| Author |
Message |
a112 Ryousuke
Joined: 24 Nov 2006 Posts: 161 Location: Lipik,Croatia
Posted: Tue Aug 07, 2007 11:47 am Post subject: Kadett C x 2 Limo '76/City '77 |
The story begins with me,my brother and my friend going to tow the car in the neighbour city 25km's away in one direction
We saw the cops on the road,they just waved and looked away
Opel Kadett C 1.2S 2 Door Limo
There are some visual modifications,like Irmscher rear ducktail
And some plastic parts,that are normally made of steel.
3 Spoke Opel aluminium steering wheel,but unfortunately with original 2 Spoke wheel horn button
The stupid things about the car,tow hook
And this hideous front bumper,removing it was the first modification
The rear bonnet absorber,not working at all.
There is corosion on fenders,front part of the car.Front and rear shock mounts are not rusty.
I really don't know anything about the engine,the starter is not working,gotta fix that first.
This is after removing the air filter plastic lid.
There is 3 same wheels,and one different
The different one has the bigger oval cuts
Here is the fourth one that i managed to get few days ago on the junkyard
Last registration was half year ago,not so bad.
I'm not going to tell you plans,gonna tell it when the time comes,step by step.
It costed me about 200 euros,i think it's not so bad.
I'm very happy about it,and i think i'm gonna start working on it very soon
Cheers from a112- Der Neue Kadett C Fahrer
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Tue Aug 07, 2007 5:31 pm Post subject: |
Amazing front bumper. Where did they find that!
| Back to top |
a112 Ryousuke
Posted: Tue Aug 07, 2007 6:20 pm Post subject: |
I don't know where they found it ,but i save it in the basment's recycle bin
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2604 Location: Amsterdam // The Netherlands
Posted: Wed Aug 08, 2007 9:42 am Post subject: |
drop a 4age in
_________________ "08 Honda Civic Hybrid
"84 AE86 Zenki Blue Levin (project racer) http://www.cardomain.com/ride/613398
KIS it
Keep It Sideways
| Back to top |
a112 Ryousuke
Posted: Wed Aug 08, 2007 1:23 pm Post subject: |
| robokill wrote: | drop a 4age in  |
If it would be easy (the gearbox and the costs),the italian equivalent is planned under the hood.
| Back to top |
Apolan Bunta
Joined: 27 Nov 2004 Posts: 2109 Location: Slovenia, Ljubljana
Posted: Wed Aug 08, 2007 2:28 pm Post subject: |
evo još ovdje, congrats! Banzai Koruno-kun
| Back to top |
a112 Ryousuke
Posted: Thu Aug 09, 2007 2:18 am Post subject: |
Continued to do some things today.
I pulled out the car from the garage and tried to detach the front seat,it was all ok,a bit coroded screws,but got used to it.It was down in few minutes.
Found some money in the car
I vacuumed the carpet so i can easly remove it,and detached the seatbelt mechanism,the plastic at the gear shifter,and few other plastics,the carpet was out.
The floor is in pretty much in a good condition,a few rust spots,but nothing to worry,usually the floor is completly rusted.
Moved to the back seats,part of the job outside,but the sun came down,so i had to move in the garage for the light.
Had a few problems with the seats,but it was eventually out.
Detached the rear panels also.
I remembered that i have old rear bonnet somewhere,and i took a flaslight to see around the house.Voila,found it.
Detached the old one,and attached the new one only with 3 screws beacuse the mountings were all rusty.Left it without keylock,and attached the hammer to it to get some weight .
I fixed the handbrake a bit,it was also a bit rusty,it's good now,and put the car to sleep.
Cheers.
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Thu Aug 09, 2007 8:39 am Post subject: |
I can see the garagefloor through it!
| Back to top |
a112 Ryousuke
Posted: Thu Aug 09, 2007 12:38 pm Post subject: |
That's even good,in compare to other ones where you can drive Flinstones Style
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Thu Aug 09, 2007 2:20 pm Post subject: |
| a112 wrote: | That's even good,in compare to other ones where you can drive Flinstones Style
That's exactly what the neighbour said when I brought in the hachi with a big rusthole next to the pedals.
| Back to top |
Apolan Bunta
Posted: Thu Aug 09, 2007 5:06 pm Post subject: |
| a112 wrote: | | ,a few rust spots, |
a few? a few? not to rain on your parade but that looks pretty bad. I mean nothing is unfixable, but i still think you'd be much better off, if you just saved another 100-200 eur and got a better one.. looks like you've got your work cut out for the next half year or so. After you're done with this, you might as well start your own welding company
good luck!
| Back to top |
a112 Ryousuke
Posted: Sat Aug 11, 2007 1:02 am Post subject: |
This is from yesterday.
