Drifting with stock power on the dry
Goto page Previous  1, 2
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Drifters
Author Message
woper
Wataru
PostPosted: Fri May 04, 2007 11:23 am    Post subject: Reply with quote
It's hard to drift with underpower (stock engine). On close,slow sections it's ok but when You need speed and power - You cannot drift anymore.
see this on my short vid.
http://www.youtube.com/watch?v=bbNimtMQcgY
_________________
IF Carlsberg made an AE86, then it would be propably the best car in the world...
Back to top
Jan Pedersen
Moderator
PostPosted: Fri May 04, 2007 1:36 pm    Post subject: Reply with quote
I just hadd a bit of track time last saturday - actually my first Smile What I learned was that rear shocks has to be as hard as possible and you need high tire pressure too. Bushings makes it a lot easier too Wink
I could get it sideways but not that much since this was a first for me and there wasn't too far to the fences.
My setup:
Stock blue top
Poly bushings
TRD 8 / 6 kg/mm springs
TRD dampers
Rebuild stock LSD
Quaife steering rack
Shitty no name tires all around
Before going again I would to get some front tires with more grip and some camber plates. I dont believe that new sway bars is nessesary - yet any ways Wink I could easily play a bit more with tire pressure and damper settings (for grip driving) but thats different story...
_________________
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
Mux213
Site Admin
PostPosted: Fri May 04, 2007 3:32 pm    Post subject: Reply with quote
Uhm:
sideways
6.5kg front, 4.5kg rear springs.
Tokico HTS front (highest setting), KONI rear (mid setting)
RCAs
Poly bushings
1.9bar pressure in all 4 tires.
Bridgestone RE720 Potenza's with PLENTY of grip (grip timed laps on sunday were top 3 of the day)
And my diff currently doesn't lock to well Smile
Owh, and 25+ degrees and it hadn't rained for days..
Not me driving btw.
Actually currently my car is VERY easy to get into a drift, I still suck at it but I even managed some combination drifts last Sunday. I just need more practice.
P.S. Jan, you are right, stiffening up the rear suspention helps make the car easier to oversteer (you sacrefice grip), my car doesn't have such a setup since I primairely use my car for grip driving.
_________________
No more hachi Sad
Back to top
Jan Pedersen
Moderator
PostPosted: Fri May 04, 2007 5:44 pm    Post subject: Reply with quote
Stiffening the rear suspension will take away some grip. But since I haven't got some nice tires I just had some fun going sideways Cool I could addjust the dampers quite easy so I tweaked a bit. I middle position it was close to neutral but could be provoked pretty easily. At the highest level I got more angle and it simply was easier Smile
BTW I think that you could get even more grip with a bit higher tire pressure...
_________________
Back to top
Mux213
Site Admin
PostPosted: Fri May 04, 2007 5:59 pm    Post subject: Reply with quote
Jan,
The tire pressure has a bit of a story...
I put 2.5 bar in my tires at a gas station with one of those digital air things before running around Zandvoort.
Then on Lelystad Robokill drove my car for a bit on our way up there and mentioned my tire pressure was to high because the car was way to easy to drift (plainly mentioning this going sideways at 80 or so over a big crossing) and told me we should take some pressure out because we're were going to do gripdriving today.
So at Lelystad we asked around and one of the guys had a tire pressure meter and it measure over 3.5 bars in my tires!! WTF?!?!
So we took it down to 2.5 bars again assuming the air system at the gaspump was wrong. Turned out however the tire pressure meter wasn't very accurate, we later on measured and turned out the tires were actually at 1.9 bars now.
But at Lelystad we don't have an airpump to inflate the tires, so we had to make due.
Lelystad a year or so back driving Robokills car on 8Kg/7Kg and having tire pressure available (tire fitter was helping us out) we started playing around with tire pressure. He found that with the tires he had back then and his car setup, his fastest laps where with 2.1 to 2.2 bar in his tires.
P.S. having a car with very neutral balance I actually like very much even when drifting. Having it oversteer to easily just gives you a very messy oversteer. Atleast thats what I feel right now, not being very experienced in this field.Smile
_________________
No more hachi Sad
Back to top
Chell
Takumi
PostPosted: Fri May 04, 2007 6:27 pm    Post subject: Reply with quote
here is a foto of my car full stock
en drift on a dry track
_________________
Greetz Chell
Back to top
Jan Pedersen
Moderator
PostPosted: Fri May 04, 2007 6:36 pm    Post subject: Reply with quote
Oh I see...
Must have been nice to have the help of a pro! But I thought it would be a bit higher than 2,1-2,2 bar. We had an instructor who said that we had to go up to about 3 bar, but I guess this is different from one tire to another...
