| Author |
Message |
byd1380 Wataru
Joined: 22 Feb 2006 Posts: 87 Location: Belfast - Northern Ireland
Posted: Tue Jul 24, 2007 1:01 am Post subject: Injector Impedence. |
I have fitted ITB's and standalone ECU (Perfectpower XMSL). I had the car running and drove it over to the rolling road to get mapped. That was two months ago!!! The car will not take any throttle, we have tried moving the crank position sensor, rewired the ECU/engine, but still no joy. I am convince the ECU cannot drive the injectors. According to the Toyota manual the injectors should measure 13.8 Ohms. Does this mean thay are high impedence, could I change them for low impedence ones?
Cheers
Ivan
_________________ 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
| Back to top |
parrot Takumi
Joined: 24 Nov 2006 Posts: 279 Location: Melbourne AUSTRALIA
Posted: Tue Jul 24, 2007 2:58 am Post subject: |
13.8 is high impedence. Low impedence is typically in the 1 - 3 ohm range. Put a multimeter across the two injector terminals and see what resistance they are. Check what resistance injectors your standalone ecu requires. Perhaps the ECU can be programmed to run whatever you want to run resistance wise?
The ECU and injector resistances have to tally or it won't run properly
| Back to top |
jamiemirror Bunta
Joined: 04 Jan 2005 Posts: 1795 Location: Sofia, Bulgaria
Posted: Tue Jul 24, 2007 9:49 am Post subject: |
Get ECU (Perfectpower XMSL) manufacturer's support about that.
| Back to top |
jondee86 Takumi
Posted: Tue Jul 24, 2007 10:25 am Post subject: Choking ?? |
Is the engine running when you say "will not take any throttle" ?
Does this mean that it chokes and dies when you open the throttle ? If
so, it is often a sign that the timing is over-advanced.
Cheers... jondee86
_________________
| Back to top |
byd1380 Wataru
Posted: Wed Jul 25, 2007 4:18 pm Post subject: |
I have been in contatc with Perfectpower directly, they said I would nee to run a set of amplifiers to run the injectors of that impedence. I have got them now, so will hopefully get the car sorted soon.
Will keep you posted on the power output etc.
Cheers
Ivan
| Back to top |
jamiemirror Bunta
| Back to top |
byd1380 Wataru
Posted: Mon Jul 30, 2007 6:08 pm Post subject: injector impendence |
I went up to the car today and the guy had the injector Amplifiers wired in, this seems to have cured the problem, can runs quite well. His rolling road is broken at the minute so once that is sorted the car can get properly mapped. Then just need to tidy it up.
Will post power figures when it' done.
Cheers
Ivan
| Back to top |
tolisspi Takumi
Joined: 24 Jan 2008 Posts: 376 Location: Greece-Korinthos
Posted: Fri Aug 29, 2008 1:37 pm Post subject: |
Which injectors(up to the OEM) can we use for 4age bigport wiring plug/connector injectors? I dont want to replace the wiring connector of bigport.
Thx a lot
_________________ **COROLLA EE80 - 4AGE 124HP**
| Back to top |
Chrisso Iketani
Joined: 11 Jul 2008 Posts: 41 Location: Brisbane, QLD, Australia
Posted: Mon Sep 01, 2008 6:07 am Post subject: |
use any bigport or smallport injectors I think the plugs are the same. I thought they were all low impedence (just check with a multimeter) and top feed. Later 20v injectors are high imp. and side feed. If you need more flow, 7mge injectors fit and flow ~295cc, and 7mgte injectors flow more again.
| Back to top |
parrot Takumi
Posted: Mon Sep 01, 2008 1:30 pm Post subject: |
No, there are different plugs for different injectors.
See here http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Injectors.html
I also believe that you need the correct impedence for your ECU (high or low) but have heard of a couple of people who claim they put high impedence smallport greens into a bigport low impedence ECU controlled engine.
| Back to top |
Chrisso Iketani
Posted: Tue Sep 02, 2008 9:44 am Post subject: |
Thanks for the correction parrot. Actually, I should have know that because I have seen that page before! With regards to the correct impedence for the ECU you should be able to adjust this with resistors. However, I'm not an electrical kinda person so please get a second opinion on this!
| Back to top |
