| Author |
Message |
odeaten Itsuki
Joined: 11 Apr 2008 Posts: 13 Location: california, USA
Posted: Sun Apr 13, 2008 6:48 am Post subject: trans wont shift into 3rd or 4th :( |
hey guys first things first im pretty new, and actualy my car isent a AE-86 (unfortunately) its an AE-92 fwd, but i cant find any forums for my car, and i fugure we share the same motor, so why not ask you guys for help.
i just got my car running again (with your guyses help) it had been sitting for a lil while maybe a month or so. when i got it to run it was doing fine, shifting perfectly and everything was ok. but out of nowhere with out any warning signs, as im driving along my car just stops shifting into 3rd and 4th gear. it was just fine befor, never slipped or ANYTHING
it will "click" into 3rd but as soon as i pop the clutch it shoots out of gear and if i try to force it in, it just makes a horrable grinding sound. and it wont even go into 4th at all, its like 4th isent there anymore. 1st 2nd 5th and reverse work fine.
I checked the oil, all good and brand new.
HELP! thank you
| Back to top |
jondee86 Takumi
Posted: Sun Apr 13, 2008 9:52 am Post subject: One of those... Uh Oh moments.... |
Sounds like you broke one of the gear selector forks
Cheers... jondee86
| Back to top |
odeaten Itsuki
Posted: Mon Apr 14, 2008 12:40 am Post subject: |
any idea to how u think this happend? what would you say i do to fix it?
| Back to top |
koh Wataru
Joined: 05 Apr 2008 Posts: 72 Location: south wales uk
Posted: Mon Apr 14, 2008 12:58 am Post subject: |
the box will need stripping down,or replacing
_________________
| Back to top |
odeaten Itsuki
Posted: Mon Apr 14, 2008 1:05 am Post subject: |
thanks guys. ima go take a look at it.
is there anything else that it might possably be?
_________________ Beater cars, they run fine.........till you need to use them
| Back to top |
koh Wataru
Posted: Mon Apr 14, 2008 10:20 am Post subject: |
when was the last time it had a trans service?
_________________
| Back to top |
Sanity Clause Wataru
Joined: 14 Mar 2005 Posts: 57 Location: Addlestone, Surrey, UK
Posted: Mon Apr 14, 2008 12:12 pm Post subject: |
Before you pull the box out, check the linkage from the gearlever to the box. Something may have moved slightly.
I'm not familiar with the AE92 gearbox setup, but I had a similar problem on the wife's Fiesta, a few years ago.
It just needed a slight adjustment at the gearbox end, and all was well again.
_________________ www.AE86imports.0catch.com
| Back to top |
odeaten Itsuki
Posted: Mon Apr 14, 2008 10:30 pm Post subject: |
i've never had it "serviced" but i have changed the trans fluid. i did that about a month ago.
i'll take a look at the linkage.
| Back to top |
DJexor Moderator
Joined: 24 Oct 2004 Posts: 1396 Location: Netherlands, Den Haag
Posted: Mon Apr 14, 2008 11:28 pm Post subject: |
| odeaten wrote: | i've never had it "serviced" but i have changed the trans fluid. i did that about a month ago.
i'll take a look at the linkage. |
What oil did you use?
_________________
AE86 Levin 2drs
| Back to top |
odeaten Itsuki
Posted: Tue Apr 15, 2008 8:33 am Post subject: |
just plain tranny fluid. i dont remember what brand or nothin.
i checked the linkage and it aint the problem.
| Back to top |
DJexor Moderator
Posted: Tue Apr 15, 2008 3:39 pm Post subject: |
| odeaten wrote: | just plain tranny fluid. i dont remember what brand or nothin.
i checked the linkage and it aint the problem.  |
I did my oil half a year ago and first with a ..W80 or 90 if im correct and it didnt shift very well. People told me it was better to use W75 and now its shifts much better...
Ill get back on this when i have the exact nummers ...W...
_________________
AE86 Levin 2drs
| Back to top |
Mux213 Site Admin
Posted: Tue Apr 15, 2008 4:23 pm Post subject: |
Hmm,
The important bit for Hachi's is that the oil isn't GL5 but GL4 oil. GL5 has some additive that eats away the synchros, atleast so I've been told.
No idea if this also goes for the AE92...
_________________ Greetz,
No more hachi
| Back to top |
odeaten Itsuki
Posted: Tue Apr 15, 2008 9:04 pm Post subject: |
i wouldent know. but i guess that after i take out the "box" to check things out i'll replace the oil with GL4. thanks guys.
| Back to top |
odeaten Itsuki
Posted: Tue Apr 22, 2008 12:13 am Post subject: |
ok, so i havent yet takin it apart to check it all out. but now ALL the gears are messed up. the clutch pedal is hard to push in now. it wont go into 1st, 2nd is real hard to get it into, and when i take off (in second) there is a whining, scraping sound. also if i have the clutch pedal pushed in while it is in gear, in tryes to take off on its own as if i were letting off the clutch.
does anyone have any idea whats goin on? maybe my clutch is going out?
| Back to top |
jondee86 Takumi
Posted: Tue Apr 22, 2008 12:32 am Post subject: Check the slave first.... |
Yup.... sure sounds like your clutch is fcuked !!!!!
But first, check that the clutch slave cylinder isn't seized. Check there
is fluid in the clutch reservoir... look for leaks... get someone to work
the pedal while you are under the car watching the slave. If it does
not move freely back and forwards, replace the slave. If that doesn't
cure the problem....
Get under there and get the gearbox out... while you are replacing
the clutch you can spin the gearbox by hand and see if it jams up in
the gears. If so, it will need to be stripped and repaired.
Cheers... jondee86
| Back to top |
F0Bman Takumi
Posted: Thu May 01, 2008 1:12 am Post subject: |
Synchros? Contact Max Misawa for a rebuild kit.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
