| Author |
Message |
banpei Site Admin
1982 Toyota Carina
Posted: Thu May 12, 2005 4:10 pm Post subject: |
| Widar wrote: | | banpei wrote: | Finally entered the writeup in the How-to section on the frontpage.  | But the two last writeuplinks aint working, look at the link "http://www.aeu86.org../Writeup/Engine/4AGE_to_7AGE_conversion/55/"
Hmmm, bizarre... The editor makes it wrong if I enter it's own domain, eg:
http://www.aeu86.org/Whatever/You/Put/Here
will result in:
http://www.aeu86.org/../../Whatever/You/Put/Here
So, fixed it by removing www.aeu86.org.
Weird.
| Back to top |
the boffin Wataru
Joined: 09 Jan 2006 Posts: 101 Location: Coupesville Northern Ireland
Posted: Wed May 10, 2006 5:13 pm Post subject: |
Did you use an uprated oil pump? Where or who makes them? Has to be 7A version due to positioning of the idler pulley.
_________________ Listen to the whine.
Not just a carbon copy.
| Back to top |
ae82rollaboy
Posted: Tue May 01, 2007 5:35 pm Post subject: |
i've just finished building one of these..
i used the original 7a oil pump - which seems to be enough for the application. the only thing that sucks about the 7a block is that it doesnt have oil squirters to cool the bottom of the pistons (as the later versions of the 4ag do) which could lead to overheating problems if you choose to go turbo down the track..
i'd recommend using ae92 (smallport 4ag pistons) for the conversion as the 7a ones are dished and wouldnt give you a very good compression.
i'll try to get a version of my own build process on the www.twincam.info forums with pics soon.
_________________ .:backyard engineer with a distinct lack of tools:.
| Back to top |
peter møller Takumi
1986 Toyota Corolla AE86 (late JDM Levin)
| Back to top |
gate4sweden
Posted: Tue May 13, 2008 11:25 pm Post subject: hi |
hi i am new here .
i am wondering wich 4AGE engine did you use? not the silver top right?
| Back to top |
projectrollas Wataru
Joined: 25 May 2007 Posts: 98 Location: othersideoftheworld
Posted: Wed May 14, 2008 12:17 am Post subject: |
he didnt use a 4ag. he used a 7afe block w/a 4ag head. so now its a 1.8 engine bottom end w/the 16 valve head.
silver top is a 20 valve. you should be able to use that head as well. i think theres a little bit more elbow grease to do that one though.
nice build log. helps out allot. im think of building one for a spare.
_________________ te72 wagon
ae86 levin coupe project
| Back to top |
