Clutch types for AE86
Goto page Previous  1, 2
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
Holli
Iketani
PostPosted: Tue Apr 24, 2007 8:52 pm    Post subject: Reply with quote
Got my clutch when i was home, he had to split 3 different kits to make one clutch, cost Ģ60 which i cant really argue with cos the guy is always interested in the car rather enjoys making clutches rather than off the shelf. that included the pressure plate and release bearing.
clark bros in belfast.
_________________
Its gotta go whoosh or give a whine!!!!
Back to top
SutteR
Takumi
1987 Toyota Corolla AE86 (late US)
PostPosted: Mon Jul 09, 2007 3:37 pm    Post subject: Reply with quote
Does anybody know which brand is the AE92GTi factory clutch plate? This is the 212mm diameter, P/N 31250-17020 or 31250-12320 - no difference imho.
I thought it should be Aisin as many other parts and like the AE86 factory clutch but according to a dealer it isn't. I was told it is something like NKK or whatever...
Can somebody help me out with this please?
_________________
1987 Toyota Corolla GT coupe - for holidays oversteer
1999 Toyota Corolla - for daily understeer
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Skype Name
*ian_pez*
PostPosted: Sun Nov 18, 2007 9:52 pm    Post subject: Reply with quote
Could someone please advise if the aw11 clutch has the same splines as the ae86?
There is one on ebay that I might buy if I can use it.
Regards
Ian
Back to top
View user's profile Send private message Visit poster's website
jamiemirror
Bunta
PostPosted: Mon Nov 19, 2007 12:21 pm    Post subject: Reply with quote
If it is for 4AGE engine - yes, same splines.
Avoid 4AGZE ones.
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
*ian_pez*
PostPosted: Mon Nov 19, 2007 6:46 pm    Post subject: Reply with quote
Thanks for the reply Jamie..maybe I will bid on it now. Cool
Back to top
kid
Ryousuke
PostPosted: Thu Dec 06, 2007 9:37 pm    Post subject: Reply with quote
just got teh info that blacktop engine with bt flywheel with 10v cluch will NOT fit. is that true? something with the pressure plate
_________________
Back to top
jamiemirror
Bunta
PostPosted: Fri Dec 07, 2007 11:16 am    Post subject: Reply with quote
Pressure plate depends from the flywheel used (200 and 212mm options, 4AC have diferent bolting pattern than 4AGE but can be easily redrilled to fit - 1 or 2 holes only).
Back to top
raki
Iketani
PostPosted: Sun Jan 20, 2008 10:18 pm    Post subject: Reply with quote
Now I installed a clutch with heavy duty pressure plate and 6-pad spring ceramic disc from ACT in my rallycar. The clutch feels quite good, though I only droveon the streets and not on a rallye yet. The pressure plate is harder to press, but not too hard, i find, and due to the springs, the shocks are not too hard. I think itīs a good choice for racecars that also must be driven on streets and need a good durability of transmission, rear axle, etc. But I can tell more, after the first rally this year...
There are different possibilities for pressure plates and discs, so i think everybody can find his best choice...
URL of the label:
http://www.advancedclutch.com/1274880/0/0/0/198...GTS_L4_1.6L_N_FI_(4AGEC).html
Best regards,
raki
_________________
www.sg-rallyesport.de
Back to top
View user's profile Send private message Visit poster's website AIM Address MSN Messenger Skype Name
F0Bman
Takumi
PostPosted: Fri May 09, 2008 7:50 pm    Post subject: Reply with quote
I have a 6 puck sprung hub clutch. Its awesome, sprung hub reduces the chatter.
_________________
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
www.TheTunerSource.com
Back to top
Miguel - Newera
Ryousuke
1985 Toyota Corolla AE86 (late JDM Levin)
PostPosted: Fri Jun 13, 2008 1:54 am    Post subject: Reply with quote
Careful with clutches that are too heavy duty, for example high pressure clutch covers, twin plate clutches, etc. If used hard these are too harsh for the weak T50 gearbox and if you have an uprated final drive such as say 4.77:1...
Use of too heavy duty a clutch will end in tears Sad - when your gearbox breaks, pinion gear loses teeth, etc. The best clutch (Which I see Tec Arts use in their D1 cars and Techo Pro Spirits recommend above all others is the RG or TRD clutch kit (Both are the same) with copper mix plate (Circular - not puck type). I've used the RG kit for drifting with a 200 bhp engine and mine lasted me almost 2 years of clutch kicking abuse before the plate finally got worn enough to slip. We've just replaced it with the same again Smile
They're not expensive, so there's no excuse for not getting one. Thumbsup
_________________
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
Back to top
tolisspi
Wataru
PostPosted: Sun Jun 15, 2008 12:05 pm    Post subject: Reply with quote
I have 4age tvis with 200mm flywheel and clutch kit.
I have a bottom 4agze and im thinking to change with 4age. Can i fit the 200mm clutch kit and flywheel?
Thx a lot
_________________
**COROLLA EE80 - 4AGE 124HP**
Back to top
raki
Iketani
PostPosted: Sun Jun 15, 2008 3:06 pm    Post subject: Reply with quote
After driving 5 rallys with the ACT clutch, I wrote a few postings before, I changed the disc, but still use the pressure plate. I destroyed a driveshaft and the t50 had to be changed, cause itīs not working well anymore. Of course there are also other reasons, but I think the disc is too harsh for the other stock components, when driving really hard. Though it was really nice driving it. Cool
Now I use a 4 puck sprung disc from "Sachs" which is also sintered metal, but works much smoother, almost like the stock one, maybe cause of stronger springs. But it is not so weak like the stock one. I donīt think this disc is available anymore, cause I got it from a friend who bought it few years ago but didnīt need it...
Best regards,
Michael
_________________
Back to top
D.Wars
Takumi
1985 Toyota Celica
PostPosted: Sat Aug 09, 2008 12:54 pm    Post subject: Reply with quote
i've installed an XTD stage 3 6puck clutch with a lightend flywheel, both new.
But now i cant get the car in gear when the engine is running? Shocked
I can't imagine that i have to re-bleed the system after changing the clutch.
Anyone with the same experience overhere?
With other words:
HELP? Blonde question
_________________
Pandalica Initial-d sprinter trueno wanabee look-a-like. Going downhill, time after time, mod after mod.
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 2 of 2
Jump to:
