| Author |
Message |
S.K. Takumi
Joined: 23 Apr 2006 Posts: 251 Location: Vähäkyrö, Finland
Posted: Sun Jul 08, 2007 10:26 am Post subject: |
Little progress in here, but it is not on the hood yet, maybe after couple of weeks...
I change a new RWD-waterpump and stuff to it (before there was FWD-waterpump)
This is what it looks now
and new engine mounts
| Back to top |
matt mead Ryousuke
Joined: 01 Jun 2006 Posts: 156 Location: Sydney, AUSTRALIA
1984 Toyota Corolla AE86 (early JDM Levin)
Posted: Sun Jul 08, 2007 10:28 am Post subject: |
i luv ur car and your build keep up the good work
| Back to top |
S.K. Takumi
Posted: Wed Jul 25, 2007 9:36 pm Post subject: |
I got few days ago engine back to own place and tomorrow I go find a new hose to oil cooler, new waterhoses should come on friday...so probably on monday I will get engine running first time after accident. I have also change tyres (at last) and same time I change rear absorbers to TRD 8-ways.
_________________ "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://youtube.com/watch?v=Kgb8yp0eywM
| Back to top |
S.K. Takumi
Posted: Thu Jul 26, 2007 1:03 pm Post subject: |
Didn´t have to wait to monday, I woke up 8.00 because my phone was ringing: Your waterhoses has arriwed.
Great, so I picked up those too, when I search oil hose.
I just started it...
| Back to top |
S.K. Takumi
Posted: Fri Aug 17, 2007 8:53 pm Post subject: |
Yesterday I got a set new wheels (COMPOMOTIVE MO) and I also started to modified a left wheelbase, because when I enlarged it, clutchpedal had not enought space...
And today I got a new gravel tyres (MATADOR SM-8 16/65-15)
Still need to get it on dynamometer and get it adjusted, before rallysprint on 16.9. in the neighbour municipality.
| Back to top |
matt mead Ryousuke
Posted: Mon Aug 20, 2007 1:43 pm Post subject: |
i luv ur car, it inspires me so much... good work mate
| Back to top |
20vPETE Ryousuke
Joined: 20 Dec 2006 Posts: 137 Location: NSW,Australia
Posted: Mon Aug 20, 2007 1:51 pm Post subject: |
is that box section there for a reason,sorry for the stupid question
_________________ if first u dont succeed,ur not trying hard enough
| Back to top |
S.K. Takumi
Posted: Mon Aug 20, 2007 3:46 pm Post subject: |
| matt mead wrote: | | i luv ur car, it inspires me so much... good work mate |
Thanks
| 20vPETE wrote: | | is that box section there for a reason,sorry for the stupid question | What? Where? In the wheelcase?...for my left foot
| Back to top |
irishtwincam Wataru
Joined: 03 Oct 2005 Posts: 115 Location: Republic of Ireland
Posted: Mon Aug 20, 2007 5:00 pm Post subject: :( |
Bad news.
Your distributor wont work
I recognise it as a 3A-U dizzy.
The advance system built in turns the wrong direction when used in a 4age. The car will RETARD heavily as you rev it.
If you want to stick with distributors, try the 4K-U with mag pickup.
If you have the adaptor block for the 4A head it can be used.
Kit comes from Japan.
Best bet, go VEMS with EFI!
VEMS can just control spark if you want to use carbs.
Then in future youll have EFI capability waiting
_________________ http://www.skynet.ie/~eireae86
| Back to top |
S.K. Takumi
Posted: Mon Aug 20, 2007 6:26 pm Post subject: |
You are absolutely wrong. It works. I have changed it rolling on right direction
You can see the changes in here: http://s33.photobucket.com/albums/d61/Kleemola/Jakaja/
| Back to top |
20vPETE Ryousuke
Posted: Tue Aug 21, 2007 5:04 am Post subject: |
sorry for another stupid question but im not seeing the benefits from the box section behind the clutch pedal,the pedal can only move to a certain point
| Back to top |
S.K. Takumi
Posted: Tue Aug 21, 2007 8:54 am Post subject: |
It goes very well all way to bottom, picture is lying a bit .
