE-86 (unfortunately) its an AE-92 fwd, but i cant find any forums for my car, and i fugure we share the same motor, so why not ask you guys for help.
i just got my car running again (with your guyses help) it had been sitting for a lil while maybe a month or so. when i got it to run it was doing fine, shifting perfectly and everything was ok. but out of nowhere with out any warning signs, as im driving along my car just stops shifting into 3rd and 4th gear. it was just fine befor, never slipped or ANYTHING Neutral
it will "click" into 3rd but as soon as i pop the clutch it shoots out of gear and if i try to force it in, it just makes a horrable grinding sound. and it wont even go into 4th at all, its like 4th isent there anymore. 1st 2nd 5th and reverse work fine.
I checked the oil, all good and brand new.
HELP! Sad Sad thank you
Back to top
jondee86
Takumi
PostPosted: Sun Apr 13, 2008 9:52 am    Post subject: One of those... Uh Oh moments.... Reply with quote
Sounds like you broke one of the gear selector forks Neutral
Cheers... jondee86
Back to top
View user's profile Send private message Send e-mail
odeaten
Itsuki
PostPosted: Mon Apr 14, 2008 12:40 am    Post subject: Reply with quote
any idea to how u think this happend? what would you say i do to fix it?
Back to top
koh
Wataru
PostPosted: Mon Apr 14, 2008 12:58 am    Post subject: Reply with quote
the box will need stripping down,or replacing
_________________
Back to top
odeaten
Itsuki
PostPosted: Mon Apr 14, 2008 1:05 am    Post subject: Reply with quote
thanks guys. ima go take a look at it. Worship
is there anything else that it might possably be?
_________________
Beater cars, they run fine.........till you need to use them
Back to top
koh
Wataru
PostPosted: Mon Apr 14, 2008 10:20 am    Post subject: Reply with quote
when was the last time it had a trans service?
_________________
Back to top
Sanity Clause
Wataru
PostPosted: Mon Apr 14, 2008 12:12 pm    Post subject: Reply with quote
Before you pull the box out, check the linkage from the gearlever to the box. Something may have moved slightly.
I'm not familiar with the AE92 gearbox setup, but I had a similar problem on the wife's Fiesta, a few years ago.
It just needed a slight adjustment at the gearbox end, and all was well again.
_________________
www.AE86imports.0catch.com
Back to top
View user's profile Send private message Visit poster's website
odeaten
Itsuki
PostPosted: Mon Apr 14, 2008 10:30 pm    Post subject: Reply with quote
i've never had it "serviced" but i have changed the trans fluid. i did that about a month ago.
i'll take a look at the linkage.
_________________
Back to top
DJexor
Moderator
PostPosted: Mon Apr 14, 2008 11:28 pm    Post subject: Reply with quote
What oil did you use?
_________________
AE86 Levin 2drs
Back to top
odeaten
Itsuki
PostPosted: Tue Apr 15, 2008 8:33 am    Post subject: Reply with quote
just plain tranny fluid. i dont remember what brand or nothin.
i checked the linkage and it aint the problem. Neutral
_________________
Back to top
DJexor
Moderator
PostPosted: Tue Apr 15, 2008 3:39 pm    Post subject: Reply with quote
I did my oil half a year ago and first with a ..W80 or 90 if im correct and it didnt shift very well. People told me it was better to use W75 and now its shifts much better...
Ill get back on this when i have the exact nummers ...W... Puh
_________________
AE86 Levin 2drs
Back to top
Mux213
Site Admin
PostPosted: Tue Apr 15, 2008 4:23 pm    Post subject: Reply with quote
Hmm,
The important bit for Hachi's is that the oil isn't GL5 but GL4 oil. GL5 has some additive that eats away the synchros, atleast so I've been told.
No idea if this also goes for the AE92...
_________________
No more hachi Sad
Back to top
odeaten
Itsuki
PostPosted: Tue Apr 15, 2008 9:04 pm    Post subject: Reply with quote
i wouldent know. but i guess that after i take out the "box" to check things out i'll replace the oil with GL4. thanks guys.
_________________
Back to top
odeaten
Itsuki
PostPosted: Tue Apr 22, 2008 12:13 am    Post subject: Reply with quote
ok, so i havent yet takin it apart to check it all out. but now ALL the gears are messed up. the clutch pedal is hard to push in now. it wont go into 1st, 2nd is real hard to get it into, and when i take off (in second) there is a whining, scraping sound. also if i have the clutch pedal pushed in while it is in gear, in tryes to take off on its own as if i were letting off the clutch.
does anyone have any idea whats goin on? maybe my clutch is going out?
_________________
Back to top
jondee86
Takumi
PostPosted: Tue Apr 22, 2008 12:32 am    Post subject: Check the slave first.... Reply with quote
Yup.... sure sounds like your clutch is fcuked !!!!!
But first, check that the clutch slave cylinder isn't seized. Check there
is fluid in the clutch reservoir... look for leaks... get someone to work
the pedal while you are under the car watching the slave. If it does
not move freely back and forwards, replace the slave. If that doesn't
cure the problem....
Get under there and get the gearbox out... while you are replacing
the clutch you can spin the gearbox by hand and see if it jams up in
the gears. If so, it will need to be stripped and repaired.
Cheers... jondee86
Back to top
F0Bman
Takumi
PostPosted: Thu May 01, 2008 1:12 am    Post subject: Reply with quote
Synchros? Contact Max Misawa for a rebuild kit.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
