Stativ
09-19-2007, 10:25 PM
Stativ
Hej
Jeg skal have lavet et stativ Men hvor stort skal det vaere for at det kan holde og ikke vaelter. tager karossen paa nogen maade skade kan man komme til at bukke det? Hvis i har nogle billeder og maal maa i meget gerne poste dem Tak for hjaelpen English: I'm building a rotisserie. What dimensions should it be to make it strong enough and make sure it doesn't tip over. Will the chassis be damaged or could you bend in any way? If you got any pictures or messurements please post up. Thanks! |
09-19-2007, 11:21 PM
Stativ
Jag har gjort en snabb skiss. Du måste nog stödja profilen som länkar ihop båda ramarna från var och en sida eller hitta på något annat. Ramarna är i alla fall ritade enligt ae86 mått. Hoppas detta blir till nån hjälp.
Philip |
09-20-2007, 08:57 AM
Stativ
(my swedish is really bad so I'll reply in english, sorry)
This is a pretty good rotisserie for a car chassis and it's adjustable so it can be used for different cars; http://www.mts.net/~hpokrant/Restoration...sserie.htm The construction plans are also pretty detailed so building one shouldn't be too hard. |
09-20-2007, 09:16 AM
Stativ
You guys rock !!!!!
I was looking after of a plan like this. Thank you very very much Toyota Corolla KE30 + Toyota Corolla AE86 |
09-20-2007, 10:06 AM
Stativ
Nice link Firehawk :!: The rotisserie I used look like this:
![]() ![]() ![]() This was nicely balanced and I could turn it single handed If you want to leave the rear end and front suspension you might want to make it a bit stronger... WeRz, hvis karosseriet tager skade er det ikke værd at lave (Jeg tror ikke det kan ske)... Du skal naturligvis ikke skære alle vangene af mens karossen hænger i stativet, men det giver jo sig selv ![]() English: If the chassis gets damaged its not worth saving, but I don't think you have to worry about that. Just don't cut all the all the side members at once
09-20-2007, 12:21 PM
Stativ
The rotisserie I made:
09-21-2007, 12:11 AM
Stativ
nice link firehawk!
Philip |
09-21-2007, 08:32 AM
Stativ
please convert it to english and make it a sticky in the tech session. This is helpfull for everyone!
09-21-2007, 09:12 AM
Stativ
I hope Cannabolic will translate his reply... I'm not quite sure that I'm able to do it properbly
09-25-2007, 12:09 PM
Stativ
I just made a quick drawing taking in mind hachi's dimensions. there's a lot of other stands that have hachi's on'em. I've made mine but haven't put my hachi on it yet.
sticky firehawks link is very good Philip |
| Stativ til karosseri søges | Jimmi The Kid | 1 | 8,131 |
12-04-2007 09:19 PM Last Post: Jimmi The Kid |
![AEU86 AE86 - Stativ [Image: AEU86 AE86 - Stativ]](http://img.photobucket.com/albums/v622/JJGP/scan0001.jpg)
![AEU86 AE86 - Stativ [Image: AEU86 AE86 - Stativ]](http://img.photobucket.com/albums/v622/JJGP/DSC00262.jpg)
![AEU86 AE86 - Stativ [Image: AEU86 AE86 - Stativ]](http://img.photobucket.com/albums/v622/JJGP/DSC00261.jpg)
