| Author |
Message |
filh Takumi
Joined: 10 Oct 2004 Posts: 236 Location: Liège Belgique
Posted: Tue Jan 22, 2008 1:39 am Post subject: rear springs TRd or else |
I' looking for rear Springs (no coilovers) like TRD , Tein , SWift
for rallye purpose
filh
_________________ Filh
Save the RWD cars
| Back to top |
filh Takumi
Posted: Wed Jan 23, 2008 11:35 pm Post subject: |
looks pretty impossible to get springs here in Europe!!????
Save the RWD cars
| Back to top |
Jan Pedersen Moderator
Joined: 07 Sep 2004 Posts: 1144 Location: Herning, Denmark
Posted: Thu Jan 24, 2008 8:39 am Post subject: |
What rate do you want? Short stroke? Gravel? Tarmac?
I'll help you but you need to be specific
_________________ Sarcasme is just one of the things I offer
| Back to top |
filh Takumi
Posted: Fri Jan 25, 2008 12:42 am Post subject: |
Well It's for rallying only
I run stock stroke , and need more tarmac than gravel : maybe 4kg/mm
I Think I have Koni springs , but there are so old and collapsed .Rear has became too low .
I've measured the wire dia : 12mm. Global dia is stock , but I'll have to measure the free height and number of coils . Hard for me As I've some health problems. Trying to do that saturday
Still searching but it seems hard to find . I don't want them to stiff , as tarmac here is so often in bad condition . I had Tokico blue shocks , with stock springs , but it was too hard and very hazardous on bad roads.
Hope it can helps you to understand what I'm looking for .
regards
Phil
Save the RWD cars
| Back to top |
Posted: Fri Jan 25, 2008 8:48 am Post subject: |
I'll ask the TRD agent here in Denmark
Ride height: My car is too low, right?
I'm running 5,1kg TRDs in the rear which is what most rally drivers use in DK. But then 95% af all stages is tarmac...
| Back to top |
filh Takumi
Posted: Sat Jan 26, 2008 2:39 am Post subject: |
Doesn't look too low for me .Mine is lower from rear , but the side flap makes a wrong feeling
Filh
Save the RWD cars
| Back to top |
SYM Ryousuke
Joined: 24 Apr 2006 Posts: 178 Location: California, USA
Posted: Sat Jan 26, 2008 5:46 am Post subject: |
I have swift 6.5 and 7kg in stock
_________________ P.A.S.S Racing
148 S.8th Ave, Unit-F
(626)961-6284
City of Industry
SYM@passracing.com
www.passracing.com
| Back to top |
Posted: Sat Jan 26, 2008 9:56 am Post subject: |
Ok, but I'm running short strokes with these springs...
| Back to top |
filh Takumi
Posted: Sun Jan 27, 2008 1:13 am Post subject: |
To SYM
Thanks Sym , It would be a pleasure to buy from you , but I'm still"fighting"
with the belgian customs, to get the front springs and camber plates I bought from you . They arrived on december 28th in Belgium .
I got an email from them on january 10th to get the invoice .And still got nothing from them . It's a real shame .And no way to contact them
And I must thank you as you did all very correctly with me !!!!!!
To Jan
here are some pics of what I'm looking for :
measurements :
I must use a 2cm spacer , as it's too low , and even with that spacer , it 's 3cm too low :
Spring :
Free height : 30cm
ext dia : 13 cm
wire dia : 12,30 mm
number of coils : 7
Spacer height : 2cm .
To resume : I would like to gain 5cm height ,and maybe a little stiffer
Regards
Viewed 51 Time(s)
rear height
Viewed 50 Time(s)
rear spring
Viewed 55 Time(s)
spring spacer
Save the RWD cars
| Back to top |
Posted: Sun Jan 27, 2008 1:17 pm Post subject: |
This is what is read: You want TRD sprins that is as long as stock springs. Spring rate would be about 4-5 kg/mmm???
| Back to top |
filh Takumi
Posted: Sun Jan 27, 2008 3:23 pm Post subject: |
Yes but it's a problem for the rate as I just don't know my springs rate .
If mine are , let's say 2,5KG , with TRD 4'5 kg stock lenght , I guess the car
will look like Starsky&Hutch or dragster look!!!!
I'm still looking for a solution .
I think I' d better place a double spacer (4cm) to regain height and leave things as they are as it looks so complicated .
Fil
Save the RWD cars
| Back to top |
alex-evo Iketani
Posted: Mon Apr 14, 2008 1:45 pm Post subject: |
hey i have some rear light blue springs with spacers i think they are trd ones and they are v.hard not too sure on the rate but yeah they are hard too hard for the street if interested give me a pm
| Back to top |