Before that box, it did go down, but i have to move my foot a bit same time when pressing the pedal, and my foot used to a little bit under the brake pedal and that was not funny. Don´t worry, I know what I´m doing.
Here is a picture from one Group-F Starlet, also larger wheelcases.
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2249 Location: Amsterdam // The Netherlands
Posted: Tue Aug 21, 2007 10:15 am Post subject: |
S.K. will you use the car for drifting or track days? So far it only has seen snow ?
_________________ "08 Honda Civic Hybrid
KIS it
Keep It Sideways
| Back to top |
S.K. Takumi
Posted: Tue Aug 21, 2007 10:18 am Post subject: |
The time will show...
| Back to top |
irishtwincam Wataru
Posted: Tue Aug 21, 2007 11:26 pm Post subject: |
Cool.
We only had one of those distributors and didnt want to take it apart.
How did you get the plastic under the rotor arm off?
Do you ahve more pictures or information about the sequence to disassemble the unit?
What other engines did they come on?
Very cool article!
I ahd the "Spark advance vs Vacuum" curve somewhere.
Oh wait, did you remove the vacuum advance mechanism?
| Back to top |
S.K. Takumi
Posted: Wed Aug 22, 2007 9:40 am Post subject: |
| irishtwincam wrote: | Cool.
Very cool article!
Oh wait, did you remove the vacuum advance mechanism? |
It is very easy to dissabled, sorry no other pictures. Plastic, with little screwdriver.
Middle axle is from 4A, but I have to weld a another lowerpart on it (without that it wouldn´t work).
Upper rotor is also from 4A, but I grinded pins and hit them out, then I put rest of it on a lathe and take that lowerpart off. Then I turned it around, pull the pins down and soldered it together.
Body is from 2E (1.3 12V) carb. engine, because it fits better to cylinder head, but I had to lathed it a bit.
Electrical system is also from 2E
Yes, I dump vacuum advance mechanism, for me centrifugal governor gives enough advance on right time.
Those three single wires goes to revolution limiter, so don´t care of those.
| Back to top |
S.K. Takumi
Posted: Fri Sep 07, 2007 10:03 pm Post subject: |
Little update.
Last weekend I finished the right door and now it is painted. I have a dynotime on monday, so let's see if everything is ok.
| Back to top |
S.K. Takumi
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sun Sep 16, 2007 6:25 pm Post subject: |
Auch!
Are you going to fix her up again?
And what happend?
| Back to top |
Erik_dk Takumi
Joined: 06 Feb 2005 Posts: 204 Location: Danmark-Odense
Posted: Sun Sep 16, 2007 6:39 pm Post subject: |
many cars died there:-(
_________________ Corolla GT Twin Cam AE86 whit 4agze:-D SOLd:-(
Ke70 rocks:-D
| Back to top |
S.K. Takumi
Posted: Sun Sep 16, 2007 7:05 pm Post subject: |
| banpei wrote: | Auch!
And what happend?  |
Yes, it is fixable...but need some work...
I came too fast on one curve...(just like that number 55, and same place), then it just start rolling...3 rounds...I will get videoclip from it someday.
E:
another pic: http://rallikuvat.1g.fi/2007/laihia/images/laihia_46.jpg
and other: http://www.rallikuvat.net/2007/laihia/index.php#
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4853 Location: Netherlands Z-H
Posted: Sun Sep 16, 2007 8:39 pm Post subject: |
Sorry to see that... a lot of hard work down the drain
'81 poor guy with a money-pit
| Back to top |
E-volve Takumi
Joined: 26 Feb 2006 Posts: 224 Location: Beverwijk, The Netherlands
Posted: Sun Sep 16, 2007 9:24 pm Post subject: |
Damn too bad man, is the roof still straight?
| Back to top |
S.K. Takumi
Posted: Sun Sep 16, 2007 9:31 pm Post subject: |
| E-volve wrote: | | Damn too bad man, is the roof still straight? |
The roofs left corner had little damage, also left A-pillar, but sunroofs hole/plate is still unvisible
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sun Sep 16, 2007 10:24 pm Post subject: |
Nasty corner!
Looks like you pulled it off better than 55.
| Back to top |
