| Author |
Message |
firehawk Takumi
Joined: 10 Jun 2005 Posts: 240 Location: Turku, Finland
Posted: Fri Apr 11, 2008 11:12 pm Post subject: |
| Rossi wrote: | I am running 297/12mm cams made my Angelworks Technolgies in the UK which are amazing
Any pics of the rest of the kit yet, i badly need a front splitter for my TRD kit. |
12mm lift? Wow - are you running fuel injection with those or carbs? The idle must be quite wild either way.
My N2 kit is still at the guy who does fibreglass work as he's making proper molds of them. I do have some old pics here but will post new photos as soon as I get the fresh parts off the molds, hopefully sometime early next month.
_________________ Jani Halme / Red 5 Racing || AE86 / EP3 / SW20 / ED9
| Back to top |
Rossi Wataru
Posted: Sat Apr 12, 2008 12:44 pm Post subject: |
lol they are with fuel injection, well i haven't heard it run yet is just being finished, can't wait to hear it!
Will you be willing to sell me a front lip when you get the parts made?
| Back to top |
firehawk Takumi
Posted: Fri Apr 25, 2008 3:30 pm Post subject: |
| Rossi wrote: | | Will you be willing to sell me a front lip when you get the parts made? |
That should be possible. The FRP guy can make all the parts of the N2 kit so I could ask him if he could make one extra front lip and sell it to you.
Ok, making some progress with the car again. First of all, the brakes are now all done and working, although they still need a good bleeding. I replaced the front discs, all pads, lines and hoses. The 195/45R13 Conti Sportcontact front tyres also arrived but I haven't had them changed on the rims yet.
So far the engine has been completely stock, with the exception of a 11.2:1 compression ratio and some porting and polishing. To slightly bring the engine up to speed, I installed a pair of Schrick group A camshafts with 296 degree duration and 8.6mm lift. This particular pair of cams was originally owned by none other than the former F1 driver Jyrki Järvilehto! They were used in a gr.F AE86 rallycar which he raced at the "Tunturiralli" rally in 96-99. These cams are pretty close to the "magical" 9mm limit where under-bucket shims are required, so I'll probably go for stiffer springs and 1SZ-FE buckets later on.
I also reworked the exhaust system a bit by swapping out the original manifold in favor of a Martelius 4-1 manifold. I also added a small-diameter absorption muffler to cut the high-frequency noise a bit because test running the engine, even for short periods, makes my head hurt.
A bit of enginebay bling in the form of a set of velocity stacks was also added.
To fill a big hole at the rear of the car, I got 8-gallon (~30l) RCI safety fuel cell with foam and an aircraft-style filler cap. It's actually a bit deeper than I originally intended, so I'll need to modify my rear bracing to mount the cell slightly lower. Once the cell sits at its location, I'll start working on building an aluminium enclosure around it.
Finally, I found a second hand Sparco Pro2000 FRP racing seat in excellent condition and as extra, also got a pair of sliderails and side mounts - both from Sparco as well. I'll need to modify the mounts on the car a bit to bolt on the rails, though.
My fingers are really itching to get that fuel cell installed but no work on the AE86 this weekend - our first endurance race of the season with the CRX this sunday at Botniaring.
Viewed 67 Time(s)
Sparco seat
Viewed 66 Time(s)
8gal RCI fuel cell
Viewed 83 Time(s)
Viewed 90 Time(s)
Manifold on the car
Viewed 80 Time(s)
296deg/8.6mm Schrick cams
Viewed 80 Time(s)
Tiny 195/45R13 tyres
| Back to top |
andrecorreia Iketani
| Back to top |
firehawk Takumi
| Back to top |
| Back to top |
firehawk Takumi
Posted: Tue Apr 29, 2008 4:02 pm Post subject: |
Nope, not FIA-approved - hence the quite affordable price. If your class requires a FIA-approved fuel cell, go for ATL but be prepared to shell out at least four times as much cash.
| Back to top |
firehawk Takumi
Posted: Wed May 14, 2008 12:27 pm Post subject: |
Ok, finally the engine is starting to run a bit like it's supposed to. Without ignition advance, it started and idled nicely but didn't really pick up revs at all. Now that the advance works, it both starts and runs properly.
I hacked together a quick'n'dirty method for gathering enough vacuum to provide the standard ECU a MAP-signal. As mentioned earlier, the ECU itself is modified slightly to overcome the lack of a TPS, air temp sensor and the idle mixture pot. These have no function on the ignition side of things so just faking them with two-resistor voltage dividers works quite well. The ECU does throw error code 11 when the diagnostic plug is connected but this is completely harmless as it only indicates that the idle switch was open on power up (the switch is normally inside the TPS).
Since the TRD intake manifold only provides vacuum ports from cylinders 1 and 4, I took those two, connected them with a Y-junction and ran a small hose via a filter to the MAP sensor. This seems to work reasonably well and the ECU runs the car with the stock ignition advance map. Since the fueling is performed by the carbs, the slight "jumpiness" of the vacuum doesn't matter as much as it would with ITBs+injectors.
Now that the ignition advance works properly and the engine starts to burn the fuel earlier, I found out that the carbs are way too lean. The engine idled very nicely, at a stable 850rpm but when carefully pressing the throttle, the carbs spat puffs of smoke and the exhaust popped and crackled loudly. On the other hand, the acceleration pumps seem to work exceptionally well with the 40 nozzles as a fast dab of the throttle picks up revs very sharply without a hint of hesitation.
A friend of mine shot this video while I tested the throttle response and tried to peek at the smoke-spitting carbs through the gap under the raised bonnet.
http://hanza.1g.fi/kuvat/sekalaista/corolla.AVI
Even with the muffler I added, the exhaust is ear-piercingly loud and on the video it's hard to tell when it backfires because the camera's mic gets completely swamped. Also, the recently applied heat-resistant paint on the muffler started to emit an acrid smell and white smoke towards the end of the video.
Anyway, since the engine ran so obviously lean, I pulled the 52.5 pilot jets and 135 main jets and skipped two sizes on both and replaced them with 60.0 and 150. No more backfire and the engine still revs quite eagerly. It may have gone a bit too far into the rich side but I won't know that for sure until I get to do some actual full-throttle driving. Gotta bleed those brakes first.
Viewed 86 Time(s)
The fugly vacuum hack to the MAP sensor
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4759 Location: Netherlands Z-H
Posted: Wed May 14, 2008 5:45 pm Post subject: |
That sound! Very nice..I like!
'81 poor guy with a money-pit
| Back to top |
cavey Takumi
Joined: 07 Dec 2007 Posts: 305 Location: Arnemuiden, Netherlands
Posted: Wed May 14, 2008 7:13 pm Post subject: |
jumalauta! now that is some engine noise
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
