| Author |
Message |
WeRz Iketani
Posted: Wed Sep 19, 2007 10:25 pm Post subject: Stativ |
Hej
Jeg skal have lavet et stativ
Men hvor stort skal det vaere for at det kan holde og ikke vaelter.
tager karossen paa nogen maade skade kan man komme til at bukke det?
Hvis i har nogle billeder og maal maa i meget gerne poste dem
Tak for hjaelpen
English:
I'm building a rotisserie. What dimensions should it be to make it strong enough and make sure it doesn't tip over.
Will the chassis be damaged or could you bend in any way?
If you got any pictures or messurements please post up. Thanks!
| Back to top |
cannabolic Takumi
Posted: Wed Sep 19, 2007 11:21 pm Post subject: |
Jag har gjort en snabb skiss. Du måste nog stödja profilen som länkar ihop båda ramarna från var och en sida eller hitta på något annat. Ramarna är i alla fall ritade enligt ae86 mått. Hoppas detta blir till nån hjälp.
_________________ Philip
'86 Red hachi
'03 Silver BigHit
| Back to top |
firehawk Takumi
Joined: 10 Jun 2005 Posts: 240 Location: Turku, Finland
| Back to top |
dikolotour Bunta
Joined: 25 Oct 2004 Posts: 829 Location: Greece - Pyrgos
Posted: Thu Sep 20, 2007 9:16 am Post subject: |
You guys rock !!!!!
I was looking after of a plan like this.
Thank you very very much
_________________ Toyota Corolla KE30 + Toyota Corolla AE86
| Back to top |
Jan Pedersen Moderator
Joined: 07 Sep 2004 Posts: 1133 Location: Herning, Denmark
Posted: Thu Sep 20, 2007 10:06 am Post subject: |
Nice link Firehawk The rotisserie I used look like this:
This was nicely balanced and I could turn it single handed
If you want to leave the rear end and front suspension you might want to make it a bit stronger...
WeRz, hvis karosseriet tager skade er det ikke værd at lave (Jeg tror ikke det kan ske)... Du skal naturligvis ikke skære alle vangene af mens karossen hænger i stativet, men det giver jo sig selv
English: If the chassis gets damaged its not worth saving, but I don't think you have to worry about that. Just don't cut all the all the side members at once
_________________ Sarcasme is just one of the things I offer
| Back to top |
KrizKH Wataru
Joined: 05 Dec 2005 Posts: 65 Location: Denmark, Aalborg
Posted: Thu Sep 20, 2007 12:21 pm Post subject: |
The rotisserie I made:
| Back to top |
cannabolic Takumi
Posted: Fri Sep 21, 2007 12:11 am Post subject: |
nice link firehawk!
'86 Red hachi
'03 Silver BigHit
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2093 Location: Amsterdam // The Netherlands
Posted: Fri Sep 21, 2007 8:32 am Post subject: |
please convert it to english and make it a sticky in the tech session. This is helpfull for everyone!
_________________ "05 Ford Mondeo Daily moving object
KIS it
Keep It Sideways
| Back to top |
Posted: Fri Sep 21, 2007 9:12 am Post subject: |
I hope Cannabolic will translate his reply... I'm not quite sure that I'm able to do it properbly
| Back to top |
cannabolic Takumi
Posted: Tue Sep 25, 2007 12:09 pm Post subject: |
I just made a quick drawing taking in mind hachi's dimensions. there's a lot of other stands that have hachi's on'em. I've made mine but haven't put my hachi on it yet.
sticky
firehawks link is very good
'86 Red hachi
'03 Silver BigHit
| Back to top |
