Quaife QSR - Installation & manual steering info
12-13-2007, 08:30 AM
Jimmi either you go to the gym or you could ask Martin Bjerre... He used a rack from an old Carina and an electric servo from a MR2 I think. It wasn't easy but it worked
12-13-2007, 06:48 PM
Jimmi The Kid Wrote:When you ad the steering quickeners, the steering wheel will be lighter to turn right? But that will also mean, you got to turn the sterring wheel a lot more, to get the same angel, right? Thats not good. I meant you could add the quickener to a POWERSTEERING equipped vehicle to get quicker response, while having easier steering. But with the loss of road feel & achievable angle. Andrew |
12-13-2007, 09:34 PM
Mayby I should work out
This quickener is good idea, but not the best. I have found some drawing of the Avensis power steering motor and its not impossible. Fitting the car is not a problem - I think, its just metalwork and will just take some time. Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
01-17-2008, 08:52 PM
Great thread on so many ae86 forums
But one question : what is the ratio of the rack ? with this gear set fitted i am guessing that the NON powersteering racks you have there are the same as ones here AE86 : 16 : 1 also i have looked at the following for replacing it SW20{MR2} : 16.6 : 1 , 2.7 in SW20{MR2} MR-S{MR2} : 13.6 : 1 but the rack is front mounted so would require a gearbox to reverse direction , fitted in a AE86 with its shorted arms is gives 2.2 turns from 2.6 in the MR-S s13/240sx : ???? No doubt No Hachi will know s14 : 17.49 : 1 Late EVO : 13 : 1 still trying to get hold of a rack for measurements EVO CT9A RS RHD 11.8 : 1 MR2 is a manual powersteering rack with a external electric powersteering pump as per MR-S as well. There very unreliable over here and cannot supply the pressure to keep up with going from full lock one direction to the other. |
01-17-2008, 11:49 PM
3 of my friend uses the suzuki ignis electris ps column with their quaife qsr.
Its working. I don't have pictures at this time and I don't know how they did it, but I know the whole thing was under 400 EUR. I'll try to get some pics. |
| Looking for jdm spec body repair manual | AE111 | 0 | 899 |
10-08-2025 10:33 AM Last Post: AE111 |
| Wanted: 3-rib engine repair manual | Ivan141 | 6 | 5,101 |
09-09-2022 07:46 PM Last Post: oldeskewltoy |
| Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 10,039 |
| Quaife quick rack | totta Crolla | 19 | 26,885 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
| TRD multi-ECU manual | Two Sheds | 10 | 25,490 |
07-12-2017 12:21 AM Last Post: jondee86 |