Haven't done much of a job today,haven't had time.
Shortly,removed the rear bumper and the tow hook finally
There was a few problems with the hook,as usually rusty screws and hard reachable.
After that,i disconnected rear lights.
Started removing the front ligths and fenders,but screws were very very rusty,so i put some WD40 on it and had a sleep . Detached the fender screws that went down well.And yes,detached some badly done DIY net over the cooler that was also fitten with lousy and rusty screws.
That's all for today,cheers.
| Back to top |
a112 Ryousuke
Posted: Sat Aug 11, 2007 9:27 pm Post subject: |
Woke up at 9AM and started to do some work.
Ordered new front fenders at the local parts shop,for C2 line(blinkers next to the lights) since they don't have C1 type.
Went home,turned the car around,and detached the hood and engine mount,mounted the lifter and pulled the engine little up.
Detached the motor starter that is not working.
We made a direct connection starter > battery and it didn't work.I took a visit to my friend who knows car electics,since my grandfather,also auto electrician is now for nothing(he is 83 year old).
Then started to detach the fenders and found out something new
All for today.
Cheers.
| Back to top |
Apolan Bunta
Posted: Sun Aug 12, 2007 1:52 am Post subject: |
| a112 wrote: | | a few rust spots |
dude seriously, i really really wish you well and hate to say i told you so.. but i told you so. after you break and sand everything off you wont be left with much to call it a car.. seriously. i know you would like to "doityourself" but this is like trying to cure cancer in its last stage..
| Back to top |
Mux213 Site Admin
Posted: Sun Aug 12, 2007 10:06 am Post subject: |
I think you need to locate just about every panel there is for this car and just weld together a new one:D
_________________ Greetz,
*** http://shop.aeu86.org - shop at aeu86 dot org ***
*** Check the commercial sales section for our closing down sale ***
No more hachi
| Back to top |
a112 Ryousuke
Posted: Sun Aug 12, 2007 12:53 pm Post subject: |
Nah,it's not so bad,after your comments my conlusion is that you never saw real rust
It can all be fixed,my brothers C was 5 times worse than this one,and it's fixed now,so i'm not scared.
Cheers.
| Back to top |
EE80Liftback Bunta
Joined: 16 Feb 2006 Posts: 501 Location: Espoo, Finland
1990 Peugeot 309
Posted: Sun Aug 12, 2007 7:24 pm Post subject: |
Have you seen this one: link
| Back to top |
a112 Ryousuke
Posted: Sun Aug 12, 2007 7:28 pm Post subject: |
Yeah,pretty much the same thing,it can be fixed as i've said.
And also,thank you for the link,seems like a cool forum.
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sun Aug 12, 2007 7:48 pm Post subject: |
Everything can be fixed eventually!
If you have weldingskills or know a person close by who has those skills the car may still be fixed economical, however I think a lot of us get scared by rust because they don't have someone close by with those skills and depend on professional welders to fix such rust and from experience I know that's very costly.
| Back to top |
a112 Ryousuke
Posted: Sun Aug 12, 2007 8:40 pm Post subject: |
Well,i have my father that has welding skills,and my brother who has even more welding skills,since he is working about 12 hours a day for my cousins inox fences,aluminium doors and windows for houses company.
But i'm gonna do it myself so i can get some skills.
Cheers.
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Mon Aug 13, 2007 9:29 am Post subject: |
Sounds like no problem at all.
| Back to top |
a112 Ryousuke
Posted: Tue Aug 14, 2007 8:13 pm Post subject: |
Something new arrived today
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 5191 Location: Netherlands Z-H
Posted: Tue Aug 14, 2007 9:39 pm Post subject: |
Some inspiration for you (nice kadetts I saw last weekend):
'81 poor guy with a money-pit
| Back to top |
RBpoweredSileighty Iketani
Joined: 14 Aug 2007 Posts: 26 Location: usa but wish i was in another country
Posted: Tue Aug 14, 2007 9:47 pm Post subject: |
pretty cool man g/l with the resto.
| Back to top |
a112 Ryousuke
Posted: Wed Aug 15, 2007 12:00 am Post subject: |
Nice ones Ivan.
| Back to top |
