4AGE ITB's Rolling Road session
10-09-2007, 11:11 AM
I agree about the injectors, they wouldn't make any difference, we tried richening the mixture at the top end but it made no effect on power. I think the main problen is the engine is tired and very, very smokey at high revs. And also because the engine is in a MG midget the exhaust manifold is very restrictive, 4-2-1 all before it exits under the car, with tight 90 degree bends, this is the only way it can fit in the car. So I am happy enough, probably most impressive is mid range 4000-6000rpm. I use the car for autotesting so this suits me fine. I am going to an event on sat so will hopefully put some vids on youtube.
Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
10-09-2007, 12:26 PM
good luck on the event. http://www.heerlijklimburg.nl |
10-09-2007, 03:26 PM
robokill Wrote:without any head work (porting or other cams) I don't see the gain in using itb. I agree. Though like everyone else on here, this car will no doubt be a work in progress. My point with injectors still stands. What does a 'Standard' injector refer to in this case? 182cc, 200cc, 210cc or 213cc? Perhaps a smallport 250cc? There is a lot of potential variation there. Presumably these runs were done on a chassis dyno. Toyota got close to 200ps on an engine dyno using 250cc injectors on a group A 16 valve. Meanwhile a standard 20 valve uses 295cc injectors. In this situation the air displacement is greatly increased with the 4 throttles compared to a single throttle plenum. Presumably fuel demand also increases in a linear fashion. Allowing for transmission losses, I doubt a 182cc injector would cut it in this situation. If you utilise the approximation of HP = cc per minute /5, a 182cc injector will only produce in the vicinity of 145hp at the flywheel. What colour are the injectors? But once again, robokill Wrote:without any head work (porting or other cams) I don't see the gain in using itb. |
01-19-2008, 04:13 PM
Parrot,
No offense,but if you'll look at Ivan's dyno sheet,you'll see he has more than enough fuel flow to support his power output.His A/F ratio trace is rock steady,and between approximately 13:1 and 12:1 as rpm increase.If anything,he might even want to lean it out a bit!Any richer and he would most likely begin to lose power.As was mentioned earlier,higher-flowing injectors are only needed if airflow into the engine warrants it(via porting and more aggresive cams,like the GrpA engine you mentioned above). |
| Sparco chrono road seat rails | stratosTRD | 6 | 9,556 |
09-03-2011 07:32 PM Last Post: stratosTRD |
| 4AGE 20v ITB vacuum instructions on Intecracing.com | JAVResistance | 17 | 40,125 |
05-07-2011 05:50 AM Last Post: jondee86 |
| Power - 4AGE ITB's and Stand alone ECU? | byd1380 | 10 | 17,434 |
02-27-2009 12:45 AM Last Post: Elitetech |
| megasquirt 4age wit 20v itb's | shanemck | 7 | 11,943 |
05-18-2008 06:08 PM Last Post: shanemck |
| Rolling road update | totta Crolla | 13 | 14,489 |
01-05-2008 02:03 PM Last Post: totta Crolla |
