  Home    shopshop    Garage  Forum RSS feed of our forumsForum RSS   FAQ   Search  Memberlist   Register    Log in
smallport redtop with 20V quads- question.
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
hachirokuGTV
Takumi
PostPosted: Thu Jun 21, 2007 1:30 pm    Post subject: smallport redtop with 20V quads- question. Reply with quote
If you use 20v quads either black or silvertop (yes i know there is a difference) with a redtop smallport, what loom do you use? What ecu can you use? Is there anything else that needs changing?
Back to top
View user's profile Send private message Visit poster's website
NoHachi
Moderator
PostPosted: Thu Jun 21, 2007 2:48 pm    Post subject: Reply with quote
Whatever loom your custom ecu or piggyback needs. Most of the stuff will fit on the stock RWD 4A-GE loom.
_________________
Back to top
robokill
Bunta
PostPosted: Thu Jun 21, 2007 3:48 pm    Post subject: Reply with quote
you will need a difrent tps as the 20v tps is difrent. You will need custom wiring on your intake because most wires don't fir the 20v setup. (connectors difrent etc
_________________
"08 Honda Civic Hybrid
"84 AE86 Zenki Blue Levin (project racer) http://www.cardomain.com/ride/613398
KIS it
Keep It Sideways
Back to top
hachirokuGTV
Takumi
PostPosted: Thu Jun 21, 2007 9:00 pm    Post subject: Reply with quote
So would i need 20v and smallport loom?
Back to top
Jimmi The Kid
Wataru
PostPosted: Thu Jun 21, 2007 9:45 pm    Post subject: Reply with quote
I am building one to. I will use the MegaSquirt ECU, with custom wirring. You can buy the few connectors at Toyota.
What will you do with the manifolds? I think I must build them myself. It should fit the smallport head and Blacktop ITBs.
_________________
AE86 newbie - but 20v oldie...
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Starlet/0/4...-984601079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
Back to top
View user's profile Send private message Send e-mail
NoHachi
Moderator
PostPosted: Thu Jun 21, 2007 9:49 pm    Post subject: Reply with quote
Nah, not really.
How do you plan on running the engine? Which ECU/Piggyback?
20V wiring looms sell for prices that are so high that you would think they were made of gold. But go out to the junkyard with a pair of wireclippers and you'll find out that connectors are pretty much universal between cars. It just takes some patience to collect them all from other wiring looms. After that a couple of hours with a wiring diagram and a welding iron is all thats needed.
_________________
Back to top
Jimmi The Kid
Wataru
By the way, does the AE92 Smallport flywheel fit the AE86 gearbox?
_________________
Cars I have owned:
Back to top
jamiemirror
Bunta
PostPosted: Fri Jun 22, 2007 10:18 am    Post subject: Reply with quote
Yes.
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
jondee86
Takumi
PostPosted: Fri Jun 22, 2007 11:52 am    Post subject: T50 to AE92... Reply with quote
AE92 flywheel takes a 212 (8.5") dia clutch and pressure plate, but
you use the standard AE86 throwout bearing when bolting up a T50.
Cheers... jondee86
_________________
Back to top
Os7213
Wataru
PostPosted: Sat Jun 23, 2007 10:34 pm    Post subject: Re: smallport redtop with 20V quads- question. Reply with quote
Hi
Im sure you already know but you will need an adapter plate to fit 20v itb on 16v head:
AE86 : Technical > smallport redtop with 20V quads question
This one is ported to fit 16v small ports with 42mm St itb.
For the ecu I suggest you MegaSquirt even use as piggyback only.
A MS-1 PCB2.2 like this one can do the job easily...cheap too and can be tune for ANY others modifications like putting a Knock sensor on 16v ect.
For the loom use the 16v with 20v tps.
You will need AFM connector modifications to provide fuel delivery
You will also need to tap an AIT sensor in one itb to provide perfect air temp reading (Place it near the port that will provide perfect reading) I suggest you use a GM AIT sensor(2 wires) if you decide to go with MS.
Also the harness can be connected directly to a ecu like the MS if you do it or buy it from me Wink this kind of plug-and-play adapter:
(Made for Tom Ae111 to plug and play stock harness 20v blacktop with EDIS4 attached)
Im not sure you really want to invest at this point but I suggest you to buy a complete blacktop with harness. Take the itb with tps, sell the head, you can get a good price for the head setup you can also sell your 16v block!!...
Use the 20v block with 16v red-top PORTED head to get the maximum air entry offer by the itb . Cams 9mm+ lift, shims underbuckets,springs Wink and have fun.
Good luck with your project
Hugo
Back to top
hachirokuGTV
Takumi
PostPosted: Sun Jun 24, 2007 12:28 am    Post subject: Reply with quote
How much does Megasquirt cost?
Back to top
hachirokuGTV
Takumi
PostPosted: Sun Jun 24, 2007 12:31 am    Post subject: Reply with quote
Would a Megasquirt 1 version 3 work?
Back to top
Os7213
Wataru
PostPosted: Sun Jun 24, 2007 7:18 pm    Post subject: Reply with quote
Yes
The Ms-1 PCB 3.0 can work too.
But since you dont really need this kind of board I suggest to go with PCB2.2
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