We had an airpump but I didn't care too much about playing with tire pressure - I just wanted to learn how to drive my car (not too soon after 6 years Exclamation )...
_________________
Back to top
Chell
Takumi
PostPosted: Fri May 04, 2007 7:33 pm    Post subject: Reply with quote
i have 3.5 bar in the rear and 2 bar in the front
_________________
Greetz Chell
Back to top
Mux213
Site Admin
PostPosted: Fri May 04, 2007 7:51 pm    Post subject: Reply with quote
To much pressure in the tires mean you will loose grip. That is nice for drifting though..
Also I guess if you have slick tires or so, pressure could be different aswell.
_________________
No more hachi Sad
Back to top
Chell
Takumi
PostPosted: Sat May 05, 2007 10:10 am    Post subject: Reply with quote
the best is rear no name tyre's or wanli
and in the front toyo trampio or this sort of tyres whit 1.8 bar
and rear 3.5 or higher
_________________
Greetz Chell
Back to top
Mux213
Site Admin
PostPosted: Sat May 05, 2007 10:19 am    Post subject: Reply with quote
Chell,
I wouldn't want to use Wanli for grip driving, but indeed, put these on the rear of a drift car:)
Funny fact, I drove past the Wanli factory when I was in China:) Should have said hi I guess:)
_________________
No more hachi Sad
Back to top
Chell
Takumi
PostPosted: Sat May 05, 2007 10:21 am    Post subject: Reply with quote
hahaha that funny
_________________
Greetz Chell
Back to top
gon
Ryousuke
PostPosted: Sat May 05, 2007 10:54 am    Post subject: Reply with quote
kinda drifting ..... (my second track day, I was still learing how to avoid the kick when the car stop drifting) this was like 2 or 3 years ago
it was with completly stock engine , some konig rewinds a KAAZ and some kony sport ....
everything else was stock
this is at the Portuguese main track.
http://video.google.co.uk/videoplay?docid=-2223887317243928789&hl=en-GB
second lap is a little better
Back to top
robokill
Bunta
PostPosted: Sat May 05, 2007 12:13 pm    Post subject: Reply with quote
gon to me it seems your scared when the car looses traction in the rear. Next time speed up more and the steering will be easier. Just keep hitting the gas when it start to slide. If you don't want the car to break out. First break before steering and make speed while goin into the corner.
If you brake and release gas while steering the rear loses traction
_________________
"05 Ford Mondeo Daily moving object
KIS it
Keep It Sideways
Back to top
Spitfire
Ryousuke
PostPosted: Sat May 05, 2007 12:54 pm    Post subject: Reply with quote
Mux just curious, whats the lowering you are currently running please? Smile
Back to top
AshCampbell
Ryousuke
PostPosted: Sat May 05, 2007 2:42 pm    Post subject: Reply with quote
I was on a Drifttraining on the Wachauring at 30. April
http://www.youtube.com/watch?v=0aVRrZ0cto4
http://www.youtube.com/watch?v=i3STJ1I29eA
And a little onboard action
http://www.veoh.com/videos/v444172bpKPpMSH
we got no camera mount,...
I was the first time on the racetrack, but the car feels very good, diff works well,....
_________________
DRIFT THAT SHIT!
Back to top
gon
Ryousuke
PostPosted: Sat May 05, 2007 2:48 pm    Post subject: Reply with quote
robokill , like I said it was 2 or 3 years ago , a lot as
changed in the car and in the way i drive it .
But I was not scared of the car, just didn't had the feeling of it to antecipate the regain of grip in the back whells.
The lack of power didn't help as well, the 4.77 dif ratio changed that a bit.
but now the car is different ...
http://video.google.com/videosearch?q=ae86pt
going to test this new engine setup on 17th of june in the same track Smile
Back to top
ZaX
Moderator
PostPosted: Sat May 05, 2007 4:28 pm    Post subject: Reply with quote
Topic says "dry drifting" and Wachau is all under water. Smile
Glad you had fun, I was on a start list for 30.4. but had slight problem with the car so I had to drop out.
I might be there for a drift challange this year again.
BR
ZaX
_________________
Back to top
View user's profile Send private message Send e-mail Visit poster's website
AshCampbell
Ryousuke
PostPosted: Sat May 05, 2007 4:43 pm    Post subject: Reply with quote
@zax
I missed you on the event,...
But at the driftchallenge we will meet us for sure Very Happy
_________________
DRIFT THAT SHIT!
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Drifters All times are GMT + 2 Hours
Page 2 of 2
Jump to:
You cannot attach files in this forum
