nzae86's AE86 Levin Tarmac rally car build Project 1
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Projects
Author Message
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 6:54 am    Post subject: nzae86's AE86 Levin Tarmac rally car build Project 1 Reply with quote
I thought I would share one of my project builds that I started after destroying my Rally car on tarmac. I managed to salvage the engine , gearbox, and diff center and front brakes, the rest went to the dump!The seats broke , the dash was destroyed, it was easier to start again!
After finding another good shell my panel beater cut and butt welded any areas of rust to end with a rust free body to start building a new cage into, all the fabrication work i have done myself.
The shell was then sent in and media blasted back to bare metal, the sprayed with PPG DP40 etch primer
The cage did it's job ok last time but I added a bit more to it for the new car
The shell then went to the painters to have the top coats sprayed in a oven
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 7:08 am    Post subject: Reply with quote
While the shell was away for paint I rebuilt all the other components, sand blasting everything and repainting, i also thoght it was time for a new engine as well , the other needed pulling apart to check for oil starvation while end for ending down the road, so a bit more power was added with new pistons and balanced bottom end.
All new bilstien suspension was fitted and the springs were replaced with TRD.
After building a new fuel system for the car I had just finished when Motorsport New Zealand changed the rules on surge tanks and fuel pumps inside the car, so i had to redesign how it fitted and mounted it all in a sealed box
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 7:24 am    Post subject: Reply with quote
My ae86 toybox! where it all happens (as you see I do have a few spare parts!!)
Finally after many months I had the car almost complete
As you can see some head restraint seats help hold me in place now!
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 7:35 am    Post subject: Reply with quote
The engine is a smallport , with Wisco pistons , 20v ITB's ,lots of head work, Link computer, TRD gearbox, TRD LSD with a 4.8 crown wheel and pinion
Underneath the car is as (was) as well painted as the outside
Looking a bit naked without any signwriting!!!!
Back to top
nzae86
Wataru
PostPosted: Tue Jan 01, 2008 7:51 am    Post subject: Reply with quote
And for the finished article in action !!
One of it's first events, just to get it dirty ! at a rallysprint in the rain
A small video, suffering from a nervous driver and very slippery conditions
http://www.youtube.com/watch?v=b_lD1ooVwqU
and another after passing the GT4 Celica
http://www.youtube.com/watch?v=bgusB5tF3M8
Tarmac rally in New Zealand
At a recent trackday enjoying the sunshine
I am now running the car on 15 inch wheels and it suits the car very well, the rims are from a Dastun 240RS rally car , if anyone knows where I can find some more of these 15 x 7 let me know
And at a recent Tarmac hillclimb, those Dunlops are fantasic, you can push them to the limit and they still hang on !
And yet another Tarmac rally in the rain !! Finished 16th O/A won 1400 - 1800cc class by over 2 minutes , take that you Honda's !!!!
Back to top
matt mead
Ryousuke
1984 Toyota Corolla AE86 (early JDM Levin)
PostPosted: Tue Jan 01, 2008 9:30 am    Post subject: Reply with quote
thats sick... i luv 86 rally cars Smile
how come u decide to use struts and springs instead of coilvoers?? and what brakes are u using???
Back to top
Eircamae86
Takumi
PostPosted: Tue Jan 01, 2008 12:25 pm    Post subject: Reply with quote
Very nice build, youve been at this game a while?, had a pic of your colourscheme on an 86 a few years ago now. Keep up the good work Thumbsup
_________________
Back to top
Ivan141
Moderator
PostPosted: Tue Jan 01, 2008 2:57 pm    Post subject: Reply with quote
Very nice.. great looking build.
_________________
'81 poor guy with a money-pit
Back to top
ae86_sr20
Iketani
PostPosted: Sun Jan 06, 2008 3:46 am    Post subject: Reply with quote
Great job,best of luck in the future
_________________
TURBO'D HACHI
Back to top
nzae86
Wataru
PostPosted: Sun Mar 23, 2008 11:20 pm    Post subject: Reply with quote
And just to prove that ae86's are not slow on tarmac here are the results from a recent 9km tarmac hillclimb , loosing the final run due to fuel surge from trying to run too light a fuel load!!
http://www.hamiltoncarclub.org.nz/Results_This_...imb%20Results.pdf
The conditions changed from damp to dry from the bottom of the hill to the top.
Who said 4wd was fast???
Back to top
mc68
Wataru
PostPosted: Sun Apr 27, 2008 11:30 am    Post subject: Reply with quote
awesome build!
how did you paint your cage black with the rest of the car being white!
how good do starion 14" wheels look on sprinters Very Happy defiantly the rally wheel of choice.
Back to top
nzae86
Wataru
PostPosted: Wed Apr 30, 2008 1:03 pm    Post subject: Reply with quote
mc68 wrote:
awesome build!
The cage was painted first in a satin black then wraped in masking while the inside was painted white , it took a bit of time but it was the look that I wanted.
Yeah 14" Starion rims suit ae86's well as the have the correct offset and are easy to find over here, but I have now changed to Nissan 240RS rims 15 x 7 with 205 /50 /15 but only have 6 of them at this stage and am having trouble finding 2 more
cheers
Back to top
mc68
Wataru
PostPosted: Thu May 01, 2008 1:28 pm    Post subject: Reply with quote
god damn, starion wheels are like hens teeth here in perth..
i need a couple of sets Sad
Back to top
matt mead
Ryousuke
PostPosted: Mon May 05, 2008 6:51 am    Post subject: Reply with quote
I pmed you but wondering if you have the part number for the bilsteins and the trd springs you use??? also im guessing you still use the standard ae86 struts??
Back to top
nzae86
Wataru
PostPosted: Mon May 05, 2008 10:48 am    Post subject: Reply with quote
Hi there
I have my shocks built by Chris at Suspension Tech www.stech.co.nz , he has valved these to my requirements for tarmac rallying .he also supplied the front springs and adjustable sleaves for my N2 car as well . And yes I use ae86 struts as I don't think that I could build anything that would work better
Back to top
nzae86
Wataru
PostPosted: Mon May 05, 2008 10:49 am    Post subject: Reply with quote
Well you will hate me then as I had 20 and sold them all not that long ago
Back to top
matt mead
Ryousuke
PostPosted: Mon May 05, 2008 2:24 pm    Post subject: Reply with quote
nzae86 wrote:
Hi there
hello, thanks for that..i sen thim an email about the bilsteins
can you remember the spring rates of your springs and/or the part numbers?? you would be my hero if you did Smile
cheers matt
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Projects All times are GMT + 2 Hours
Page 1 of 1
Jump to:
You cannot attach files in this forum
