| Author |
Message |
von*
Posted: Wed Apr 09, 2008 7:25 pm Post subject: 4AGE 20V sensor troubles |
I've got some question about blacktop!!!
I receive my engine with a broken sensor (I think it's a sensor) and when I remove the sensor I find a hole without thread :
This is the throttle body' side of the engine.
The broken "sensor" :
I want know what's this sensor and if it's the good fixing (without thread)
Other problem :
I don't have the knock sensor : there are two holes under the throttle body and I don't know where it is located...
Last problem :
I've the purge valve :
But I don't know how it's "wired" (the vacuum hoses)
I hope someone can help me or show me pics of this side of the engine.
I wait for your answer, thanks...
| Back to top |
Jonny Rochester
Joined: 08 May 2007 Posts: 6 Location: Tasmania, Australia
Posted: Tue Apr 29, 2008 11:32 am Post subject: |
The part you have removed is not a sensor. It is just a plain plug to plug up a unused hole. This hole is used in the 16v 4A-GE as a extra oil drain from the head. No used with the 20 valve.
The knock sensor is ment to screw into the block. It goes in the block, under No.3 throttle.
| Back to top |
Jonny Rochester
Posted: Tue Apr 29, 2008 11:37 am Post subject: |
With the purge valve: one side is connected to your charcole canister. The other side is connected to all 4 throttles. There is a vaccum port underneath each throttle. These are all met to be connected up together, and via a valve, connect to once side of the purge valve.
| Back to top |
