| Author |
Message |
Holli Iketani
Joined: 18 Sep 2006 Posts: 41 Location: HMS SULTAN or Catterick England
Posted: Tue Apr 24, 2007 8:52 pm Post subject: |
Got my clutch when i was home, he had to split 3 different kits to make one clutch, cost Ģ60 which i cant really argue with cos the guy is always interested in the car rather enjoys making clutches rather than off the shelf. that included the pressure plate and release bearing.
clark bros in belfast.
_________________ Its gotta go whoosh or give a whine!!!!
| Back to top |
SutteR Takumi
Joined: 19 Mar 2005 Posts: 394 Location: Budapest, Hungary
1987 Toyota Corolla AE86 (late US)
Posted: Mon Jul 09, 2007 3:37 pm Post subject: |
Does anybody know which brand is the AE92GTi factory clutch plate? This is the 212mm diameter, P/N 31250-17020 or 31250-12320 - no difference imho.
I thought it should be Aisin as many other parts and like the AE86 factory clutch but according to a dealer it isn't. I was told it is something like NKK or whatever...
Can somebody help me out with this please?
_________________ 1987 Toyota Corolla GT coupe - for holidays oversteer
1999 Toyota Corolla - for daily understeer
| Back to top |
*ian_pez*
Posted: Sun Nov 18, 2007 9:52 pm Post subject: |
Could someone please advise if the aw11 clutch has the same splines as the ae86?
There is one on ebay that I might buy if I can use it.
Regards
Ian
| Back to top |
jamiemirror Bunta
Joined: 04 Jan 2005 Posts: 1795 Location: Sofia, Bulgaria
Posted: Mon Nov 19, 2007 12:21 pm Post subject: |
If it is for 4AGE engine - yes, same splines.
Avoid 4AGZE ones.
| Back to top |
*ian_pez*
Posted: Mon Nov 19, 2007 6:46 pm Post subject: |
Thanks for the reply Jamie..maybe I will bid on it now.
| Back to top |
kid Ryousuke
Posted: Thu Dec 06, 2007 9:37 pm Post subject: |
just got teh info that blacktop engine with bt flywheel with 10v cluch will NOT fit. is that true? something with the pressure plate
_________________
| Back to top |
jamiemirror Bunta
Posted: Fri Dec 07, 2007 11:16 am Post subject: |
Pressure plate depends from the flywheel used (200 and 212mm options, 4AC have diferent bolting pattern than 4AGE but can be easily redrilled to fit - 1 or 2 holes only).
| Back to top |
raki Iketani
Posted: Sun Jan 20, 2008 10:18 pm Post subject: |
Now I installed a clutch with heavy duty pressure plate and 6-pad spring ceramic disc from ACT in my rallycar. The clutch feels quite good, though I only droveon the streets and not on a rallye yet. The pressure plate is harder to press, but not too hard, i find, and due to the springs, the shocks are not too hard. I think itīs a good choice for racecars that also must be driven on streets and need a good durability of transmission, rear axle, etc. But I can tell more, after the first rally this year...
There are different possibilities for pressure plates and discs, so i think everybody can find his best choice...
URL of the label:
http://www.advancedclutch.com/1274880/0/0/0/198...GTS_L4_1.6L_N_FI_(4AGEC).html
Best regards,
raki
_________________ www.sg-rallyesport.de
| Back to top |
F0Bman Takumi
Posted: Fri May 09, 2008 7:50 pm Post subject: |
I have a 6 puck sprung hub clutch. Its awesome, sprung hub reduces the chatter.
_________________ Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
| Back to top |
Miguel - Newera Ryousuke
Joined: 22 Aug 2005 Posts: 177 Location: Tokyo, Japan!
1985 Toyota Corolla AE86 (late JDM Levin)
Posted: Fri Jun 13, 2008 1:54 am Post subject: |
Careful with clutches that are too heavy duty, for example high pressure clutch covers, twin plate clutches, etc. If used hard these are too harsh for the weak T50 gearbox and if you have an uprated final drive such as say 4.77:1...
Use of too heavy duty a clutch will end in tears - when your gearbox breaks, pinion gear loses teeth, etc. The best clutch (Which I see Tec Arts use in their D1 cars and Techo Pro Spirits recommend above all others is the RG or TRD clutch kit (Both are the same) with copper mix plate (Circular - not puck type). I've used the RG kit for drifting with a 200 bhp engine and mine lasted me almost 2 years of clutch kicking abuse before the plate finally got worn enough to slip. We've just replaced it with the same again
They're not expensive, so there's no excuse for not getting one.
_________________ VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
| Back to top |
tolisspi Ryousuke
Posted: Sun Jun 15, 2008 12:05 pm Post subject: |
I have 4age tvis with 200mm flywheel and clutch kit.
I have a bottom 4agze and im thinking to change with 4age. Can i fit the 200mm clutch kit and flywheel?
Thx a lot
_________________ **COROLLA EE80 - 4AGE 124HP**
| Back to top |
raki Iketani
Posted: Sun Jun 15, 2008 3:06 pm Post subject: |
After driving 5 rallys with the ACT clutch, I wrote a few postings before, I changed the disc, but still use the pressure plate. I destroyed a driveshaft and the t50 had to be changed, cause itīs not working well anymore. Of course there are also other reasons, but I think the disc is too harsh for the other stock components, when driving really hard. Though it was really nice driving it.
Now I use a 4 puck sprung disc from "Sachs" which is also sintered metal, but works much smoother, almost like the stock one, maybe cause of stronger springs. But it is not so weak like the stock one. I donīt think this disc is available anymore, cause I got it from a friend who bought it few years ago but didnīt need it...
Best regards,
Michael
| Back to top |
D.Wars Takumi
Joined: 07 Oct 2006 Posts: 407 Location: Bavel, Holland
1985 Toyota Celica
Posted: Sat Aug 09, 2008 12:54 pm Post subject: |
i've installed an XTD stage 3 6puck clutch with a lightend flywheel, both new.
But now i cant get the car in gear when the engine is running?
I can't imagine that i have to re-bleed the system after changing the clutch.
Anyone with the same experience overhere?
With other words:
HELP?
_________________ I reject your reality and substitute my own!
Pandalica Initial-d sprinter trueno wanabee look-a-like. Going downhill, time after time, mod after mod.
| Back to top |
